> Nose Job, What To Do
NARP74
post Aug 28 2026, 11:52 AM
I have never been a big fan of the nose on the 914 I purchased. I was always 50/50, sometimes I liked it, sometimes I tolerated it. It was on the car and it needed other work so I ignored it mostly. Now I am working on options to see what I can do.
It has a cooler under it, see the pics. Not the correct one though.
Go back to some form of stock?
I like the 916 front end, try to do something like that?
Some hybrid approach?
I don't really want to go down a $10K rabbit hole. I don't really want to cut into the front end and make it a full GT. I may be limiting my options as I think.
post Sep 14 2026, 06:29 PM
914-6 GT in waiting
You can mount the cooler behind the front of the car, remove the row of plugs from the front and remover the two round plates on the rear of the trunk floor. They are just held in by seam sealer. No cutting. Use a cooler with a fan pack. You do need to cut out some of the lower front valance.
Personally, I really like the full on GT look and have no problem adjusting my car to get there.
NARP74
post Sep 14 2026, 07:25 PM
QUOTE(mepstein @ Sep 14 2026, 06:29 PM) *
I love the full GT look. Yes, but it's still a rabbit hole to me. Do the cooler, cut the front, add the cowl, cut the front bumper, and valance, figure out a spare tire option and mount it. All doable for sure. It has all been done and looks great. But if I do that, I am on the way to a very expensive car because I will want flares, then things have to match the flare, then a repaint and then a while I am in there a full rotisserie tribute to a GT. I know what will happen. That is why I posted that photo.
The car runs cool(ish) now with a cooler just bolted on the front. I was at 180 to 210 most of the weekend at RRC2026. Very hot and mountain passes at high altitude. Saw 250 a couple of long hot sections and long hill climbs. My frunk holes are still plugged.
I know this seems whiny, but i am trying to get there with the least amount of the possibility of going further down the rabbit hole.
NARP74   Nose Job   Aug 28 2026, 11:52 AM
Cairo94507   It is all up to you. What is the condition of the...   Aug 28 2026, 01:18 PM
mepstein   It is all up to you. What is the condition of th...   Aug 28 2026, 01:36 PM
Shivers   Is that the only modification on the car? Stock bo...   Aug 28 2026, 01:36 PM
NARP74   The rest of the body is in great shape. It was re...   Aug 28 2026, 04:20 PM
mepstein   You can't really see it while you are driving ...   Aug 28 2026, 05:10 PM
Craigers17   This might be a stupid question, but is this a -4 ...   Aug 28 2026, 05:25 PM
Root_Werks   Hard to go wrong with stock. Looks the best to me...   Aug 28 2026, 06:37 PM
NARP74   Didn't know you could run a GT with a cooler a...   Aug 28 2026, 06:46 PM
NARP74   What my car wants to be when it grows up. Thanks ...   Sep 14 2026, 05:14 PM
mepstein   You can mount the cooler behind the front of the c...   Sep 14 2026, 06:29 PM
NARP74   You can mount the cooler behind the front of the ...   Sep 14 2026, 07:25 PM
dtmehall   the big plus is that you can drive it instead of s...   Sep 14 2026, 07:34 PM
NARP74   The big plus is that you can drive it instead of ...   Sep 15 2026, 08:02 AM
Chris914n6   PMS has an overpriced oil/water heat exchanger tha...   Sep 15 2026, 10:51 AM
NARP74   PMS has an overpriced oil/water heat exchanger th...   Sep 15 2026, 01:14 PM
Chris914n6   PMS has an overpriced oil/water heat exchanger t...   Sep 15 2026, 03:56 PM
Montreal914   I am currently restoring my 73 and converting it t...   Sep 15 2026, 01:51 PM
Montreal914   If more air flow is required, adding more holes in...   Sep 15 2026, 02:06 PM
Montreal914   ... just noticed the connections to your cooler ar...   Sep 15 2026, 02:16 PM
mepstein   Remember the front cooler is an extra one. You sti...   Sep 15 2026, 02:29 PM
NARP74   I was having some PPI work done before I bought th...   Sep 15 2026, 04:31 PM
Chris914n6   You should have a temp controlled oil cooler bypas...   Sep 15 2026, 10:03 PM
NARP74   You should have a temp controlled oil cooler bypa...   Sep 16 2026, 11:26 AM
- Lo-Fi Version Time is now: 22nd October 2026 - 07:18 PM
