| jmargush |
Aug 18 2026, 07:22 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 512 Joined: 8-June 04 From: Goshen, IN Member No.: 2,176 |
I have read several of the hot start (starter related not fuel) and have mixed opinions on the fix as the threads exhibit as well.
I have had the car on the road for 24 years and never had a problem with the stock setup. then the other week at an autox I shut the car off in grid and it wouldn't turn over enough to start. Let it cool down and it started fine. Did some reading when I got home. At this point I have cleaned all the connections except the one on the transmission. Cables look good other than the one going to the alternator 9it have some corrosion around the terminal on the starter. Ran it for 10 or so minutes the other day shut it off let it sit for a few minutes it started but seemed a bit on the slow side shut it off and tried again much slower but did eventually start did it again and it was even slower next time it wouldn't even turn over. While doing this I was checking voltage form the ignition wire terminal on the solenoid to negative on battery. it is down to about volts when trying to start. so would you say this is confirmation of ignition switch or need for the additional solenoid or might the battery be weak? |
| Ninja |
Aug 19 2026, 01:24 PM
Member ![]() ![]() Group: Members Posts: 323 Joined: 25-September 25 From: Granbury Texas Member No.: 29,004 Region Association: Southwest Region |
I'd install the hot start relay as a diagnostic step.
I believe in them. You can feed the relay from the battery terminal on the starter. Original is a path from battery to ignition switch to solenoid. About 12 feet long with multiple connections. The path with a hot start relay could be less than a foot with less connections. I'd also install a bump start button somewhere in the engine compartment. One of the members here made a super nice box mount with integral start button on it. That's what I'll copy on mine. 50% of my "hard to start" cars get fixed with the relay. This is EVERYTHING, not just Porsche. This rule only applies to old cars that didn't have a relay installed from the factory. Everything modern I've hit already has a "start" relay installed. Maybe the manufactures are on to something... Grounds are SUPER important! I'm also prone to add grounds, mostly on old stuff that didn't have enough to begin with. |
jmargush confirming hot start Aug 18 2026, 07:22 PM
emerygt350
I have read several of the hot start (starter rel... Aug 19 2026, 04:54 AM
jmargush Only connection i haven't gotten a chance to c... Aug 19 2026, 01:02 PM
GregAmy I'm a big fan of the relays, too. It really do... Aug 19 2026, 01:41 PM
jmargush So i added a relay and still have slow sluggish st... Sep 12 2026, 05:10 PM
BillC
So i added a relay and still have slow sluggish s... Sep 12 2026, 07:13 PM
emerygt350 Did you double up on the ground? Run one from the... Sep 12 2026, 05:30 PM
jmargush
Did you double up on the ground? Run one from th... Sep 13 2026, 02:30 AM
jmargush
Did you double up on the ground? Run one from th... Sep 13 2026, 04:40 AM
Superhawk996 You can avoid throwing parts at this by troublesho... Sep 12 2026, 07:29 PM
emerygt350 That's hard when it's a high current issue... Sep 12 2026, 08:10 PM
Superhawk996
That's hard when it's a high current issu... Sep 12 2026, 09:53 PM
emerygt350 The fan shroud. There is a nice convenient hole f... Sep 13 2026, 05:15 AM
jmargush
The fan shroud. There is a nice convenient hole ... Sep 13 2026, 12:37 PM
emerygt350
[quote name='emerygt350' post='3271643' date='Sep... Sep 13 2026, 06:33 PM
jmargush Haven't tried another ground yet .
It has bee... Sep 28 2026, 01:45 PM
Superhawk996
60% SOC isn’t great
The fact that it drops t... Sep 28 2026, 05:55 PM![]() ![]() |
Lo-Fi Version | Time is now: 24th October 2026 - 01:50 AM |
