| nmkimosabe |
Jul 31 2026, 04:18 PM
Member ![]() ![]() Group: Members Posts: 99 Joined: 16-March 25 From: Santa Fe, NM Member No.: 28,660 Region Association: Rocky Mountains |
My 1974 1.8 with fuel injection will only start by manually opening the throttle but I can't get it idle and thus run properly. I recently had the AFM rebuilt and replaced the points, plugs, condenser and replaced the CHT sensor but the problem continues as it did before. I've looked for vacuum leaks to no avail with starter fluid. I now seek the expertise of the members of this forum for additional suggestions.
| Superhawk996 |
Aug 27 2026, 07:08 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,191 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
Given you had a worn distributor is there a reason you wanted to stay with rebuilt stock instead of going to a new 123 distributor?
The thing that bothers me here is your last update was UPDATE: Well, the car finally was running better in the shop but then died when the car was taken for a test drive This really doesn’t align with the bad distributor theory as a bad distributor doesn’t usually work then stop during a test drive. Usually when you get those kind of died instantly while driving failures, it’s electrical in nature. As Wonki suggested, that could extend all the way into the ECU not failing until hot. You may want to reach out to @jeffbowlsby - at one time he was offering a test service of ECU’s in car and with the ECU test equipment but that may have been D-jet only ? You’ve had a lot of parts swapped but I’m still not getting the sense that you have a mechanic that really understands L-jet. Could just be that you’ve had multiple problems masking other problems. (IMG:style_emoticons/default/confused24.gif) I wish I had a better suggestion for you but there’s just too many questions I have that can’t easily be answered 2nd hand not knowing what he’s tested electrically and how he tested it. Maybe Wonkipop has better suggestions - I’m not an L-jet guy and he is. |
| nmkimosabe |
Aug 28 2026, 04:26 PM
Given you had a worn distributor is there a reason you wanted to stay with rebuilt stock instead of going to a new 123 distributor? The thing that bothers me here is your last update was UPDATE: Well, the car finally was running better in the shop but then died when the car was taken for a test drive This really doesn’t align with the bad distributor theory as a bad distributor doesn’t usually work then stop during a test drive. Usually when you get those kind of died instantly while driving failures, it’s electrical in nature. As Wonki suggested, that could extend all the way into the ECU not failing until hot. You may want to reach out to @jeffbowlsby - at one time he was offering a test service of ECU’s in car and with the ECU test equipment but that may have been D-jet only ? You’ve had a lot of parts swapped but I’m still not getting the sense that you have a mechanic that really understands L-jet. Could just be that you’ve had multiple problems masking other problems. (IMG:style_emoticons/default/confused24.gif) I wish I had a better suggestion for you but there’s just too many questions I have that can’t easily be answered 2nd hand not knowing what he’s tested electrically and how he tested it. Maybe Wonkipop has better suggestions - I’m not an L-jet guy and he is. I appreciate you taking the time to respond. The mechanic now believes the electrical issue when the car died was possibly the burnt 88Y pin on the dual relay which was later switched. I've been as methodical and thorough throughout this process, and it has been quite aggravating. I've had many vintage Porsche's and never experienced this level of frustration. Stay tuned for an update this week. |
| wonkipop |
Aug 29 2026, 05:06 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,783 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille
Given you had a worn distributor is there a reason you wanted to stay with rebuilt stock instead of going to a new 123 distributor? The thing that bothers me here is your last update was UPDATE: Well, the car finally was running better in the shop but then died when the car was taken for a test drive This really doesn’t align with the bad distributor theory as a bad distributor doesn’t usually work then stop during a test drive. Usually when you get those kind of died instantly while driving failures, it’s electrical in nature. As Wonki suggested, that could extend all the way into the ECU not failing until hot. You may want to reach out to @jeffbowlsby - at one time he was offering a test service of ECU’s in car and with the ECU test equipment but that may have been D-jet only ? You’ve had a lot of parts swapped but I’m still not getting the sense that you have a mechanic that really understands L-jet. Could just be that you’ve had multiple problems masking other problems. (IMG:style_emoticons/default/confused24.gif) I wish I had a better suggestion for you but there’s just too many questions I have that can’t easily be answered 2nd hand not knowing what he’s tested electrically and how he tested it. Maybe Wonkipop has better suggestions - I’m not an L-jet guy and he is. I appreciate you taking the time to respond. The mechanic now believes the electrical issue when the car died was possibly the burnt 88Y pin on the dual relay which was later switched. I've been as methodical and thorough throughout this process, and it has been quite aggravating. I've had many vintage Porsche's and never experienced this level of frustration. Stay tuned for an update this week. yeah well, the dual relay is real important for having the fuel pump work in an L jet. so........ lets see. i can tell you another interesting story about "ECU"s. going back 25+ years ago, and being an early adopter of CAD (thanks to my time in chicago, (IMG:style_emoticons/default/beerchug.gif) thank you america) i had a hot rodded 486 i ran my drafting and modelling software on. and one day it (IMG:style_emoticons/default/stromberg.gif) itself. i came in the office and fired it up and it ran for about 10 minutes. then kaput. if i remember right i went out for a coffee and cig or three and came back and switched it back on. fired up. ran for 10 minutes. kaput again. sat down and thought about it. right. somethings getting hot and when its up to temp is when if fails. rang my computer tach man nerd at that time. the late 90s were great. nerds door to door. he came and picked up the box and threw it in his ute and took it home. ripped it apart. found the crack in the circuit board. i said great. i have forgotten to back up for a fortnight or two and i have a masterpiece or three on it i need to retrieve. "no worries". he set the box up on his back verandah outside over night with a hard drive to down load all the data and fired it up first thing the next morning and before it could get hot enough to die he managed to get all the data off it. saved our arses. but not our bank account as we had to get a new machine. forced us to get a pentium. (IMG:style_emoticons/default/biggrin.gif) moral of the story. if it runs and idles well etc but then when you head out the door and get 10 minutes down the road and it dies well.............and its an EFI system from half a century ago, you got to suspect some thing electrical. and start testing and diagnosing. and resist spraying it with parts machine gun. i hope this is the end of your troubles. very frustrating as you say. however - i would say this, L jet is very very simple and honestly not hard to get to the bottom of, if you get your brain into what it is. its a fairly limited set of things that can go wrong. |
| nmkimosabe |
Aug 29 2026, 12:02 PM
Given you had a worn distributor is there a reason you wanted to stay with rebuilt stock instead of going to a new 123 distributor? The thing that bothers me here is your last update was UPDATE: Well, the car finally was running better in the shop but then died when the car was taken for a test drive This really doesn’t align with the bad distributor theory as a bad distributor doesn’t usually work then stop during a test drive. Usually when you get those kind of died instantly while driving failures, it’s electrical in nature. As Wonki suggested, that could extend all the way into the ECU not failing until hot. You may want to reach out to @jeffbowlsby - at one time he was offering a test service of ECU’s in car and with the ECU test equipment but that may have been D-jet only ? You’ve had a lot of parts swapped but I’m still not getting the sense that you have a mechanic that really understands L-jet. Could just be that you’ve had multiple problems masking other problems. (IMG:style_emoticons/default/confused24.gif) I wish I had a better suggestion for you but there’s just too many questions I have that can’t easily be answered 2nd hand not knowing what he’s tested electrically and how he tested it. Maybe Wonkipop has better suggestions - I’m not an L-jet guy and he is. I appreciate you taking the time to respond. The mechanic now believes the electrical issue when the car died was possibly the burnt 88Y pin on the dual relay which was later switched. I've been as methodical and thorough throughout this process, and it has been quite aggravating. I've had many vintage Porsche's and never experienced this level of frustration. Stay tuned for an update this week. yeah well, the dual relay is real important for having the fuel pump work in an L jet. so........ lets see. i can tell you another interesting story about "ECU"s. going back 25+ years ago, and being an early adopter of CAD (thanks to my time in chicago, (IMG:style_emoticons/default/beerchug.gif) thank you america) i had a hot rodded 486 i ran my drafting and modelling software on. and one day it (IMG:style_emoticons/default/stromberg.gif) itself. i came in the office and fired it up and it ran for about 10 minutes. then kaput. if i remember right i went out for a coffee and cig or three and came back and switched it back on. fired up. ran for 10 minutes. kaput again. sat down and thought about it. right. somethings getting hot and when its up to temp is when if fails. rang my computer tach man nerd at that time. the late 90s were great. nerds door to door. he came and picked up the box and threw it in his ute and took it home. ripped it apart. found the crack in the circuit board. i said great. i have forgotten to back up for a fortnight or two and i have a masterpiece or three on it i need to retrieve. "no worries". he set the box up on his back verandah outside over night with a hard drive to down load all the data and fired it up first thing the next morning and before it could get hot enough to die he managed to get all the data off it. saved our arses. but not our bank account as we had to get a new machine. forced us to get a pentium. (IMG:style_emoticons/default/biggrin.gif) moral of the story. if it runs and idles well etc but then when you head out the door and get 10 minutes down the road and it dies well.............and its an EFI system from half a century ago, you got to suspect some thing electrical. and start testing and diagnosing. and resist spraying it with parts machine gun. i hope this is the end of your troubles. very frustrating as you say. however - i would say this, L jet is very very simple and honestly not hard to get to the bottom of, if you get your brain into what it is. its a fairly limited set of things that can go wrong. I love your story about the hot -rodded 486 and I have similar memories of those and the IT nerds running around the company offices. I would agree that L-jet seems like a simple system once you figure it out, but it does require a learning curve to understand it fully and how all the components work together. Of course, what doesn't. I'm curious as to why you live in Antartica? |
nmkimosabe Starting Problems Jul 31 2026, 04:18 PM
rfinegan get a smoker from amazon, cheep and multi purpose.... Jul 31 2026, 04:23 PM
nmkimosabe
get a smoker from amazon, cheep and multi purpose... Aug 1 2026, 11:51 AM
fiacra I'm going to add a few more things I know abou... Aug 1 2026, 01:32 PM
fiacra :popcorn: Aug 6 2026, 10:29 AM
rfinegan It is running now with new ignition parts and base... Aug 6 2026, 11:10 AM
nmkimosabe
It is running now with new ignition parts and bas... Aug 10 2026, 12:03 PM
TRP Congratulations on getting it to start and idle. T... Aug 10 2026, 03:30 PM
nmkimosabe
Congratulations on getting it to start and idle. ... Aug 10 2026, 09:20 PM
TRP
Congratulations on getting it to start and idle.... Aug 10 2026, 11:36 PM
wonkipop
Congratulations on getting it to start and idle.... Aug 11 2026, 05:07 AM
nmkimosabe
[quote name='nmkimosabe' post='3268296' date='Aug... Aug 11 2026, 08:54 AM
wonkipop
[quote name='nmkimosabe' post='3268296' date='Au... Aug 11 2026, 06:01 PM
nmkimosabe
[quote name='nmkimosabe' post='3268355' date='Aug... Aug 24 2026, 02:23 PM
Artfrombama I too have a 74 1.8 with FI
I was having a similar... Aug 24 2026, 02:51 PM
wonkipop
Congratulations on getting it to start and idle. ... Aug 11 2026, 05:25 AM
nmkimosabe Thanks for the advice and I will double check that... Aug 26 2026, 09:32 AM
Superhawk996 Find a new mechanic that actually understands thes... Aug 26 2026, 12:56 PM
wonkipop
Find a new mechanic that actually understands the... Aug 26 2026, 03:19 PM
wonkipop as i recall @nmkimosabe - you sent me a PM telli... Aug 26 2026, 03:47 PM
nmkimosabe I will try to clarify the status and progress to d... Aug 27 2026, 06:13 PM
wonkipop
[quote name='wonkipop' post='3270009... Aug 29 2026, 02:07 PM
fiacra I can't believe this saga took yet another tur... Aug 27 2026, 09:01 PM
nmkimosabe
I can't believe this saga took yet another tu... Aug 28 2026, 04:27 PM
fiacra It's funny how things always seem to circle ba... Aug 29 2026, 07:54 AM
nmkimosabe
It's funny how things always seem to circle b... Aug 29 2026, 12:06 PM
nmkimosabe It was suggested to me today by a person with seve... Sep 5 2026, 05:34 PM
wonkipop
It was suggested to me today by a person with sev... Sep 6 2026, 07:49 PM
nmkimosabe
[quote name='nmkimosabe' post='3270852' date='Sep... Sep 7 2026, 03:37 PM
wonkipop
[quote name='nmkimosabe' post='3270852' date='Se... Sep 7 2026, 05:09 PM
nmkimosabe
[quote name='nmkimosabe' post='3271003' date='Sep... Sep 8 2026, 12:35 PM
Superhawk996 Not likely.
Can be measured if you really wanted... Sep 5 2026, 08:41 PM
nmkimosabe
Not likely.
Can be measured if you really wante... Sep 6 2026, 05:19 PM
wonkipop @nmkimosabe
situation re servicing /parts etc fo... Sep 8 2026, 01:00 PM
nmkimosabe
@[url=http://www.914world.com/bbs2/index.php?show... Sep 9 2026, 11:03 AM
re 87 alfa romeo spider. thats a co... Sep 9 2026, 01:12 PM
nmkimosabe
@[url=http://www.914world.com/bbs2/index.php?show... Sep 9 2026, 04:16 PM
some other tips for you re your 1.8 ... Sep 9 2026, 01:28 PM
nmkimosabe
[b]@[url=http://www.914world.com/bbs2/index.php?s... Sep 15 2026, 04:37 PM
Superhawk996 Here is the curve for CHT sensor - you will have a... Sep 15 2026, 07:28 PM
nmkimosabe
Here is the curve for CHT sensor - you will have ... Sep 16 2026, 12:22 PM
wonkipop
[quote name='Superhawk996' post='3271990' date='S... Sep 16 2026, 03:00 PM
Superhawk996 Lets be clear here. You have no obligation to kee... Sep 16 2026, 02:57 PM
wonkipop
Lets be clear here. You have no obligation to ke... Sep 16 2026, 04:20 PM
wonkipop i should add the symptoms are also fitting a fuel ... Sep 16 2026, 03:20 PM
wonkipop re vapor lock as an issue.
i live in a real hot p... Sep 16 2026, 03:38 PM
wonkipop ps
the fuel pressure figures you are looking for ... Sep 16 2026, 04:08 PM
Superhawk996 @wonkipop
The state of the repair industry is :... Sep 16 2026, 05:03 PM
nmkimosabe
@[url=http://www.914world.com/bbs2/index.php?show... Sep 17 2026, 06:53 PM
wonkipop yeah.
right on @Superhawk996 .
mike in here ju... Sep 17 2026, 02:49 AM
Superhawk996 I apologize if I’m coming off a bit harsh. My e... Sep 17 2026, 08:42 PM
nmkimosabe
I apologize if I’m coming off a bit harsh. My ... Sep 18 2026, 01:04 PM
fiacra Some great advice from @Superhawk996 and [b]@[u... Sep 20 2026, 12:37 PM
wonkipop
Some great advice from [b]@[url=http://www.914wo... Sep 20 2026, 02:18 PM
nmkimosabe
Some great advice from [b]@[url=http://www.914w... Sep 23 2026, 04:12 PM
Superhawk996 I don’t have a OEM 3 port pump on-site to measur... Sep 23 2026, 07:41 PM
nmkimosabe
I don’t have a OEM 3 port pump on-site to measu... Sep 24 2026, 11:11 AM
wonkipop
[quote name='wonkipop' post='3272527' date='Sep 2... Sep 24 2026, 05:04 AM
nmkimosabe
[quote name='wonkipop' post='3272527' date='Sep ... Sep 24 2026, 01:00 PM
nmkimosabe
[quote name='wonkipop' post='3272934' date='Sep 2... Sep 26 2026, 04:43 PM
Superhawk996 Give me a day or so and I’ll dig a 3 port fuel p... Sep 26 2026, 05:13 PM
nmkimosabe
Give me a day or so and I’ll dig a 3 port fuel ... Sep 26 2026, 07:09 PM
Superhawk996
Give me a day or so and I’ll dig a 3 port fuel... Sep 26 2026, 08:20 PM
nmkimosabe
[quote name='nmkimosabe' post='3273240' date='Sep... Sep 26 2026, 08:35 PM
wonkipop yeah that is interesting about the fuel pump in th... Sep 26 2026, 05:36 PM
nmkimosabe
yeah that is interesting about the fuel pump in t... Sep 26 2026, 07:06 PM
wonkipop
yeah that is interesting about the fuel pump in ... Sep 27 2026, 02:20 AM
nmkimosabe
[quote name='nmkimosabe' post='3273239' date='Sep... Sep 27 2026, 10:29 AM
wonkipop
[quote name='nmkimosabe' post='3273239' date='Se... Sep 27 2026, 01:20 PM
nmkimosabe
[quote name='nmkimosabe' post='3273326' date='Sep... Sep 27 2026, 01:46 PM
wonkipop
[quote name='nmkimosabe' post='3273326' date='Se... Sep 27 2026, 03:07 PM
nmkimosabe
[quote name='nmkimosabe' post='3273339' date='Sep... Sep 27 2026, 04:03 PM
wonkipop
[quote name='nmkimosabe' post='3273339' date='Se... Sep 27 2026, 04:30 PM
nmkimosabe
[quote name='nmkimosabe' post='3273356' date='Sep... Sep 27 2026, 04:57 PM
Superhawk996 Sorry for sloppy test setup.
Here are the curren... Sep 27 2026, 06:48 PM
nmkimosabe
Here are the curre... Sep 28 2026, 11:39 AM
Superhawk996
Impressive....as they say "a picture is wor... Sep 28 2026, 01:28 PM
wonkipop i pretty much agree with @Superhawk996 .
the co... Sep 28 2026, 02:35 PM
Superhawk996 Good point on the fuel lines - sometimes I assume ... Sep 28 2026, 06:47 PM
wonkipop
Good point on the fuel lines - sometimes I assume... Sep 28 2026, 07:15 PM
wonkipop double post for some reason, deleted, Sep 28 2026, 07:15 PM
nmkimosabe @[url=http://www.914world.com/bbs2/index.php?showu... Oct 4 2026, 07:48 PM
fiacra What a journey to get here. I'm glad you pers... Oct 4 2026, 08:31 PM
Superhawk996 :trophy: enjoy :driving: Oct 5 2026, 01:59 AM
nmkimosabe
Thanks again for you... Oct 5 2026, 08:39 AM
wonkipop top stuff
nothing like being in the hands of a me... Oct 5 2026, 05:25 AM
nmkimosabe
top stuff
nothing like being in the hands of a m... Oct 5 2026, 08:23 AM
Superhawk996
Of course, it was a rather expensive education.
... Oct 5 2026, 09:40 AM
nmkimosabe
... Oct 5 2026, 09:45 AM
wonkipop
top stuff
nothing like being in the hands of a ... Oct 5 2026, 04:30 PM
Superhawk996 Out of curiosity - did your mechanic keep the CHT ... Oct 5 2026, 11:39 AM
nmkimosabe
Out of curiosity - did your mechanic keep the CHT... Oct 5 2026, 02:46 PM
Superhawk996
Out of curiosity - did your mechanic keep the CH... Oct 5 2026, 03:10 PM
nmkimosabe
[quote name='nmkimosabe' post='3274235' date='Oct... Oct 5 2026, 03:30 PM
wonkipop
[quote name='nmkimosabe' post='3274235' date='Oct... Oct 6 2026, 01:29 AM
nmkimosabe
[quote name='nmkimosabe' post='3274235' date='Oc... Oct 6 2026, 10:50 AM![]() ![]() |
Lo-Fi Version | Time is now: 24th November 2026 - 09:17 PM |
