| Literati914 |
Aug 5 2026, 07:13 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,385 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
I'm going to restore (try to) a set of Italian Weber 40idf carburetors to put on a 1.7 engine. I have two sets of manifolds... one set has a vacuum port on one runner (each side of engine), and the other has none at all. Is one type favored?
Which do I want to use, and why? - I have no idea what the vac ports would connect to. If they help even out idle, I'd want them I guess. Thoughts? |
| Literati914 |
Aug 7 2026, 02:24 PM
Thanks again guys!
One set has what I guess is cable controlled chokes and the other just has plates where chokes go. The set with cables, has the main cable cut... that is, I think it was cut short upon removal - I'm not even sure how/where it would lead to for manual control inside the cabin. Can someone enlighten me on that? Our climate here in N.TX. is mainly warm, like 9 mos. a year, but we do get some really cold spells too - do I even need a choke system for almost daily use? Sorry if these are lame questions, but I know almost nothing about Weber carbs. |
Literati914 Weber Carb Restore Questions Aug 5 2026, 07:13 PM
dtmehall what kind of distirbuter? Aug 5 2026, 07:18 PM
Literati914
These are bigger port... Aug 5 2026, 08:01 PM
porschetub the inlet manifolds you describe with the large va... Aug 5 2026, 10:31 PM
930cabman [quote name='Literati914' date='Aug 5 ... Aug 6 2026, 04:52 AM
dtmehall i am running 40idf's on a 1.7, and it runs gre... Aug 6 2026, 03:28 PM
Literati914
the inlet manifolds you describe with the large v... Aug 6 2026, 04:11 PM
Ninja You will want the smallest venturis available for ... Aug 6 2026, 04:18 PM
Literati914
You will want the smallest venturis available for... Aug 6 2026, 04:26 PM
dtmehall i am running 52 idles and 125 mains Aug 6 2026, 04:40 PM
porschetub
I'am a D... Aug 6 2026, 09:36 PM
dtmehall and 28 mm venturis Aug 6 2026, 04:41 PM
Literati914
and 28 mm ve... Aug 6 2026, 07:14 PM
porschetub
Thanks again guys!
One set has what I guess ... Aug 7 2026, 03:09 PM
dtmehall no chokes on mine Aug 7 2026, 04:20 PM![]() ![]() |
Lo-Fi Version | Time is now: 20th September 2026 - 01:16 PM |
