| Type 47 |
Aug 30 2026, 08:34 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 809 Joined: 1-June 10 From: St. Louis, MO Member No.: 11,790 Region Association: None
| Ninja |
Aug 30 2026, 09:12 PM
Member ![]() ![]() Group: Members Posts: 323 Joined: 25-September 25 From: Granbury Texas Member No.: 29,004 Region Association: Southwest Region |
Not enough info yet...
What do the other plugs look like? Does the fouled plug have a gap? Hard to tell in picture. But, without any info... Compression test Ignition spark intensity test, color of spark across a 1/4" gap Try another plug Fuel tests, pressure, air leakage, maybe fuel quality (if old with alcohol in it). Injector spray pattern tests I agree with the Hawk, the lean plug would bug me. How long has it been in? When is the last time the car ran well? |
Type 47 74' 1.8 #2 is not firing? Aug 30 2026, 08:34 PM
Superhawk996 Need to determine what is missing the fuel or the ... Aug 30 2026, 08:48 PM
Superhawk996 :agree:
All good points
In the end what you ha... Aug 30 2026, 09:37 PM
Type 47 took plugs out and all were sooty, except #2.
too... Aug 30 2026, 09:50 PM
JeffBowlsby Being Ljet, be sure to check that all 4 wires on t... Aug 30 2026, 10:06 PM
Type 47
Being Ljet, be sure to check that all 4 wires on ... Aug 31 2026, 05:40 PM
JeffBowlsby Not ground issues per se, but the injector wire at... Aug 31 2026, 08:13 PM
StarBear Had that a while ago, also on #2. The contact on t... Sep 1 2026, 06:05 AM
Type 47
Had that a while ago, also on #2. The contact on ... Sep 1 2026, 08:51 AM
rfinegan swap 1-2 injectors and see if the problem follow t... Sep 1 2026, 07:15 AM
Type 47
swap 1-2 injectors and see if the problem follow ... Sep 1 2026, 08:52 AM
L-Jet914 If you have access to noid lights, you can connect... Sep 2 2026, 06:54 PM![]() ![]() |
Lo-Fi Version | Time is now: 24th October 2026 - 01:16 AM |
