| Speedo |
Sep 14 2026, 05:56 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 660 Joined: 7-November 06 From: Boulder Member No.: 7,170 Region Association: Rocky Mountains
So this sort of resembles stock. I've never been a VW guy so I have no history on this part crossing over to 914s. This part has two feet I guess were used for injection molding? Came with the additional countersunk machine screws that screwed through the top of the striker, down through a metal shim and then into the top flat area of the shim into embedded machined metal anchors. I see no metal anchors in the shims unless they are buried under the feet. Are the metal anchors under the feet? Am I supposed to cut them off? What is going on here?
| bdstone914 |
Sep 14 2026, 06:27 PM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,379 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Yiu probably have an early 1970-1972 with the striker platesxthat do not have thr inner shoulder which was added when they changed to doors with reinforcements.
Note what you bought is a 311 (VW) part number. Both the VW parts. I have some good used ones of the other type that use the screws to attach. if you need them. |
Speedo door striker shim Sep 14 2026, 05:56 PM
bdstone914
Yiu probably have an early 1970-1972 with the str... Sep 14 2026, 06:34 PM
Speedo Thanks Bruce. My strikers are great, car arrived w... Sep 14 2026, 06:39 PM
bdstone914 @[url=http://www.914world.com/bbs2/index.php?showu... Sep 14 2026, 07:39 PM![]() ![]() |
Lo-Fi Version | Time is now: 14th September 2026 - 10:58 PM |
