| thomasotten |
Sep 13 2026, 11:44 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,589 Joined: 16-November 03 From: San Antonio, Texas Member No.: 1,349 |
I have a 2056 cc engine running D-Jet. All new lines, harness, everything. The engine has 96 mm pistons and larger valves - 44/36. I had to tune the MPS away from the original factory settings or it was just running too lean. So I richened it up and it runs really well now, checked MPS and adjusted with an AFR gauge. Only worry is my ECU mixture knob has no effect. The throttle position sensor has been rebuilt and calibrated with a new board. I double checked and triple checked the calibration because I know that it won't go into the idle circuit, where the mixture knob has authority if the TPS isn't calibrated correctly. So, the next thing I tried was changing out the ECU. Still acts the same. Idle mixture knob has no authority. So I am wondering, is there something about adjusting the MPS that will cause the computer to never use the idle logic? I know it doesn't have any feedback that you get from an O2 sensor, but I am wondering if signals from the MPS can keep it from going into idle mode.
Thanks |
| 914werke |
Sep 13 2026, 12:44 PM
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,746 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest
what is the problem you are addressing?
Too high an idle? Have you smoked your engine to eliminate air leaks that would defeat idle adjustments? |
thomasotten TPS on DJet with 2056 Sep 13 2026, 11:44 AM
mgphoto Idle is controlled by the TPS, and the Pot on the ... Sep 13 2026, 12:24 PM
thomasotten
Too high... Sep 13 2026, 02:02 PM
mgphoto TPS needs to be bench adjusted with the throttle b... Sep 13 2026, 01:09 PM![]() ![]() |
Lo-Fi Version | Time is now: 13th September 2026 - 03:57 PM |
