| 914rrr |
Aug 10 2026, 10:04 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,125 Joined: 1-July 03 From: McMinnville, TN Member No.: 874 Region Association: South East States |
Working on my brakes and installing new soft lines in the rear. Used PB Blaster to baptise both soft line fittings to hard lines that to go the proportioning valve. Re-applied each day for a few days.
Went to remove the drivers side soft line and the fitting rounded off before the hard line snapped of just above the fitting. Had a crummy made in India flare wrench laying around that spread right away and was quickly useless. Tried again with an 11 mm Proto combo wrench on the hard line barrel and a 17 mm Indian flare on the bottom soft line. Thought I was making progress until the line broke off just above the fitting (IMG:style_emoticons/default/headbang.gif) Now, I have to replace the drivers side hard line that goes on TOP of the proportioning valve, and possibly the other twin line going to the passenger side. How do you remove THAT fitting on top without pulling the engine? I could barely get an 11 mm stubby combo wrench on it, but have almost zero room to twist it. I'm in need of solutions, ideas, old timer trick, tips if anybody has any. |
| 914rrr |
Aug 18 2026, 09:45 PM
Success!! I was able to remove the passenger side hard line flare nut from the soft line AND the top flare nut on the broken drivers side hard line without damaging either! (IMG:style_emoticons/default/dancinnanner.gif)
I bought one of the cheap flare nut crows foot wrench sets from Walmart and a 3/8" flexible ratcheting T-Bar from Harbor Freight. These made removing and reinstalling the driver's side hard line's top flare nut on the proportioning valve possible. I honestly don't think I could have removed that top flare nut or reinstalled the new one without them! I also used my trusty vintage 3" C-Jaw Vice Grips (favorite tool in my tool box!) to hold / brace the passenger side rubber hose fitting and the 11 mm flare nut crows foot on the hard line fitting with a 3/8 swivel head ratchet and a long 3/8 extension. ![]() |
914rrr Any Tips, Tricks, Old School Methods, etc. to loosen stubborn brake line fittings? Aug 10 2026, 10:04 PM
bdstone914
Working on my brakes and installing new soft line... Aug 10 2026, 11:22 PM
bdstone914 Do you use a torch to heat the fitting. I rdid tha... Aug 10 2026, 11:31 PM
Jack Standz Somebody recommended these ratcheting flare wrench... Aug 10 2026, 11:41 PM
porschetub
Working on my brakes and installing new soft line... Aug 11 2026, 12:12 AM
BillC If you are replacing the line (hard or soft) anywa... Aug 11 2026, 08:16 AM
brant Try aero kroil
I find it much better than pb Aug 11 2026, 08:29 AM
emerygt350 Watch any episode of vice grip garage.... Aug 11 2026, 09:45 AM
Chris H.
LOL ex... Aug 11 2026, 10:59 AM
Root_Werks
LOL e... Aug 21 2026, 10:39 AM
VaccaRabite I usually just accept that I'm going to break ... Aug 11 2026, 11:13 AM
914rrr Thanks everyone! I was told by another member ... Aug 11 2026, 11:27 AM
Cvrguy I did what BillC did, cut the old rubber hose just... Aug 14 2026, 03:17 PM
emerygt350 That's the other vgg bit of advice. Sacrifice... Aug 14 2026, 04:25 PM
rgalla9146 Ancient brake hoses swell inside.
When thi... Aug 19 2026, 06:09 AM![]() ![]() |
Lo-Fi Version | Time is now: 22nd October 2026 - 08:32 PM |
