> Nose Job, What To Do
NARP74
post Aug 28 2026, 11:52 AM
I have never been a big fan of the nose on the 914 I purchased. I was always 50/50, sometimes I liked it, sometimes I tolerated it. It was on the car and it needed other work so I ignored it mostly. Now I am working on options to see what I can do.
It has a cooler under it, see the pics. Not the correct one though.
Go back to some form of stock?
I like the 916 front end, try to do something like that?
Some hybrid approach?
I don't really want to go down a $10K rabbit hole. I don't really want to cut into the front end and make it a full GT. I may be limiting my options as I think.
Montreal914
post Sep 15 2026, 01:51 PM
I am currently restoring my 73 and converting it to a 3.2 /6 but staying a narrow body.
I find it interesting your temperature is going up even with that large cooler, but maybe the air isn't flowing out properly in the back of it? Ducting helps a lot too. It looks like you initially had a different cooler?
My plan is to have a Mercedes oil cooler inside the front and remove the 5 rubber plugs as mentioned by Mark Epstein. I am not set on the air exit scheme yet, either the two rear floor stock ports (per Mark) or side wents in the wheel wells.
One thing to consider is the semicircular front reinforcement you have on your car. I like to think Porsche didn't add this for no reason and want to keep it there. Luckily my MBZ cooler fits under it, but is it large enough for the 3.2... (IMG:style_emoticons/default/idea.gif)
As for front, I plan on using the stock bumper and a narrow body GT front valence (FG).
Here was my mock up. The spare is a fake Fuch 15" with a small temporary tire.
Here is the front view.
Again, I don't know if this will suffice as auxiliary cooler for my 3.2. I do plan on running aluminum oil lines along the passenger side long. This should help too.
NARP74   Nose Job   Aug 28 2026, 11:52 AM
Cairo94507   It is all up to you. What is the condition of the...   Aug 28 2026, 01:18 PM
mepstein   It is all up to you. What is the condition of th...   Aug 28 2026, 01:36 PM
Shivers   Is that the only modification on the car? Stock bo...   Aug 28 2026, 01:36 PM
NARP74   The rest of the body is in great shape. It was re...   Aug 28 2026, 04:20 PM
mepstein   You can't really see it while you are driving ...   Aug 28 2026, 05:10 PM
Craigers17   This might be a stupid question, but is this a -4 ...   Aug 28 2026, 05:25 PM
Root_Werks   Hard to go wrong with stock. Looks the best to me...   Aug 28 2026, 06:37 PM
NARP74   Didn't know you could run a GT with a cooler a...   Aug 28 2026, 06:46 PM
NARP74   What my car wants to be when it grows up. Thanks ...   Sep 14 2026, 05:14 PM
mepstein   You can mount the cooler behind the front of the c...   Sep 14 2026, 06:29 PM
NARP74   You can mount the cooler behind the front of the ...   Sep 14 2026, 07:25 PM
dtmehall   the big plus is that you can drive it instead of s...   Sep 14 2026, 07:34 PM
NARP74   The big plus is that you can drive it instead of ...   Sep 15 2026, 08:02 AM
Chris914n6   PMS has an overpriced oil/water heat exchanger tha...   Sep 15 2026, 10:51 AM
NARP74   PMS has an overpriced oil/water heat exchanger th...   Sep 15 2026, 01:14 PM
Chris914n6   PMS has an overpriced oil/water heat exchanger t...   Sep 15 2026, 03:56 PM
Montreal914   I am currently restoring my 73 and converting it t...   Sep 15 2026, 01:51 PM
Montreal914   If more air flow is required, adding more holes in...   Sep 15 2026, 02:06 PM
Montreal914   ... just noticed the connections to your cooler ar...   Sep 15 2026, 02:16 PM
mepstein   Remember the front cooler is an extra one. You sti...   Sep 15 2026, 02:29 PM
NARP74   I was having some PPI work done before I bought th...   Sep 15 2026, 04:31 PM
Chris914n6   You should have a temp controlled oil cooler bypas...   Sep 15 2026, 10:03 PM
NARP74   You should have a temp controlled oil cooler bypa...   Sep 16 2026, 11:26 AM
- Lo-Fi Version Time is now: 22nd October 2026 - 07:18 PM
