> Nose Job, What To Do
NARP74
post Aug 28 2026, 11:52 AM
I have never been a big fan of the nose on the 914 I purchased. I was always 50/50, sometimes I liked it, sometimes I tolerated it. It was on the car and it needed other work so I ignored it mostly. Now I am working on options to see what I can do.
It has a cooler under it, see the pics. Not the correct one though.
Go back to some form of stock?
I like the 916 front end, try to do something like that?
Some hybrid approach?
I don't really want to go down a $10K rabbit hole. I don't really want to cut into the front end and make it a full GT. I may be limiting my options as I think.
Craigers17
post Aug 28 2026, 05:25 PM
This might be a stupid question, but is this a -4 or a -6?
NARP74   Nose Job   Aug 28 2026, 11:52 AM
Cairo94507   It is all up to you. What is the condition of the...   Aug 28 2026, 01:18 PM
mepstein   It is all up to you. What is the condition of th...   Aug 28 2026, 01:36 PM
Shivers   Is that the only modification on the car? Stock bo...   Aug 28 2026, 01:36 PM
NARP74   The rest of the body is in great shape. It was re...   Aug 28 2026, 04:20 PM
mepstein   You can't really see it while you are driving ...   Aug 28 2026, 05:10 PM
Craigers17   This might be a stupid question, but is this a -4 ...   Aug 28 2026, 05:25 PM
Root_Werks   Hard to go wrong with stock. Looks the best to me...   Aug 28 2026, 06:37 PM
NARP74   Didn't know you could run a GT with a cooler a...   Aug 28 2026, 06:46 PM
NARP74   What my car wants to be when it grows up. Thanks ...   Sep 14 2026, 05:14 PM
mepstein   You can mount the cooler behind the front of the c...   Sep 14 2026, 06:29 PM
NARP74   You can mount the cooler behind the front of the ...   Sep 14 2026, 07:25 PM
dtmehall   the big plus is that you can drive it instead of s...   Sep 14 2026, 07:34 PM
NARP74   The big plus is that you can drive it instead of ...   Sep 15 2026, 08:02 AM
Chris914n6   PMS has an overpriced oil/water heat exchanger tha...   Sep 15 2026, 10:51 AM
NARP74   PMS has an overpriced oil/water heat exchanger th...   Sep 15 2026, 01:14 PM
Chris914n6   PMS has an overpriced oil/water heat exchanger t...   Sep 15 2026, 03:56 PM
Montreal914   I am currently restoring my 73 and converting it t...   Sep 15 2026, 01:51 PM
Montreal914   If more air flow is required, adding more holes in...   Sep 15 2026, 02:06 PM
Montreal914   ... just noticed the connections to your cooler ar...   Sep 15 2026, 02:16 PM
mepstein   Remember the front cooler is an extra one. You sti...   Sep 15 2026, 02:29 PM
NARP74   I was having some PPI work done before I bought th...   Sep 15 2026, 04:31 PM
Chris914n6   You should have a temp controlled oil cooler bypas...   Sep 15 2026, 10:03 PM
NARP74   You should have a temp controlled oil cooler bypa...   Sep 16 2026, 11:26 AM
- Lo-Fi Version Time is now: 22nd October 2026 - 07:22 PM
