> Weber Carb Restore Questions, Manifold preferences, Manual Choke, etc..
Literati914
post Aug 5 2026, 07:13 PM
I'm going to restore (try to) a set of Italian Weber 40idf carburetors to put on a 1.7 engine. I have two sets of manifolds... one set has a vacuum port on one runner (each side of engine), and the other has none at all. Is one type favored?
Which do I want to use, and why? - I have no idea what the vac ports would connect to. If they help even out idle, I'd want them I guess. Thoughts?
Literati914
post Aug 6 2026, 04:26 PM
QUOTE(Ninja @ Aug 6 2026, 05:18 PM) *
You will want the smallest venturis available for that.
Pierce Manifold is my go-to for Weber stuff.
They should have 27 or 28s available.
I'd start with 135 mains, 200 Airs, and 50 or 55 idles.
40 IDFs with 28 venturis are excellent for 2.0Ls with a "street" friendly motor.
Manifold ports don't matter, just make sure to cap them off.
Those might be helpful if you were going ITB fuel injection as they could form a plenum for an IAC (idle air control) valve.
Good real world info right there, thanks
- Lo-Fi Version Time is now: 20th September 2026 - 01:16 PM
