> Proper PCV arrangment for a 2L, A little help please
North Coast Jim
post Aug 26 2026, 08:27 AM
Have a newly rebuilt 2L in the car with 40 IDF Weber carbs which is running fine except for a RMS dripping oil. We believe we installed it correctly and took careful steps assembling the rest of the engine/flywheel/clutch/transmission. We believe that the crankcase vent system is not working properly which is pressurizing the crankcase as RPM builds, thereby pushing oil out the RMS.
My oil fill assy has a 022115542 PCV assy in it and a solid oil fill cap. I took the valve out to see if it was working. When I blow into the bottom it is initially open. Increased pressure it closes the valve. Seems backward to me. My oil fill tower has no vent in it.
I do know that when I got this motor, 6 years ago, the PCV assy was in pieces all captured in the oil fill assy. I took it out and reassembled it thinking it was correct. Maybe not ??
I have Len Hoffman heads when he sold them direct and the vents are capped shut per his instructions.
Any help is appreciated.
emerygt350
post Aug 27 2026, 07:02 PM
Yeah, I just went to Lowe's to look at options. My concern on any plastic or rubber cap is the heat. I found some electric box plugs but I don't want to put metal in a spot where it could fall into the crank. I need to think on this....
- Lo-Fi Version Time is now: 22nd October 2026 - 08:32 PM
