> Starting Problems, Starting with Throttle but Won't Idle
nmkimosabe
post Jul 31 2026, 04:18 PM
My 1974 1.8 with fuel injection will only start by manually opening the throttle but I can't get it idle and thus run properly. I recently had the AFM rebuilt and replaced the points, plugs, condenser and replaced the CHT sensor but the problem continues as it did before. I've looked for vacuum leaks to no avail with starter fluid. I now seek the expertise of the members of this forum for additional suggestions.
wonkipop
post Sep 8 2026, 01:00 PM
@nmkimosabe
situation re servicing /parts etc for aged aircooled VWs or porsches is identical to USA.
all the old air cooled mechanics are dead or retired. specialists machinists etc are dying out, but thats not restricted to being an air cooled thing. parts access is per USA situation.
i do a good deal of work on the car myself and what i don't do gets done by our resident mechanic. there are a bunch of us here with a co-operative workshop.
our cars get worked on by him on heavy duty matters. for instance he rebuilt all the suspension on my 914 when i recommissioned it about 5 years or so back. i had had its stored for the 16 years or so previous. the rest of the recommission work i assisted him.
for the last three months i have been head down - arse up on 4 late 60s / early 70s mercedes benzs.
working with the mechanic on various recommissioning and minor restoration servicing issues on those cars. one of which is a 1972 benz CE250 still running its D jet EFI system. its turned out to be a pretty special car. another of them is a benx 6.3 - the big V8. mechanically fuel injected. its been fun. i've been attending to all the interior wood trim in all the cars - amongst other things. have developed another useless set of skills as a result. (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif)
its all fun.
the older cars are not necessarily the headache for parts at present. funnily enough its the cars that are about 20-25 years old that parts are drying up on (which are cars that do not have extensive cult followings say like the 914). i have a friend with a 97 citroen xantia we look after for her. that car is suddely proving very difficult to get bits and bobs for. but she persists. she loves it. its sort of the last of the fully hydraulic citroens and they just don't make em like that anymore.
good luck with your 1.8
sometimes it can be exasperating trying to get to the bottom of a niggle.
nmkimosabe   Starting Problems   Jul 31 2026, 04:18 PM
rfinegan   get a smoker from amazon, cheep and multi purpose....   Jul 31 2026, 04:23 PM
nmkimosabe   get a smoker from amazon, cheep and multi purpose...   Aug 1 2026, 11:51 AM
fiacra   I'm going to add a few more things I know abou...   Aug 1 2026, 01:32 PM
fiacra   :popcorn:   Aug 6 2026, 10:29 AM
rfinegan   It is running now with new ignition parts and base...   Aug 6 2026, 11:10 AM
nmkimosabe   It is running now with new ignition parts and bas...   Aug 10 2026, 12:03 PM
TRP   Congratulations on getting it to start and idle. T...   Aug 10 2026, 03:30 PM
nmkimosabe   Congratulations on getting it to start and idle. ...   Aug 10 2026, 09:20 PM
TRP   Congratulations on getting it to start and idle....   Aug 10 2026, 11:36 PM
wonkipop   Congratulations on getting it to start and idle....   Aug 11 2026, 05:07 AM
nmkimosabe   [quote name='nmkimosabe' post='3268296' date='Aug...   Aug 11 2026, 08:54 AM
wonkipop   [quote name='nmkimosabe' post='3268296' date='Au...   Aug 11 2026, 06:01 PM
nmkimosabe   [quote name='nmkimosabe' post='3268355' date='Aug...   Aug 24 2026, 02:23 PM
Artfrombama   I too have a 74 1.8 with FI I was having a similar...   Aug 24 2026, 02:51 PM
wonkipop   Congratulations on getting it to start and idle. ...   Aug 11 2026, 05:25 AM
nmkimosabe   Thanks for the advice and I will double check that...   Aug 26 2026, 09:32 AM
Superhawk996   Find a new mechanic that actually understands thes...   Aug 26 2026, 12:56 PM
wonkipop   Find a new mechanic that actually understands the...   Aug 26 2026, 03:19 PM
wonkipop   as i recall @nmkimosabe - you sent me a PM telli...   Aug 26 2026, 03:47 PM
nmkimosabe   I will try to clarify the status and progress to d...   Aug 27 2026, 06:13 PM
Superhawk996   Given you had a worn distributor is there a reason...   Aug 27 2026, 07:08 PM
nmkimosabe   Given you had a worn distributor is there a reaso...   Aug 28 2026, 04:26 PM
wonkipop   Given you had a worn distributor is there a reas...   Aug 29 2026, 05:06 AM
nmkimosabe   [quote name='nmkimosabe' post='3269962' date='Aug...   Aug 29 2026, 12:02 PM
wonkipop   [quote name='wonkipop' post='3270009...   Aug 29 2026, 02:07 PM
fiacra   I can't believe this saga took yet another tur...   Aug 27 2026, 09:01 PM
nmkimosabe   I can't believe this saga took yet another tu...   Aug 28 2026, 04:27 PM
fiacra   It's funny how things always seem to circle ba...   Aug 29 2026, 07:54 AM
nmkimosabe   It's funny how things always seem to circle b...   Aug 29 2026, 12:06 PM
nmkimosabe   It was suggested to me today by a person with seve...   Sep 5 2026, 05:34 PM
wonkipop   It was suggested to me today by a person with sev...   Sep 6 2026, 07:49 PM
nmkimosabe   [quote name='nmkimosabe' post='3270852' date='Sep...   Sep 7 2026, 03:37 PM
wonkipop   [quote name='nmkimosabe' post='3270852' date='Se...   Sep 7 2026, 05:09 PM
nmkimosabe   [quote name='nmkimosabe' post='3271003' date='Sep...   Sep 8 2026, 12:35 PM
Superhawk996   Not likely. Can be measured if you really wanted...   Sep 5 2026, 08:41 PM
nmkimosabe   Not likely. Can be measured if you really wante...   Sep 6 2026, 05:19 PM
wonkipop   @nmkimosabe situation re servicing /parts etc fo...   Sep 8 2026, 01:00 PM
nmkimosabe   @[url=http://www.914world.com/bbs2/index.php?show...   Sep 9 2026, 11:03 AM
wonkipop   @nmkimosabe re 87 alfa romeo spider. thats a co...   Sep 9 2026, 01:12 PM
nmkimosabe   @[url=http://www.914world.com/bbs2/index.php?show...   Sep 9 2026, 04:16 PM
wonkipop   @nmkimosabe some other tips for you re your 1.8 ...   Sep 9 2026, 01:28 PM
nmkimosabe   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Sep 15 2026, 04:37 PM
Superhawk996   Here is the curve for CHT sensor - you will have a...   Sep 15 2026, 07:28 PM
nmkimosabe   Here is the curve for CHT sensor - you will have ...   Sep 16 2026, 12:22 PM
wonkipop   [quote name='Superhawk996' post='3271990' date='S...   Sep 16 2026, 03:00 PM
Superhawk996   Lets be clear here. You have no obligation to kee...   Sep 16 2026, 02:57 PM
wonkipop   Lets be clear here. You have no obligation to ke...   Sep 16 2026, 04:20 PM
wonkipop   i should add the symptoms are also fitting a fuel ...   Sep 16 2026, 03:20 PM
wonkipop   re vapor lock as an issue. i live in a real hot p...   Sep 16 2026, 03:38 PM
wonkipop   ps the fuel pressure figures you are looking for ...   Sep 16 2026, 04:08 PM
Superhawk996   @wonkipop The state of the repair industry is :...   Sep 16 2026, 05:03 PM
nmkimosabe   @[url=http://www.914world.com/bbs2/index.php?show...   Sep 17 2026, 06:53 PM
wonkipop   yeah. right on @Superhawk996 . mike in here ju...   Sep 17 2026, 02:49 AM
Superhawk996   I apologize if I’m coming off a bit harsh. My e...   Sep 17 2026, 08:42 PM
nmkimosabe   I apologize if I’m coming off a bit harsh. My ...   Sep 18 2026, 01:04 PM
fiacra   Some great advice from @Superhawk996 and [b]@[u...   Sep 20 2026, 12:37 PM
wonkipop   Some great advice from [b]@[url=http://www.914wo...   Sep 20 2026, 02:18 PM
nmkimosabe   Some great advice from [b]@[url=http://www.914w...   Sep 23 2026, 04:12 PM
Superhawk996   I don’t have a OEM 3 port pump on-site to measur...   Sep 23 2026, 07:41 PM
nmkimosabe   I don’t have a OEM 3 port pump on-site to measu...   Sep 24 2026, 11:11 AM
wonkipop   [quote name='wonkipop' post='3272527' date='Sep 2...   Sep 24 2026, 05:04 AM
nmkimosabe   [quote name='wonkipop' post='3272527' date='Sep ...   Sep 24 2026, 01:00 PM
nmkimosabe   [quote name='wonkipop' post='3272934' date='Sep 2...   Sep 26 2026, 04:43 PM
Superhawk996   Give me a day or so and I’ll dig a 3 port fuel p...   Sep 26 2026, 05:13 PM
nmkimosabe   Give me a day or so and I’ll dig a 3 port fuel ...   Sep 26 2026, 07:09 PM
Superhawk996   Give me a day or so and I’ll dig a 3 port fuel...   Sep 26 2026, 08:20 PM
nmkimosabe   [quote name='nmkimosabe' post='3273240' date='Sep...   Sep 26 2026, 08:35 PM
wonkipop   yeah that is interesting about the fuel pump in th...   Sep 26 2026, 05:36 PM
nmkimosabe   yeah that is interesting about the fuel pump in t...   Sep 26 2026, 07:06 PM
wonkipop   yeah that is interesting about the fuel pump in ...   Sep 27 2026, 02:20 AM
nmkimosabe   [quote name='nmkimosabe' post='3273239' date='Sep...   Sep 27 2026, 10:29 AM
wonkipop   [quote name='nmkimosabe' post='3273239' date='Se...   Sep 27 2026, 01:20 PM
nmkimosabe   [quote name='nmkimosabe' post='3273326' date='Sep...   Sep 27 2026, 01:46 PM
wonkipop   [quote name='nmkimosabe' post='3273326' date='Se...   Sep 27 2026, 03:07 PM
nmkimosabe   [quote name='nmkimosabe' post='3273339' date='Sep...   Sep 27 2026, 04:03 PM
wonkipop   [quote name='nmkimosabe' post='3273339' date='Se...   Sep 27 2026, 04:30 PM
nmkimosabe   [quote name='nmkimosabe' post='3273356' date='Sep...   Sep 27 2026, 04:57 PM
Superhawk996   Sorry for sloppy test setup. Here are the curren...   Sep 27 2026, 06:48 PM
nmkimosabe   Sorry for sloppy test setup. Here are the curre...   Sep 28 2026, 11:39 AM
Superhawk996   Impressive....as they say "a picture is wor...   Sep 28 2026, 01:28 PM
wonkipop   i pretty much agree with @Superhawk996 . the co...   Sep 28 2026, 02:35 PM
Superhawk996   Good point on the fuel lines - sometimes I assume ...   Sep 28 2026, 06:47 PM
wonkipop   Good point on the fuel lines - sometimes I assume...   Sep 28 2026, 07:15 PM
wonkipop   double post for some reason, deleted,   Sep 28 2026, 07:15 PM
nmkimosabe   @[url=http://www.914world.com/bbs2/index.php?showu...   Oct 4 2026, 07:48 PM
fiacra   What a journey to get here. I'm glad you pers...   Oct 4 2026, 08:31 PM
Superhawk996   :trophy: enjoy :driving:   Oct 5 2026, 01:59 AM
nmkimosabe   :trophy: enjoy :driving: Thanks again for you...   Oct 5 2026, 08:39 AM
wonkipop   top stuff nothing like being in the hands of a me...   Oct 5 2026, 05:25 AM
nmkimosabe   top stuff nothing like being in the hands of a m...   Oct 5 2026, 08:23 AM
Superhawk996   Of course, it was a rather expensive education. ...   Oct 5 2026, 09:40 AM
nmkimosabe   Of course, it was a rather expensive education. ...   Oct 5 2026, 09:45 AM
wonkipop   top stuff nothing like being in the hands of a ...   Oct 5 2026, 04:30 PM
Superhawk996   Out of curiosity - did your mechanic keep the CHT ...   Oct 5 2026, 11:39 AM
nmkimosabe   Out of curiosity - did your mechanic keep the CHT...   Oct 5 2026, 02:46 PM
Superhawk996   Out of curiosity - did your mechanic keep the CH...   Oct 5 2026, 03:10 PM
nmkimosabe   [quote name='nmkimosabe' post='3274235' date='Oct...   Oct 5 2026, 03:30 PM
wonkipop   [quote name='nmkimosabe' post='3274235' date='Oct...   Oct 6 2026, 01:29 AM
nmkimosabe   [quote name='nmkimosabe' post='3274235' date='Oc...   Oct 6 2026, 10:50 AM
- Lo-Fi Version Time is now: 24th November 2026 - 09:17 PM
