> If it weren't for bad luck, Under tank connection
NARP74
post Aug 6 2026, 05:52 PM
This is a continuation from a very long and frustrating fuel pump and fuel line project.
Everything is done BUT...
I have a small leak under the tank on the feed connection at the threaded nut. I did not anneal the copper washer, that seemed like a 50 50 issue and I took the lazy route to get it done. Now that I have several gallons of gas in the tank and have gone for short test drives, I have leakage at that connection.
I have good access to get a crow foot wrench on it and I have leaned into it quite a bit. I am seeing bad things happen if I really wrench on it. Don't want gallons of fuel pouring down on me again, don't ask!
Is there a torque spec for that nut other than the typical German phrase?
NARP74
post Aug 18 2026, 04:25 PM
Still on the hunt for great substitutes. McMaster Carr has one size, have to buy 100, but they are cheap. BelMetric has the same size, but not the other. I am sure shipping would suck.
Flyinlow
post Aug 18 2026, 04:50 PM
Flyinlow
QUOTE(NARP74 @ Aug 18 2026, 03:25 PM) *
Hi.. I bought a 12”x12” sheet of1/16” nitril and made my own sealed up nice.Hope it lasts longer than me!
NARP74
post Aug 18 2026, 05:11 PM
QUOTE(Flyinlow @ Aug 18 2026, 04:50 PM) *
I am getting close to that. I can find the bigger one, 10 x 16 at several places. No one likes to make a 8 x 16. I found a bunch in England, France, Taiwan. Most require large quantities and a business account.
Wasn't sure the HF assortment would give me both washers.
AI had me running all over the globe. When I asked to narrow it down to USA, it was more difficult.
bdstone914
post Aug 19 2026, 05:25 AM
bdstone914
@NARP74
date='Aug 18 2026, 04:11 PM' post='3268880']
[quote name='Flyinlow' post='3268879' date='Aug 18 2026, 04:50 PM']
[quote name='NARP74' post='3268876' date='Aug 18 2026, 03:25 PM']
[/quote]
[/quote]
[/quote]
The sealing surface on the tank needs to be honed smooth.
Had an install that kept dripping until we honed the sealing surfaces with 400 wet or dry sand paper.
Then i make my own fiber ashers from 3/32 gasket material. Punch when out with a hole punch. Insert the paper disk in the aluminun nut and trace the small hole. Remove the disc and punch the small hole. I use two washers on each. One on top and one below the flange.
I tried rubber and it did not work well. It defirmed when tightened.
NARP74   If it weren't for bad luck   Aug 6 2026, 05:52 PM
Superhawk996   For what it’s worth it’s supposed to be a fibe...   Aug 6 2026, 06:06 PM
NARP74   Well copper is what came with the new sock I order...   Aug 6 2026, 08:23 PM
NARP74   Several online sources I checked send the screen w...   Aug 7 2026, 07:55 AM
bajafreaks   Several online sources I checked send the screen ...   Aug 7 2026, 08:28 AM
DennisV   I just installed my new tank, I wasn't able ...   Aug 7 2026, 10:13 AM
bajafreaks   I just installed my new tank, I wasn't able...   Aug 7 2026, 01:23 PM
Superhawk996   The fiber washers in this kit work but need a slig...   Aug 7 2026, 12:02 PM
Spoke   When I redid the tank I made the feed hoses so lon...   Aug 7 2026, 03:36 PM
Shivers   When I redid the tank I made the feed hoses so lo...   Aug 9 2026, 10:02 AM
Garland   I have reused original fiber washers before. If th...   Aug 7 2026, 04:04 PM
NARP74   Looking at the PET for a 74, the parts description...   Aug 9 2026, 07:47 AM
Superhawk996   So why is it that no company offers the correct ...   Aug 9 2026, 11:29 AM
DennisV   The generic HF kit has washers that are so close ...   Aug 9 2026, 12:58 PM
Superhawk996   Some very cursory poking around seems to suggest ...   Aug 9 2026, 04:59 PM
914Sixer   Check with aftermarket VW parts suppliers for fibe...   Aug 9 2026, 09:39 AM
Superhawk996   Check with aftermarket VW parts suppliers for fib...   Aug 9 2026, 11:35 AM
914Sixer   Check the hole size and just get a guitar hole plu...   Aug 9 2026, 11:23 AM
Shivers   Check the hole size and just get a guitar hole pl...   Aug 9 2026, 03:00 PM
MikeK   Try giving Painters Grinding in Denver a call. I ...   Aug 9 2026, 11:31 AM
NARP74   Try giving Painters Grinding in Denver a call. I...   Aug 9 2026, 11:36 AM
NARP74   As luck would have it, or lack thereof in my case,...   Aug 9 2026, 04:27 PM
NARP74   Amazing what you learn when you get determined and...   Aug 17 2026, 10:50 AM
NARP74   Still on the hunt for great substitutes. McMaster...   Aug 18 2026, 04:25 PM
Flyinlow   Still on the hunt for great substitutes. McMaste...   Aug 18 2026, 04:50 PM
NARP74   Still on the hunt for great substitutes. McMast...   Aug 18 2026, 05:11 PM
bdstone914   @[url=http://www.914world.com/bbs2/index.php?showu...   Aug 19 2026, 05:25 AM
DennisV   Have you given any consideration to a sealant on t...   Aug 19 2026, 06:21 AM
NARP74   I'll take a look at the sealing surface. Th...   Aug 19 2026, 07:27 AM
NARP74   Should I double up on the washers? On the same si...   Aug 19 2026, 07:45 PM
- Lo-Fi Version Time is now: 22nd September 2026 - 09:22 PM
