| North Coast Jim |
Aug 26 2026, 08:27 AM
Member ![]() ![]() Group: Members Posts: 349 Joined: 11-December 15 From: Northern Ohio Member No.: 19,450 Region Association: MidAtlantic Region
Have a newly rebuilt 2L in the car with 40 IDF Weber carbs which is running fine except for a RMS dripping oil. We believe we installed it correctly and took careful steps assembling the rest of the engine/flywheel/clutch/transmission. We believe that the crankcase vent system is not working properly which is pressurizing the crankcase as RPM builds, thereby pushing oil out the RMS.
My oil fill assy has a 022115542 PCV assy in it and a solid oil fill cap. I took the valve out to see if it was working. When I blow into the bottom it is initially open. Increased pressure it closes the valve. Seems backward to me. My oil fill tower has no vent in it. I do know that when I got this motor, 6 years ago, the PCV assy was in pieces all captured in the oil fill assy. I took it out and reassembled it thinking it was correct. Maybe not ?? I have Len Hoffman heads when he sold them direct and the vents are capped shut per his instructions. Any help is appreciated. |
| 914werke |
Aug 26 2026, 09:28 AM
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,768 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest
Lens suggestion (from that article) is in addition to capping the head vent lines also change the oil fill tower to the late version w/o the PVC & run a larger catch /vent line to a can
| North Coast Jim |
Aug 26 2026, 10:25 AM
North Coast Jim Proper PCV arrangment for a 2L Aug 26 2026, 08:27 AM
JamesM
We believe that the crankcase vent system is not ... Aug 26 2026, 10:28 AM
emerygt350 Interesting. I did not know this. Is that plug s... Aug 26 2026, 04:09 PM
JamesM
Interesting. I did not know this. Is that plug ... Aug 27 2026, 07:39 AM
JamesM I suspect people have found these before and had n... Aug 27 2026, 07:42 AM
emerygt350 Now I need to find one.... Aug 27 2026, 02:05 PM
JamesM
Unless you are just ... Aug 27 2026, 02:45 PM
emerygt350 Yeah, I just went to Lowe's to look at options... Aug 27 2026, 07:02 PM
JamesM
Yeah, I just went to Lowe's to look at option... Aug 28 2026, 08:55 AM
914werke
I suspect people have found these before and had ... Aug 28 2026, 07:22 AM
Dave_Darling One minor problem is that there is no "correc... Aug 28 2026, 11:57 PM
JamesM
One minor problem is that there is no "corre... Aug 29 2026, 08:19 PM
Ninja :agree: :agree: :agree:
And then...
A vacuum ... Aug 29 2026, 10:24 AM
North Coast Jim
Have a newly rebuilt 2L in the car with 40 IDF We... Sep 2 2026, 08:35 AM![]() ![]() |
Lo-Fi Version | Time is now: 22nd October 2026 - 08:35 PM |
