| 914ltd |
Jul 31 2026, 01:17 PM
Member ![]() ![]() Group: Members Posts: 247 Joined: 18-April 03 From: Peoria, IL Member No.: 581 Region Association: None
I have been making these repair panels since 1984. If you have longitudinal rust, door gap problems or excessive body flex, this panel system is a proven fix. I also have sold many to install in track cars and big engine swaps.
This system is the fastest, easiest and least expensive way to solve your chassis problem. Does not require removal of body panels to install. MIG or stick installation.The panel ties into the 3 bolts of the trailing arm mount and extends to the front wheel house if necessary.Excellent instructions included. This system has been used with Engman's/ Maddog's Porsche 914 Inner Longitudinal Stiffening Kit $375. Includes stateside shipping! 914 Limited Brad Mayeur 1162 N. Byerly Hills Dr. East Peoria, IL. 61611 309-868-4667 P914LTD@yahoo.com Attached thumbnail(s) Attached image(s)
| dug |
Aug 2 2026, 04:30 PM
914-6 conv in progress ![]() ![]() Group: Members Posts: 186 Joined: 26-December 06 From: Santa Cruz, CA Member No.: 7,382 Region Association: Northern California |
These require removing the existing jack points, and the sill support triangles. Then these slip up under the sills to support them.
I'm installing these on my car now. I had some rust around the jack points, so they had to come off anyway. I'm using pieces from restoration design outer longs to patch the area around the jack point that needed to be cut out, then adding Brad's panels over the top. The car will definitely be stiffer and ready for another 50 years:) If your longs and jack points are rust free, then it makes more sense to do the engman/maddog interior reinforcement. If you haven't taken your rockers off and checked thoroughly, do that before you decide. cheers, dug |
| friethmiller |
Aug 21 2026, 01:45 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,605 Joined: 10-February 19 From: Austin, TX Member No.: 22,863 Region Association: Southwest Region
These require removing the existing jack points, and the sill support triangles. Then these slip up under the sills to support them. I'm installing these on my car now. I had some rust around the jack points, so they had to come off anyway. I'm using pieces from restoration design outer longs to patch the area around the jack point that needed to be cut out, then adding Brad's panels over the top. The car will definitely be stiffer and ready for another 50 years:) If your longs and jack points are rust free, then it makes more sense to do the engman/maddog interior reinforcement. If you haven't taken your rockers off and checked thoroughly, do that before you decide. cheers, dug (IMG:style_emoticons/default/agree.gif) I've done both kits now on two different cars. The RD outside stiffeners are way easier to install, IMO. However, the increase in metal thickness at the door seam makes it a little awkward [later] when installing the inner door seals. Overall, I think the maddog kit provides better support and is worth the extra effort. |
914ltd Chassis repair and stiffning panels Jul 31 2026, 01:17 PM
scott_in_nh Hi Brad,
Awesome looking product.
I'm not full... Jul 31 2026, 03:55 PM
Thunderchief Hi Brad,
My longs are fine but I do want to stiffe... Aug 2 2026, 03:53 PM
914ltd
Hi Brad,
My longs are fine but I do want to stiff... Aug 2 2026, 04:27 PM
914ltd
[quote name='dug' post='3267299' date='Aug 2 2026... Aug 22 2026, 03:29 PM
914ltd The material is 11 gauge cold rolled steel. Aug 21 2026, 09:23 AM
Graydingo I bought the RD outside stiffeners. Sorry Brad, wa... Aug 22 2026, 10:24 AM
914ltd :bump: Sep 9 2026, 07:02 PM
914ltd
I have been making these repair panels since 1984... Oct 4 2026, 05:34 PM
914ltd In stock and ready to ship. Brad Mayeur Nov 4 2026, 03:28 PM![]() ![]() |
Lo-Fi Version | Time is now: 4th November 2026 - 06:55 PM |
