| robkammer |
Aug 7 2026, 01:50 PM
Robbo ![]() ![]() Group: Members Posts: 285 Joined: 7-January 21 From: Vermilion Ohio Member No.: 25,049 Region Association: NineFourteenerVille |
Trustees: Turns out that I need to pull the newly installed 2.0 and get it back to the builder. A poor oil pump install has it pumping oil in the wrong direction. Since the BB still has FI, it has hundreds of vacuum lines, fuel line, and electrical connections I really would like to avoid disturbing.
My question of the day is: is it reasonable to assume that I can remove the intake runners, and the plenum, with the injectors and injector boots still attached, as a unit ? The new injector boots from JB were an absolute B to install without ripping them. This was with the engine on the cart! As it ended up, I needed to install them AFTER the engine was in place due to clearance issues lifting the engine into the bay. I would like to avoid that exercise. To drop the engine I removed the fuel lines from the injectors. That left plenty of clearance. Ideally, I would like to remove the intake runners with the plenum and injectors in place, and reinstall with only new intake gaskets. Am I dreaming? Or is this possible? Cheers! Robbo |
| JamesM |
Aug 7 2026, 03:56 PM
Caretaker of 914s - Master of Fuel Injection ![]() ![]() ![]() ![]() Group: Members Posts: 2,287 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
A poor oil pump install has it pumping oil in the wrong direction. (IMG:style_emoticons/default/huh.gif) Im a little confused as to how that would even be possible, unless you are just talking about excessive clearances pumping it back into the sump? It only pumps one way, install it wrong and its not pumping anything at all. |
robkammer FI Intake question for the 'Brain Trust". Aug 7 2026, 01:50 PM
JeffBowlsby The engine can be removed by just removing the air... Aug 7 2026, 02:28 PM
robkammer
The engine can be removed by just removing the ai... Aug 7 2026, 02:41 PM
emerygt350 It all comes apart super easy. Just get some pain... Aug 7 2026, 05:25 PM![]() ![]() |
Lo-Fi Version | Time is now: 7th August 2026 - 06:17 PM |
