| NARP74 |
Aug 6 2026, 05:52 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,570 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains |
This is a continuation from a very long and frustrating fuel pump and fuel line project.
Everything is done BUT... I have a small leak under the tank on the feed connection at the threaded nut. I did not anneal the copper washer, that seemed like a 50 50 issue and I took the lazy route to get it done. Now that I have several gallons of gas in the tank and have gone for short test drives, I have leakage at that connection. I have good access to get a crow foot wrench on it and I have leaned into it quite a bit. I am seeing bad things happen if I really wrench on it. Don't want gallons of fuel pouring down on me again, don't ask! Is there a torque spec for that nut other than the typical German phrase? |
| Garland |
Aug 7 2026, 04:04 PM
Restoration Fanatic ![]() ![]() ![]() Group: Members Posts: 1,437 Joined: 8-January 04 From: ......Michigan...... Member No.: 1,535 Region Association: Upper MidWest
I have reused original fiber washers before. If they appear brittle, leave them on the tube/nipple and soak them in water for a short time. They will swell a bit and easily slide off the tube, and be reusable….
This previous link covering where to source the felt washers, and the proper assembly procedure. And more from, my note from above. LINK: Gas Tank Line Seals, Seals for the two hardlines out of tank ![]() ![]() |
NARP74 If it weren't for bad luck Aug 6 2026, 05:52 PM
Superhawk996 For what it’s worth it’s supposed to be a fibe... Aug 6 2026, 06:06 PM
NARP74 Well copper is what came with the new sock I order... Aug 6 2026, 08:23 PM
NARP74 Several online sources I checked send the screen w... Aug 7 2026, 07:55 AM
bajafreaks
Several online sources I checked send the screen ... Aug 7 2026, 08:28 AM
DennisV
I just installed my new tank, I wasn't able ... Aug 7 2026, 10:13 AM
bajafreaks
I just installed my new tank, I wasn't able... Aug 7 2026, 01:23 PM
Superhawk996 The fiber washers in this kit work but need a slig... Aug 7 2026, 12:02 PM
Spoke When I redid the tank I made the feed hoses so lon... Aug 7 2026, 03:36 PM
Shivers
When I redid the tank I made the feed hoses so lo... Aug 9 2026, 10:02 AM
NARP74 Looking at the PET for a 74, the parts description... Aug 9 2026, 07:47 AM
Superhawk996
So why is it that no company offers the correct ... Aug 9 2026, 11:29 AM
DennisV
The generic HF kit has washers that are so close ... Aug 9 2026, 12:58 PM
Superhawk996
Some very cursory poking around seems to suggest ... Aug 9 2026, 04:59 PM
914Sixer Check with aftermarket VW parts suppliers for fibe... Aug 9 2026, 09:39 AM
Superhawk996
Check with aftermarket VW parts suppliers for fib... Aug 9 2026, 11:35 AM
914Sixer Check the hole size and just get a guitar hole plu... Aug 9 2026, 11:23 AM
Shivers
Check the hole size and just get a guitar hole pl... Aug 9 2026, 03:00 PM
MikeK Try giving Painters Grinding in Denver a call. I ... Aug 9 2026, 11:31 AM
NARP74
Try giving Painters Grinding in Denver a call. I... Aug 9 2026, 11:36 AM
NARP74 As luck would have it, or lack thereof in my case,... Aug 9 2026, 04:27 PM
NARP74 Amazing what you learn when you get determined and... Aug 17 2026, 10:50 AM
NARP74 Still on the hunt for great substitutes. McMaster... Aug 18 2026, 04:25 PM
Flyinlow
Still on the hunt for great substitutes. McMaste... Aug 18 2026, 04:50 PM
NARP74
Still on the hunt for great substitutes. McMast... Aug 18 2026, 05:11 PM
bdstone914 @[url=http://www.914world.com/bbs2/index.php?showu... Aug 19 2026, 05:25 AM
DennisV Have you given any consideration to a sealant on t... Aug 19 2026, 06:21 AM
NARP74 I'll take a look at the sealing surface.
Th... Aug 19 2026, 07:27 AM
NARP74 Should I double up on the washers? On the same si... Aug 19 2026, 07:45 PM![]() ![]() |
Lo-Fi Version | Time is now: 22nd September 2026 - 09:22 PM |
