| NARP74 |
Aug 28 2026, 11:52 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,579 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains |
I have never been a big fan of the nose on the 914 I purchased. I was always 50/50, sometimes I liked it, sometimes I tolerated it. It was on the car and it needed other work so I ignored it mostly. Now I am working on options to see what I can do.
It has a cooler under it, see the pics. Not the correct one though. Go back to some form of stock? I like the 916 front end, try to do something like that? Some hybrid approach? I don't really want to go down a $10K rabbit hole. I don't really want to cut into the front end and make it a full GT. I may be limiting my options as I think. |
| Montreal914 |
Sep 15 2026, 02:16 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,210 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California
... just noticed the connections to your cooler are on the bottom. You may have a lot of air trapped in there. (IMG:style_emoticons/default/idea.gif)
NARP74 Nose Job Aug 28 2026, 11:52 AM
Cairo94507 It is all up to you. What is the condition of the... Aug 28 2026, 01:18 PM
It is all up to you. What is the condition of th... Aug 28 2026, 01:36 PM
Shivers Is that the only modification on the car? Stock bo... Aug 28 2026, 01:36 PM
NARP74 The rest of the body is in great shape. It was re... Aug 28 2026, 04:20 PM
mepstein You can't really see it while you are driving ... Aug 28 2026, 05:10 PM
Craigers17 This might be a stupid question, but is this a -4 ... Aug 28 2026, 05:25 PM
Root_Werks Hard to go wrong with stock. Looks the best to me... Aug 28 2026, 06:37 PM
NARP74 Didn't know you could run a GT with a cooler a... Aug 28 2026, 06:46 PM
NARP74 What my car wants to be when it grows up. Thanks ... Sep 14 2026, 05:14 PM
mepstein You can mount the cooler behind the front of the c... Sep 14 2026, 06:29 PM
NARP74
You can mount the cooler behind the front of the ... Sep 14 2026, 07:25 PM
dtmehall the big plus is that you can drive it instead of s... Sep 14 2026, 07:34 PM
NARP74
The big plus is that you can drive it instead of ... Sep 15 2026, 08:02 AM
Chris914n6 PMS has an overpriced oil/water heat exchanger tha... Sep 15 2026, 10:51 AM
NARP74
PMS has an overpriced oil/water heat exchanger th... Sep 15 2026, 01:14 PM
Chris914n6
PMS has an overpriced oil/water heat exchanger t... Sep 15 2026, 03:56 PM
Montreal914 I am currently restoring my 73 and converting it t... Sep 15 2026, 01:51 PM
Montreal914 If more air flow is required, adding more holes in... Sep 15 2026, 02:06 PM
mepstein Remember the front cooler is an extra one. You sti... Sep 15 2026, 02:29 PM
NARP74 I was having some PPI work done before I bought th... Sep 15 2026, 04:31 PM
Chris914n6 You should have a temp controlled oil cooler bypas... Sep 15 2026, 10:03 PM
NARP74
You should have a temp controlled oil cooler bypa... Sep 16 2026, 11:26 AM![]() ![]() |
Lo-Fi Version | Time is now: 22nd October 2026 - 07:18 PM |
