> If it weren't for bad luck, Under tank connection
NARP74
post Aug 6 2026, 05:52 PM
This is a continuation from a very long and frustrating fuel pump and fuel line project.
Everything is done BUT...
I have a small leak under the tank on the feed connection at the threaded nut. I did not anneal the copper washer, that seemed like a 50 50 issue and I took the lazy route to get it done. Now that I have several gallons of gas in the tank and have gone for short test drives, I have leakage at that connection.
I have good access to get a crow foot wrench on it and I have leaned into it quite a bit. I am seeing bad things happen if I really wrench on it. Don't want gallons of fuel pouring down on me again, don't ask!
Is there a torque spec for that nut other than the typical German phrase?
NARP74
post Aug 9 2026, 07:47 AM
Looking at the PET for a 74, the parts description says gasket not washer. That seems to indicate it should be fiber based.
So why is it that no company offers the correct part? All of the ones I see sell a copper washer with a new tank sock. I understand you can buy kits and other gaskets that need modification. But why does no one sell the correct product that just works?
Superhawk996
post Aug 9 2026, 11:29 AM
QUOTE(NARP74 @ Aug 9 2026, 09:47 AM) *
I’m going to speak in the broadest terms and not directing this at anyone in particular.
Because the supply base often don’t understand the original design principles behind why an OEM chose the fiber washer in the first place and think that substituting something like the copper washer is an “upgrade”.
They likely have the copper washers sitting around for other purposes (brake systems, etc.) and don’t want to source and stock another part. Especially a part that has limited application and only sells maybe tens to fifty . . . Maybe a hundred of them a year.
No one is going to tool up a perfect fit fiber washer at those volumes. The generic HF kit has washers that are so close that you’re only trimming off maybe 0.5- 1.0 mm off the ID. It is easily done with a dremel, a hand file or sand paper wrapped around a screw driver.
When you play with with 50 year old cars it’s not reasonable to assume you’ll always be able to find off the shelf parts that fit perfectly without a bit of modification.
DennisV
post Aug 9 2026, 12:58 PM
QUOTE(Superhawk996 @ Aug 9 2026, 10:29 AM) *
Have you used these without issue? HF product description seems to indicate they are for water systems. Some very cursory poking around seems to suggest fiber washers meant for fuel get vulcanized. Maybe I'm over thinking it.
What is the proper ID and OD of these? I see photos in the parts vault but no dimensions. They seem to have a wide mating surface if those photos are of originals.
FWIW - BelMetric has several sizes of vulcanized fiber gaskets, if the VW vendors don't have the right sizes.
NARP74   If it weren't for bad luck   Aug 6 2026, 05:52 PM
Superhawk996   For what it’s worth it’s supposed to be a fibe...   Aug 6 2026, 06:06 PM
NARP74   Well copper is what came with the new sock I order...   Aug 6 2026, 08:23 PM
NARP74   Several online sources I checked send the screen w...   Aug 7 2026, 07:55 AM
bajafreaks   Several online sources I checked send the screen ...   Aug 7 2026, 08:28 AM
DennisV   I just installed my new tank, I wasn't able ...   Aug 7 2026, 10:13 AM
bajafreaks   I just installed my new tank, I wasn't able...   Aug 7 2026, 01:23 PM
Superhawk996   The fiber washers in this kit work but need a slig...   Aug 7 2026, 12:02 PM
Spoke   When I redid the tank I made the feed hoses so lon...   Aug 7 2026, 03:36 PM
Shivers   When I redid the tank I made the feed hoses so lo...   Aug 9 2026, 10:02 AM
Garland   I have reused original fiber washers before. If th...   Aug 7 2026, 04:04 PM
NARP74   Looking at the PET for a 74, the parts description...   Aug 9 2026, 07:47 AM
Superhawk996   So why is it that no company offers the correct ...   Aug 9 2026, 11:29 AM
DennisV   The generic HF kit has washers that are so close ...   Aug 9 2026, 12:58 PM
Superhawk996   Some very cursory poking around seems to suggest ...   Aug 9 2026, 04:59 PM
914Sixer   Check with aftermarket VW parts suppliers for fibe...   Aug 9 2026, 09:39 AM
Superhawk996   Check with aftermarket VW parts suppliers for fib...   Aug 9 2026, 11:35 AM
914Sixer   Check the hole size and just get a guitar hole plu...   Aug 9 2026, 11:23 AM
Shivers   Check the hole size and just get a guitar hole pl...   Aug 9 2026, 03:00 PM
MikeK   Try giving Painters Grinding in Denver a call. I ...   Aug 9 2026, 11:31 AM
NARP74   Try giving Painters Grinding in Denver a call. I...   Aug 9 2026, 11:36 AM
NARP74   As luck would have it, or lack thereof in my case,...   Aug 9 2026, 04:27 PM
NARP74   Amazing what you learn when you get determined and...   Aug 17 2026, 10:50 AM
NARP74   Still on the hunt for great substitutes. McMaster...   Aug 18 2026, 04:25 PM
Flyinlow   Still on the hunt for great substitutes. McMaste...   Aug 18 2026, 04:50 PM
NARP74   Still on the hunt for great substitutes. McMast...   Aug 18 2026, 05:11 PM
bdstone914   @[url=http://www.914world.com/bbs2/index.php?showu...   Aug 19 2026, 05:25 AM
DennisV   Have you given any consideration to a sealant on t...   Aug 19 2026, 06:21 AM
NARP74   I'll take a look at the sealing surface. Th...   Aug 19 2026, 07:27 AM
NARP74   Should I double up on the washers? On the same si...   Aug 19 2026, 07:45 PM
- Lo-Fi Version Time is now: 22nd September 2026 - 09:24 PM
