| DennisV |
Aug 14 2026, 07:20 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,040 Joined: 8-August 20 From: Santa Rosa, CA Member No.: 24,575 Region Association: Northern California
Is there anything special about the washers for the M12 transaxle mounting bolts (i.e., thicker, larger OD)? Part number: 914-375-239-00. #39 in parts catalog diagram.
They appear to be NLA and I can't find a description or photo of them. Washers I have are 13 ID and 27 OD. Normal thickness. Thank you. ![]() |
| Flyinlow |
Aug 19 2026, 05:11 PM
Flyinlow ![]() ![]() Group: Members Posts: 177 Joined: 17-October 20 From: British Columbia, Canada Member No.: 24,774 Region Association: Canada
Is there anything special about the washers for the M12 transaxle mounting bolts (i.e., thicker, larger OD)? Part number: 914-375-239-00. #39 in parts catalog diagram. They appear to be NLA and I can't find a description or photo of them. Washers I have are 13 ID and 27 OD. Normal thickness. Thank you. ![]() Hi… the washers are 40 mm O.D. 12 mm I.D.and 5mm thick |
| DennisV |
Aug 20 2026, 08:47 AM
Is there anything special about the washers for the M12 transaxle mounting bolts (i.e., thicker, larger OD)? Part number: 914-375-239-00. #39 in parts catalog diagram. They appear to be NLA and I can't find a description or photo of them. Washers I have are 13 ID and 27 OD. Normal thickness. Thank you. ![]() Hi… the washers are 40 mm O.D. 12 mm I.D.and 5mm thick Thank you! I'll add this info to the parts vault. The one's I made were 41.7 mm OD, drilled to 12.7 ID, and a 4 thick washer. So I'll probably roll with this for the foreseeable future. |
DennisV Transmission Mount Washer Spec Aug 14 2026, 07:20 PM
Luke M Yes, they are special thick washers. Pm Bruce Ston... Aug 14 2026, 07:30 PM
DennisV
Sigh. Than... Aug 14 2026, 07:41 PM
Cairo94507 I recall them being about 3/16" thick. Good ... Aug 19 2026, 08:10 AM![]() ![]() |
Lo-Fi Version | Time is now: 23rd October 2026 - 07:11 AM |
