| NARP74 |
Aug 6 2026, 05:52 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,570 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains |
This is a continuation from a very long and frustrating fuel pump and fuel line project.
Everything is done BUT... I have a small leak under the tank on the feed connection at the threaded nut. I did not anneal the copper washer, that seemed like a 50 50 issue and I took the lazy route to get it done. Now that I have several gallons of gas in the tank and have gone for short test drives, I have leakage at that connection. I have good access to get a crow foot wrench on it and I have leaned into it quite a bit. I am seeing bad things happen if I really wrench on it. Don't want gallons of fuel pouring down on me again, don't ask! Is there a torque spec for that nut other than the typical German phrase? |
| MikeK |
Aug 9 2026, 11:31 AM
Member ![]() ![]() Group: Members Posts: 141 Joined: 15-June 23 From: 80906 Member No.: 27,418 Region Association: Rocky Mountains |
Try giving Painters Grinding in Denver a call. I would be surprised if they didn't have the correct washer.
| NARP74 |
Aug 9 2026, 11:36 AM
NARP74 If it weren't for bad luck Aug 6 2026, 05:52 PM
Superhawk996 For what it’s worth it’s supposed to be a fibe... Aug 6 2026, 06:06 PM
NARP74 Well copper is what came with the new sock I order... Aug 6 2026, 08:23 PM
NARP74 Several online sources I checked send the screen w... Aug 7 2026, 07:55 AM
bajafreaks
Several online sources I checked send the screen ... Aug 7 2026, 08:28 AM
DennisV
I just installed my new tank, I wasn't able ... Aug 7 2026, 10:13 AM
bajafreaks
I just installed my new tank, I wasn't able... Aug 7 2026, 01:23 PM
Superhawk996 The fiber washers in this kit work but need a slig... Aug 7 2026, 12:02 PM
Spoke When I redid the tank I made the feed hoses so lon... Aug 7 2026, 03:36 PM
Shivers
When I redid the tank I made the feed hoses so lo... Aug 9 2026, 10:02 AM
Garland I have reused original fiber washers before. If th... Aug 7 2026, 04:04 PM
NARP74 Looking at the PET for a 74, the parts description... Aug 9 2026, 07:47 AM
Superhawk996
So why is it that no company offers the correct ... Aug 9 2026, 11:29 AM
DennisV
The generic HF kit has washers that are so close ... Aug 9 2026, 12:58 PM
Superhawk996
Some very cursory poking around seems to suggest ... Aug 9 2026, 04:59 PM
914Sixer Check with aftermarket VW parts suppliers for fibe... Aug 9 2026, 09:39 AM
Superhawk996
Check with aftermarket VW parts suppliers for fib... Aug 9 2026, 11:35 AM
914Sixer Check the hole size and just get a guitar hole plu... Aug 9 2026, 11:23 AM
Shivers
Check the hole size and just get a guitar hole pl... Aug 9 2026, 03:00 PM
NARP74 As luck would have it, or lack thereof in my case,... Aug 9 2026, 04:27 PM
NARP74 Amazing what you learn when you get determined and... Aug 17 2026, 10:50 AM
NARP74 Still on the hunt for great substitutes. McMaster... Aug 18 2026, 04:25 PM
Flyinlow
Still on the hunt for great substitutes. McMaste... Aug 18 2026, 04:50 PM
NARP74
Still on the hunt for great substitutes. McMast... Aug 18 2026, 05:11 PM
bdstone914 @[url=http://www.914world.com/bbs2/index.php?showu... Aug 19 2026, 05:25 AM
DennisV Have you given any consideration to a sealant on t... Aug 19 2026, 06:21 AM
NARP74 I'll take a look at the sealing surface.
Th... Aug 19 2026, 07:27 AM
NARP74 Should I double up on the washers? On the same si... Aug 19 2026, 07:45 PM![]() ![]() |
Lo-Fi Version | Time is now: 22nd September 2026 - 09:24 PM |
