| Type 47 |
Aug 30 2026, 08:34 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 809 Joined: 1-June 10 From: St. Louis, MO Member No.: 11,790 Region Association: None
| JeffBowlsby |
Aug 31 2026, 08:13 PM
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,356 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None
Not ground issues per se, but the injector wire attachments to the resistors are a known weakness, taking out each injector associated with a wire break.
Type 47 74' 1.8 #2 is not firing? Aug 30 2026, 08:34 PM
Superhawk996 Need to determine what is missing the fuel or the ... Aug 30 2026, 08:48 PM
Ninja Not enough info yet...
What do the other plugs lo... Aug 30 2026, 09:12 PM
Superhawk996 :agree:
All good points
In the end what you ha... Aug 30 2026, 09:37 PM
Type 47 took plugs out and all were sooty, except #2.
too... Aug 30 2026, 09:50 PM
JeffBowlsby Being Ljet, be sure to check that all 4 wires on t... Aug 30 2026, 10:06 PM
Type 47
Being Ljet, be sure to check that all 4 wires on ... Aug 31 2026, 05:40 PM
StarBear Had that a while ago, also on #2. The contact on t... Sep 1 2026, 06:05 AM
Type 47
Had that a while ago, also on #2. The contact on ... Sep 1 2026, 08:51 AM
rfinegan swap 1-2 injectors and see if the problem follow t... Sep 1 2026, 07:15 AM
Type 47
swap 1-2 injectors and see if the problem follow ... Sep 1 2026, 08:52 AM
L-Jet914 If you have access to noid lights, you can connect... Sep 2 2026, 06:54 PM![]() ![]() |
Lo-Fi Version | Time is now: 21st September 2026 - 05:48 AM |
