| DennisV |
Aug 18 2026, 07:40 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,040 Joined: 8-August 20 From: Santa Rosa, CA Member No.: 24,575 Region Association: Northern California
Is this the correct bolt to secure the flapper box to the heat exchanger on a 914-6? Part number 901-211-631-00. Appears to be NLA. Paired with square nut.
It is what I removed from a pair of used flapper boxes I bought. I tried installing it on a new Dansk flapper / heat exchanger and it appears too short. Even if I try various clamps to compress the flange and close the distance. ![]() ![]() |
| bdstone914 |
Aug 19 2026, 03:29 AM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,415 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Is this the correct bolt to secure the flapper box to the heat exchanger on a 914-6? Part number 901-211-631-00. Appears to be NLA. Paired with square nut. It is what I removed from a pair of used flapper boxes I bought. I tried installing it on a new Dansk flapper / heat exchanger and it appears too short. Even if I try various clamps to compress the flange and close the distance. ![]() ![]() I assumed the 4 and 6 flappers took the same bolt. But thevpart number does start with 901. I can check if a 4 flapper fits a 6 exchanger. Im sure i have those bolts to check. Im betting it is the Dansk flapper that is the problem. |
| rgalla9146 |
Aug 19 2026, 07:50 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,998 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None
[quote name='bdstone914' post='3268916' date='Aug 19 2026, 05:29 AM']
[quote name='DennisV' post='3268892' date='Aug 18 2026, 06:40 PM'] Is this the correct bolt to secure the flapper box to the heat exchanger on a 914-6? Part number 901-211-631-00. Appears to be NLA. Paired with square nut. It is what I removed from a pair of used flapper boxes I bought. I tried installing it on a new Dansk flapper / heat exchanger and it appears too short. Even if I try various clamps to compress the flange and close the distance. ![]() ![]() [/quote] I assumed the 4 and 6 flappers took the same bolt. But thevpart number does start with 901. I can check if a 4 flapper fits a 6 exchanger. Im sure i have those bolts to check. Im betting it is the Dansk flapper that is the problem I agree. The bolt on my flappers is 32mm If the Dansk parts do everything else as they should a longer bolt will do the trick. If you choose to go with OE 6 flappers I have a pair of beauties Oh, one more thing. The bolt extends through the elongated hole. The square nut goes on the round hole side. The round hole side keeps the nut from turning. And one more. Put a flat washer on the elongated hole side to keep the clamp from getting bent. |
DennisV Flapper Box Clamp Bolt 914-6 Aug 18 2026, 07:40 PM
Puebloswatcop Dennis, I tried looking it up in the PET and othe... Aug 18 2026, 07:51 PM
DennisV
The bolt extends through the elongated ho... Aug 20 2026, 08:30 AM
johnhora Dennis...here is a picture I took today of my OEM ... Aug 19 2026, 04:51 PM
johnhora RE: Flapper Box Clamp Bolt 914-6 Aug 19 2026, 04:52 PM
aturboman Here is an NOS valve and retainer bolt/nut. Intere... Aug 22 2026, 06:25 PM![]() ![]() |
Lo-Fi Version | Time is now: 23rd October 2026 - 07:11 AM |
