| unclemoki |
Aug 29 2026, 11:48 PM
Newbie ![]() Group: Members Posts: 11 Joined: 7-November 24 From: California Member No.: 28,450 Region Association: Northern California |
My recently "partially restored" 914-4 seems to have a noticeable lean. I checked the distance from the ground to the wheel-well all around and this is what I got:
Front Passenger/Right: 26" Rear Passenger/Right: 23.5" Front Driver's Side/Left: 25" Rear Driver's Side/Left: 22.5" I don't know what's "normal" for 914's but I'm wondering if I should be worried? I want to do more work to the car (electrical, shifting) but I feel like this needs to get sorted out first. I checked some pics from 2024 to compare and it looks like it might have been like this for a while so not sure why it seems much more noticeable now. Any advice/thoughts/suggestions? Quick History: My late dad was the original owner. It was his daily driver for many years and then garaged for many years after he retired. At some point he passed it along to me. I'm not aware of any major body damage. I've heard stories of it being involved in an accident in the early 70's but I don't have any details. I like to tinker but I'm no mechanic and I don't know much about 914's. In early 2020's I started a restoration project with a local shop - body (remove rust and dents), fresh paint, rebuilt engine, new exhaust, refresh interior ... spent more than I should have but got it looking pretty and back on the road. Brought it home summer of 2024. I've driven it maybe 100 miles in 2 years. Aug 2026 .... sorry about the orientation Aug 2024 ... for comparison |
| JeffBowlsby |
Aug 30 2026, 03:01 PM
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,390 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None
I would start by measuring to the chassis not the fenderwells. Flat/level garage floor to the corner doughnuts on the floor pan. Factory correct should be uniformly ~6 in.
| unclemoki |
Aug 31 2026, 08:06 PM
I would start by measuring to the chassis not the fenderwells. Flat/level garage floor to the corner doughnuts on the floor pan. Factory correct should be uniformly ~6 in. Thanks for the suggestion. I was thinking that might be a good idea since I wasn't sure if the wheel wells were supposed to be the same height all the way around. Considering what @Jamie and @930cabman said, here is what I got measuring to the bottom edge of the 4 "donuts" (which all seem to jut out from the bottom about the same distance): Front Passenger/Right: 8" Rear Passenger/Right: 7.5" Front Driver's Side/Left: 7" Rear Driver's Side/Left: 6.5" Which suggests only .5" difference front to back and 1" difference between the right and left. |
unclemoki 1971 914-4 Clearance Height? Aug 29 2026, 11:48 PM
bdstone914 1 inch lean is significant. First thing i would ch... Aug 30 2026, 04:11 AM
Shivers I've been into old cars most of my adult life.... Aug 30 2026, 04:37 AM
Front yard mechanic Just get a fat girlfriend Aug 30 2026, 05:08 AM
Superhawk996
:rotfl: the easy butt... Aug 30 2026, 06:39 AM
mepstein Old suspension. Worn out springs, worn out bushing... Aug 30 2026, 05:59 AM
930cabman
Old suspension. Worn out springs, worn out bushin... Aug 30 2026, 01:28 PM
Ninja Nice looking car!
Welcome to the menagerie... Aug 30 2026, 10:39 AM
unclemoki I appreciate all of the feedback, THANKS!
My ... Aug 30 2026, 01:09 PM
mepstein Seeing that it’s a family car, the idea that it ... Aug 30 2026, 01:22 PM
unclemoki Oh, and thank you all for the warm welcome! I... Aug 30 2026, 01:32 PM
rjames It was mentioned already, but I would start with t... Aug 30 2026, 01:46 PM
Jamie
I would start by measuring to the chassis not the... Aug 31 2026, 11:27 AM
930cabman
I would start by measuring to the chassis not th... Aug 31 2026, 04:25 PM
Superhawk996 I keep seeing mention of bushings and inserts (ie ... Aug 30 2026, 06:27 PM
Cairo94507 That looks and sounds like a really nice car. I s... Aug 31 2026, 07:30 AM
brant I agree with all of the above
I’d put new bushi... Aug 31 2026, 08:42 AM
Big Len Not that it would make that much of a level differ... Aug 31 2026, 11:50 AM
unclemoki
Not that it would make that much of a level diffe... Aug 31 2026, 04:22 PM
unclemoki I found the invoice/receipt and right at the top i... Aug 31 2026, 04:20 PM
Superhawk996
I found the invoice/receipt and right at the top ... Aug 31 2026, 04:27 PM
930cabman
I found the invoice/receipt and right at the top... Aug 31 2026, 05:39 PM
Superhawk996 . Can the bars (either one or the other) lose some... Aug 31 2026, 07:56 PM
unclemoki
I found the invoice/receipt and right at the top... Aug 31 2026, 07:28 PM
unclemoki Actually, if this is all I need (replacing the str... Aug 31 2026, 06:15 PM
mepstein Remove the top nut with an impact. Pull the strut ... Aug 31 2026, 06:58 PM
unclemoki
Remove the top nut with an impact. Pull the strut... Aug 31 2026, 07:31 PM
914sgofast2 For what it's worth, when I got my 914, it was... Aug 31 2026, 06:59 PM
unclemoki
For what it's worth, when I got my 914, it wa... Aug 31 2026, 07:37 PM
Superhawk996 You have plenty of torsion bar adjustment to play ... Aug 31 2026, 07:53 PM
unclemoki BTW - Found this image at the site below ... does ... Aug 31 2026, 08:23 PM![]() ![]() |
Lo-Fi Version | Time is now: 22nd November 2026 - 06:36 AM |
