| robkammer |
Sep 13 2026, 02:31 PM
Robbo ![]() ![]() Group: Members Posts: 287 Joined: 7-January 21 From: Vermilion Ohio Member No.: 25,049 Region Association: NineFourteenerVille |
Brain trust: I have a bout 60 miles on the LE motor and it's running pretty well. I have the regulator that came with the car, age is unknown. I am getting voltage readings anywhere between 12.6 to 14.2 at the battery depending on the rpm and temperature. My questions: Pelican shows a Hella unit that looks just like to one I have. Are there any solid state units out there that would be better to have? I don't have a spare so I'm going to order whatever is recommended, if for nothing else but to have a spare. BTW, the alternator looks to be a relatively new addition, prior to my taking stewardship, it's a Bosch reman.
Robbo |
| Ishley |
Sep 13 2026, 06:52 PM
Member ![]() ![]() Group: Members Posts: 362 Joined: 4-October 21 From: Clarendon Hills Il Member No.: 25,957 Region Association: Upper MidWest
I use this one I bought on Amazon. Works fine and is adjustable. Plugs in and was a direct swap. I installed it last year… 3k miles with no issues.
Attached thumbnail(s) |
robkammer Voltage regulator recs Sep 13 2026, 02:31 PM
porschetub
Brain trust: I have a bout 60 miles on the LE mot... Sep 13 2026, 03:09 PM
914Sixer Here you go >Real Bosch. Only place I know you... Sep 13 2026, 06:13 PM
emerygt350 So much better than the old ones.
https://a.co/d/... Sep 13 2026, 06:25 PM
pfreiburger Hello - Does anyone make an internal regulator alt... Sep 13 2026, 06:29 PM
scottthephotog I also just bought one of those voltage regulators... Sep 13 2026, 07:28 PM
dtmehall is that the white adjusting screw on the bottom? Sep 13 2026, 08:41 PM
Ishley Yes. I set it with my digital meter which is more ... Sep 13 2026, 09:25 PM![]() ![]() |
Lo-Fi Version | Time is now: 13th September 2026 - 10:42 PM |
