| DennisV |
Aug 20 2026, 09:07 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,054 Joined: 8-August 20 From: Santa Rosa, CA Member No.: 24,575 Region Association: Northern California
What have you found or fabricated to tighten the 13 ATF hex nut on 914-6 heat exchanger passenger side? I think that's cylinder number 1.
I'm sure this is probably mechanics 101, but I'm having a hard time with it. I've tried every combination of 1/4 socket, u-joint, wobble extender, flex driver I can find. No room for a box or open end wrench as 2 sides are blocked by bracket and pipe. Nothing I've tried provides enough engagement to properly tighten it. ![]() |
| mepstein |
Aug 20 2026, 11:45 AM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,994 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
Often called a distributor wrench
Attached thumbnail(s) |
| DennisV |
Aug 21 2026, 07:42 AM
Often called a distributor wrench Thank you for the photo Mark. That helps clarify. I started looking for an SSI wrench based on @rudedude comment. That is a crazy looking wrench! |
DennisV Heat Exchanger Nut Tool Aug 20 2026, 09:07 AM
Cairo94507 Hi Dennis, Yeah there is a special wrench that is ... Aug 20 2026, 09:13 AM
rudedude SSI included either a 12mm or 13mm z shaped wrench... Aug 20 2026, 09:23 AM
sixnotfour best kept secret,,
https://www.amazon.com/dp/B0BB8... Aug 20 2026, 11:05 AM
nivekdodge
best kept secret,,
https://www.amazon.com/dp/B0BB... Aug 20 2026, 06:52 PM
DennisV
best kept secret,,
[url=https://www.amazon.com/dp... Aug 21 2026, 07:33 AM
Steve I use a stubby 13mm wrench. I did see S wrenches ... Aug 20 2026, 11:35 AM
Thank you for... Aug 21 2026, 10:35 AM
sixnotfour The support strap needs the hole slotted so it can... Aug 20 2026, 12:14 PM
Superhawk996
and your studs short..
:agree: Thats going to f... Aug 20 2026, 01:16 PM
porschetub
:agree: Thats going to ... Aug 20 2026, 04:40 PM
fixer34 Want to say I used a ratcheting box end, swivel he... Aug 20 2026, 05:38 PM
mepstein Yea, unless that’s some sort of optical illusion... Aug 20 2026, 06:23 PM
bdstone914 @[url=http://www.914world.com/bbs2/index.php?showu... Aug 22 2026, 09:50 PM
DennisV
Why is the piece of metal under the nut?
I can... Aug 23 2026, 08:07 AM
I can... Aug 23 2026, 08:47 AM
Steve
[quote name='DennisV' post='3269391' date='Aug 23... Aug 23 2026, 12:22 PM
sixnotfour Dansks version of the bracket... is the odity.
Rus... Aug 23 2026, 02:43 PM
DennisV
C... Aug 24 2026, 09:39 AM
DennisV As a follow-up for anyone else that heads down thi... Nov 13 2026, 09:19 AM![]() ![]() |
Lo-Fi Version | Time is now: 13th November 2026 - 12:28 PM |
