| Literati914 |
Mar 13 2026, 01:37 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,379 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
I removed the engine tins from my 1.7 to clean and paint, while also degreasing the engine and transmission. I'm thinking I'll re-seal anything that's convenient to do-so while I'm here. There was an accumulation of baked on oil under the tins on top of the cylinders, not so much under (oil return tubes seem fairly well sealed and clean).. what does that usually imply, if anything?
| Literati914 |
Sep 2 2026, 11:51 AM
Wow almost 6 months since I asked this question and just now getting around to ordering engine/transmission seals. Thanks everyone for the suggestions, there were some here that I would not have thought of. Yes transmission seals are on the order. Here’s a picture of the front of the engine… guess I should pull the oil pump? To clean and re-seal .. or is that typically unnecessary? Attached thumbnail(s) |
Literati914 Re-seal Engine after Clean Up Mar 13 2026, 01:37 PM
mepstein In general, just normal for an air cooled engine. Mar 13 2026, 02:45 PM
bkrantz Check the cork seal under the oil filler "tan... Mar 13 2026, 07:42 PM
Literati914 OK, I'll check that cork seal, thanks.
The o... Mar 13 2026, 09:28 PM
porschetub
The ... Mar 15 2026, 01:03 PM
Jack Standz If you're going to have the oil cooler cleaned... Mar 15 2026, 04:28 PM
porschetub
If you're going to have the oil cooler cleane... Mar 16 2026, 02:08 PM
Literati914
If the motor is out ,I recommend you remove the c... Mar 15 2026, 07:18 PM
Chad911sc Just finished putting my engine back together last... Mar 16 2026, 01:01 PM
914sgofast2 Check the oil pressure sending unit for leaks and ... Mar 16 2026, 01:16 PM
Jack Standz As @Chad911sc mentioned, it required a minute o... Mar 16 2026, 04:28 PM
ctc911ctc I would replace all of the pushrod tube seals as w... Mar 16 2026, 04:53 PM
HFC3 It’s a perfect thread for where I’m at in my r... Sep 2 2026, 12:18 PM
Literati914 ^^ I cleaned the engine and transmission a little ... Sep 2 2026, 02:02 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd September 2026 - 08:34 PM |
