> Auxiliary Headlight Relays, Installing H4's
Artfrombama
post Sep 14 2026, 11:50 AM
Artfrombama
I've decided to install a pair of H4 headlights with a little more power (55w low, 100w hi beam).
Will I need an auxiliary relay in addition to the factory one above the fuse block?
Thanks! (IMG:style_emoticons/default/pray.gif)
Shivers
post Sep 15 2026, 07:17 AM
QUOTE(Artfrombama @ Sep 14 2026, 10:50 AM) *
I'm doing that now. I really do not like adding to the electrical system.
I put in a duel relay and some fused links if I want to add something later, in a box.
I ran a #10 wire run from the battery to the relay box inside. Trigger wire inside
from the switch will draw an amp or two. I put it inside to protect it.
I have a single relay says it is waterproof that goes in the engine compartment for the rear fog light.
- Lo-Fi Version Time is now: 24th November 2026 - 03:24 PM
