> confirming hot start
jmargush
post Aug 18 2026, 07:22 PM
I have read several of the hot start (starter related not fuel) and have mixed opinions on the fix as the threads exhibit as well.
I have had the car on the road for 24 years and never had a problem with the stock setup.
then the other week at an autox I shut the car off in grid and it wouldn't turn over enough to start.
Let it cool down and it started fine.
Did some reading when I got home.
At this point I have cleaned all the connections except the one on the transmission.
Cables look good other than the one going to the alternator 9it have some corrosion around the terminal on the starter.
Ran it for 10 or so minutes the other day shut it off let it sit for a few minutes
it started but seemed a bit on the slow side
shut it off and tried again much slower but did eventually start
did it again and it was even slower
next time it wouldn't even turn over.
While doing this I was checking voltage form the ignition wire terminal on the solenoid to negative on battery.
it is down to about volts when trying to start.
so would you say this is confirmation of ignition switch or need for the additional solenoid or might the battery be weak?
emerygt350
post Sep 12 2026, 05:30 PM
Did you double up on the ground? Run one from the neg terminal on the battery to the shroud.
jmargush
post Sep 13 2026, 04:40 AM
QUOTE(emerygt350 @ Sep 12 2026, 04:30 PM) *
The shroud being the body of the stater?
If so how heavy a gauge of wire?
jmargush   confirming hot start   Aug 18 2026, 07:22 PM
emerygt350   I have read several of the hot start (starter rel...   Aug 19 2026, 04:54 AM
jmargush   Only connection i haven't gotten a chance to c...   Aug 19 2026, 01:02 PM
Ninja   I'd install the hot start relay as a diagnosti...   Aug 19 2026, 01:24 PM
GregAmy   I'm a big fan of the relays, too. It really do...   Aug 19 2026, 01:41 PM
jmargush   So i added a relay and still have slow sluggish st...   Sep 12 2026, 05:10 PM
BillC   So i added a relay and still have slow sluggish s...   Sep 12 2026, 07:13 PM
emerygt350   Did you double up on the ground? Run one from the...   Sep 12 2026, 05:30 PM
jmargush   Did you double up on the ground? Run one from th...   Sep 13 2026, 02:30 AM
jmargush   Did you double up on the ground? Run one from th...   Sep 13 2026, 04:40 AM
Superhawk996   You can avoid throwing parts at this by troublesho...   Sep 12 2026, 07:29 PM
emerygt350   That's hard when it's a high current issue...   Sep 12 2026, 08:10 PM
Superhawk996   That's hard when it's a high current issu...   Sep 12 2026, 09:53 PM
emerygt350   The fan shroud. There is a nice convenient hole f...   Sep 13 2026, 05:15 AM
jmargush   The fan shroud. There is a nice convenient hole ...   Sep 13 2026, 12:37 PM
emerygt350   [quote name='emerygt350' post='3271643' date='Sep...   Sep 13 2026, 06:33 PM
jmargush   Haven't tried another ground yet . It has bee...   Sep 28 2026, 01:45 PM
Superhawk996   60% SOC isn’t great The fact that it drops t...   Sep 28 2026, 05:55 PM
- Lo-Fi Version Time is now: 24th October 2026 - 01:50 AM
