| robkammer |
Aug 7 2026, 01:50 PM
Robbo ![]() ![]() Group: Members Posts: 285 Joined: 7-January 21 From: Vermilion Ohio Member No.: 25,049 Region Association: NineFourteenerVille |
Trustees: Turns out that I need to pull the newly installed 2.0 and get it back to the builder. A poor oil pump install has it pumping oil in the wrong direction. Since the BB still has FI, it has hundreds of vacuum lines, fuel line, and electrical connections I really would like to avoid disturbing.
My question of the day is: is it reasonable to assume that I can remove the intake runners, and the plenum, with the injectors and injector boots still attached, as a unit ? The new injector boots from JB were an absolute B to install without ripping them. This was with the engine on the cart! As it ended up, I needed to install them AFTER the engine was in place due to clearance issues lifting the engine into the bay. I would like to avoid that exercise. To drop the engine I removed the fuel lines from the injectors. That left plenty of clearance. Ideally, I would like to remove the intake runners with the plenum and injectors in place, and reinstall with only new intake gaskets. Am I dreaming? Or is this possible? Cheers! Robbo |
JeffBowlsby The engine can be removed by just removing the air... Aug 7 2026, 02:28 PM
robkammer
The engine can be removed by just removing the ai... Aug 7 2026, 02:41 PM
JamesM
A poor oil pump install has it pumping oil in the... Aug 7 2026, 03:56 PM
emerygt350 It all comes apart super easy. Just get some pain... Aug 7 2026, 05:25 PM![]() ![]() |
Lo-Fi Version | Time is now: 7th August 2026 - 06:17 PM |
