> 1971 914-4 Clearance Height?, Noticed my 914 is leaning ... should I be worried?
unclemoki
post Aug 29 2026, 11:48 PM
My recently "partially restored" 914-4 seems to have a noticeable lean. I checked the distance from the ground to the wheel-well all around and this is what I got:
Front Passenger/Right: 26"
Rear Passenger/Right: 23.5"
Front Driver's Side/Left: 25"
Rear Driver's Side/Left: 22.5"
I don't know what's "normal" for 914's but I'm wondering if I should be worried? I want to do more work to the car (electrical, shifting) but I feel like this needs to get sorted out first. I checked some pics from 2024 to compare and it looks like it might have been like this for a while so not sure why it seems much more noticeable now.
Any advice/thoughts/suggestions?
Quick History:
My late dad was the original owner. It was his daily driver for many years and then garaged for many years after he retired. At some point he passed it along to me. I'm not aware of any major body damage. I've heard stories of it being involved in an accident in the early 70's but I don't have any details.
I like to tinker but I'm no mechanic and I don't know much about 914's. In early 2020's I started a restoration project with a local shop - body (remove rust and dents), fresh paint, rebuilt engine, new exhaust, refresh interior ... spent more than I should have but got it looking pretty and back on the road. Brought it home summer of 2024. I've driven it maybe 100 miles in 2 years.
Aug 2026 .... sorry about the orientation
Aug 2024 ... for comparison
unclemoki
post Aug 31 2026, 04:20 PM
I found the invoice/receipt and right at the top it says, "Recommendations: front and rear shocks. Car sits lower on right rear and cannot be properly 100 aligned perfect. tie rods"
So yeah, I think I found my next steps. Although it notes that the right rear sits low ... which is different than what I found, unless "right" means driver's side.
Still learning about this car and reading/watching stuff online. Looks like the rear shocks are straight forward but not so sure about the front struts, based on the videos below. Also, not sure if I can/should try and get away with doing only the rear for now, driving it around, and then leaving the front for a later date.
Front Strut Replacement on a Porsche 914
Porsche 914 Steering, Front Suspension and Brakes Install [Project Bumblebee Ep. 26]
Porsche 914 Rear Shock and Coilover Install DIY ... the "coilover" idea looks pretty nifty!
Superhawk996
post Aug 31 2026, 04:27 PM
QUOTE(unclemoki @ Aug 31 2026, 06:20 PM) *
I’ll post one more time.
Shock absorbers have nothing to do with ride height.
You will be better served to spend your time focusing on adjusting the front torsion bars and replacing the rear springs if need be.
Do the front torsion bar adjustment first - it costs you nothing but time to do it.
CV - 27 years as automotive engineer with most of that focused on chassis systems.
unclemoki
post Aug 31 2026, 07:28 PM
QUOTE(Superhawk996 @ Aug 31 2026, 03:27 PM) *
Thanks @Superhawk996 & @930cabman . I appreciate your insight. I've been trying to educate myself on what the Torsion Bars are and how they work. I didn't try adjusting them but I took a pic of their current positions. The Driver's side is about in the middle. But looks like the passenger's side is almost bottomed out which, if I'm understanding correctly, means it is almost adjusted as low as it can go (without reindexing as @Cairo94507 mentioned)?
Passenger's Side
Driver's Side
unclemoki   1971 914-4 Clearance Height?   Aug 29 2026, 11:48 PM
bdstone914   1 inch lean is significant. First thing i would ch...   Aug 30 2026, 04:11 AM
Shivers   I've been into old cars most of my adult life....   Aug 30 2026, 04:37 AM
Front yard mechanic   Just get a fat girlfriend   Aug 30 2026, 05:08 AM
Superhawk996   Just get a fat girlfriend :rotfl: the easy butt...   Aug 30 2026, 06:39 AM
mepstein   Old suspension. Worn out springs, worn out bushing...   Aug 30 2026, 05:59 AM
930cabman   Old suspension. Worn out springs, worn out bushin...   Aug 30 2026, 01:28 PM
Ninja   Nice looking car! Welcome to the menagerie...   Aug 30 2026, 10:39 AM
unclemoki   I appreciate all of the feedback, THANKS! My ...   Aug 30 2026, 01:09 PM
mepstein   Seeing that it’s a family car, the idea that it ...   Aug 30 2026, 01:22 PM
unclemoki   Oh, and thank you all for the warm welcome! I...   Aug 30 2026, 01:32 PM
rjames   It was mentioned already, but I would start with t...   Aug 30 2026, 01:46 PM
JeffBowlsby   I would start by measuring to the chassis not the ...   Aug 30 2026, 03:01 PM
Jamie   I would start by measuring to the chassis not the...   Aug 31 2026, 11:27 AM
930cabman   I would start by measuring to the chassis not th...   Aug 31 2026, 04:25 PM
unclemoki   I would start by measuring to the chassis not the...   Aug 31 2026, 08:06 PM
Superhawk996   I keep seeing mention of bushings and inserts (ie ...   Aug 30 2026, 06:27 PM
Cairo94507   That looks and sounds like a really nice car. I s...   Aug 31 2026, 07:30 AM
brant   I agree with all of the above I’d put new bushi...   Aug 31 2026, 08:42 AM
Big Len   Not that it would make that much of a level differ...   Aug 31 2026, 11:50 AM
unclemoki   Not that it would make that much of a level diffe...   Aug 31 2026, 04:22 PM
unclemoki   I found the invoice/receipt and right at the top i...   Aug 31 2026, 04:20 PM
Superhawk996   I found the invoice/receipt and right at the top ...   Aug 31 2026, 04:27 PM
930cabman   I found the invoice/receipt and right at the top...   Aug 31 2026, 05:39 PM
Superhawk996   . Can the bars (either one or the other) lose some...   Aug 31 2026, 07:56 PM
unclemoki   I found the invoice/receipt and right at the top...   Aug 31 2026, 07:28 PM
unclemoki   Actually, if this is all I need (replacing the str...   Aug 31 2026, 06:15 PM
mepstein   Remove the top nut with an impact. Pull the strut ...   Aug 31 2026, 06:58 PM
unclemoki   Remove the top nut with an impact. Pull the strut...   Aug 31 2026, 07:31 PM
914sgofast2   For what it's worth, when I got my 914, it was...   Aug 31 2026, 06:59 PM
unclemoki   For what it's worth, when I got my 914, it wa...   Aug 31 2026, 07:37 PM
Superhawk996   You have plenty of torsion bar adjustment to play ...   Aug 31 2026, 07:53 PM
unclemoki   BTW - Found this image at the site below ... does ...   Aug 31 2026, 08:23 PM
- Lo-Fi Version Time is now: 22nd November 2026 - 06:36 AM
