| nmkimosabe |
Jul 31 2026, 04:18 PM
Member ![]() ![]() Group: Members Posts: 99 Joined: 16-March 25 From: Santa Fe, NM Member No.: 28,660 Region Association: Rocky Mountains |
My 1974 1.8 with fuel injection will only start by manually opening the throttle but I can't get it idle and thus run properly. I recently had the AFM rebuilt and replaced the points, plugs, condenser and replaced the CHT sensor but the problem continues as it did before. I've looked for vacuum leaks to no avail with starter fluid. I now seek the expertise of the members of this forum for additional suggestions.
| Superhawk996 |
Sep 16 2026, 02:57 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,191 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
Lets be clear here. You have no obligation to keep me posted. However, I would like to see you get your issue resolved and get you driving. I understand how frustrating this has to be for you. I also understand how easy it is for mechanics to run up a bill needlessly as well.
My goal is to help and to be helpful to you. Forgive me in advance. I'm going to continue to be blunt. I don't think this mechanic has a clue. Forgive me this post is going to get lengthy. If you are friends with this guy or he's working for free. It's all fine. Keep doing what your doing. Eventually, the car will get fixed. If you are paying this guy shop rate to keep guessing, throwing parts at it, and/or not doing actual logical troubleshooting based on symptoms, testing, and reacting to the test results, you're getting fleeced and I'd like to help prevent that. Why do I say this and why am I so confident in saying it? Lets break this down. When the car has been running then stalls, it is literally a 5-15 minute job to determine whether it is a ignition problem (ie no spark) or a fuel problem. There is zero guess work involved in this. Spark is in one of three states: Not there, weak, or Present (strong and white/blue color). If you have a strong blue/white spark present at the tip of the spark plug -- you immediately know with certainty you have a fuel problem. You have to look at the tip of the plug. Just because a spark plug wire sparks at the top terminal, that doesn't necessarily mean the spark is present at the business end of the plug. If you have a fuel problem that can quickly be broken down to 3 states: No fuel present for whatever reason Lean Mixture that won't light off and combust Rich Mixture that won't light off and combust Each of the three have their own troubleshooting that can be done with zero guesswork. No fuel present is easy to diagnose with a fuel pressure gauge or by pulling an injector and seeing if you have fuel spraying from the injectors when it wont start. Lean - easily confirmed by looking at the spark plugs and by using starting fluid. If its truly lean or not getting any fuel at all, a few brief shots of starting fluid into the intake with get the car coughing or sputtering briefly -- confirming the problem. Rich -- easily confirmed by looking at the spark plugs. Excessively black, sooty, carbon fouled, and/or soaking wet with gasoline will not allow the engine to start. This has its own troubleshooting techniques. Lets break down your list piece by piece: "Since the fuel pump is in the original location on a shelf below the engine it could be a vapor lock. We saw bubbles in the return fuel line which also possibly points to an overheated fuel pump." Bubbles in the return line really aren't indicative of anything particular. The design of the 3 port pump is such that it has a means to self prime if air has gotten into the fuel lines. If it truly is vapor lock -- that is easily checked by looking at fuel pressure on the supply line. This isn't guesswork. Fuel pressure is at spec when it won't start or it isn't. If anything vapor lock will produce a lean condition -- and again starting fluid would quickly confirm this by making the car cough for a few seconds. "We are testing the CHT" The typical failure mode for the CHT is to go open circuit or way too high of a resistance when hot causing an excessive rich condition that won't start but often smells of raw, unburned fuel at the tailpipe. Any competent mechanic would be familiar with this smell. Super quick to check the CHT with a multimeter and zero guesswork is involved. Again, a visual plug check is one way of confirming whether the CHT is forcing a rich or lean condition that is resulting in the no start when hot. Starting fluid test is quick too but depends on which way the mixture is (rich vs. lean) "checking the fuel tank sock" There is almost zero reason to be checking the fuel tank sock unless it is 100% confirmed, beyond any doubt, that the fuel pump is being starved of fuel. This is a bunch of work to drain the tank, pull the sock, and then hope you haven't created leaks or pinched the undertank fuel hose resulting in more problems. Sure if you have zero fuel flow, this would be reasonable. But at this point your mechanic hasn't confirmed anything that would indicate that checking the sock is even relevant. The condition of the sock would have zero correlation to it stalling only when hot. " fuel lines" Again this is basically a binary. You either have fuel flow or you don't. "heater plumbing possibly deflecting air on the fuel pump." Not saying that this wouldn't contribute to vapor lock but until your mechanic actually confirms you have vapor lock and the inability to build fuel pressure after the car has heated and stalled, this is just a waste of time and would be billable hours for him. Correct me if I'm mistaken but at Mid-September the ambient temps in New Mexico are not even all that favorable for vapor lock to even be on the table. "Fuel pump will also be tested under actual driving conditions in case that is the culprit as well." I'm not sure what to say other than after two months of you struggling to solve the issues -- I cannot fathom why the fuel pump and fuel pressure is even a topic of conversation. It is one of the very first things that should have been measured and verified. Cold, Hot, running, and after the engine has stalled and won't restart. So basically, these proposed things to check are all over the map between no fuel, lean, and rich with no confirmation that spark is even present at the business end of the spark plug when the car is in a no-start condition. In order to help you move forward, and to potentially save you from being financially bled by this guy, we need to at least get information about whether you have spark present at the tip of the spark plug when the car won't start. Anything less than that with 100% certainty is just him jerking you around. I may be completely off my rocker and lacking relevant nformation about whether there is spark present during the no-start. If this is the case. Ignore my ranting. (IMG:style_emoticons/default/happy11.gif) |
| wonkipop |
Sep 16 2026, 04:20 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,783 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille
Lets be clear here. You have no obligation to keep me posted. However, I would like to see you get your issue resolved and get you driving. I understand how frustrating this has to be for you. I also understand how easy it is for mechanics to run up a bill needlessly as well. My goal is to help and to be helpful to you. Forgive me in advance. I'm going to continue to be blunt. I don't think this mechanic has a clue. Forgive me this post is going to get lengthy. If you are friends with this guy or he's working for free. It's all fine. Keep doing what your doing. Eventually, the car will get fixed. If you are paying this guy shop rate to keep guessing, throwing parts at it, and/or not doing actual logical troubleshooting based on symptoms, testing, and reacting to the test results, you're getting fleeced and I'd like to help prevent that. Why do I say this and why am I so confident in saying it? Lets break this down. When the car has been running then stalls, it is literally a 5-15 minute job to determine whether it is a ignition problem (ie no spark) or a fuel problem. There is zero guess work involved in this. Spark is in one of three states: Not there, weak, or Present (strong and white/blue color). If you have a strong blue/white spark present at the tip of the spark plug -- you immediately know with certainty you have a fuel problem. You have to look at the tip of the plug. Just because a spark plug wire sparks at the top terminal, that doesn't necessarily mean the spark is present at the business end of the plug. If you have a fuel problem that can quickly be broken down to 3 states: No fuel present for whatever reason Lean Mixture that won't light off and combust Rich Mixture that won't light off and combust Each of the three have their own troubleshooting that can be done with zero guesswork. No fuel present is easy to diagnose with a fuel pressure gauge or by pulling an injector and seeing if you have fuel spraying from the injectors when it wont start. Lean - easily confirmed by looking at the spark plugs and by using starting fluid. If its truly lean or not getting any fuel at all, a few brief shots of starting fluid into the intake with get the car coughing or sputtering briefly -- confirming the problem. Rich -- easily confirmed by looking at the spark plugs. Excessively black, sooty, carbon fouled, and/or soaking wet with gasoline will not allow the engine to start. This has its own troubleshooting techniques. Lets break down your list piece by piece: "Since the fuel pump is in the original location on a shelf below the engine it could be a vapor lock. We saw bubbles in the return fuel line which also possibly points to an overheated fuel pump." Bubbles in the return line really aren't indicative of anything particular. The design of the 3 port pump is such that it has a means to self prime if air has gotten into the fuel lines. If it truly is vapor lock -- that is easily checked by looking at fuel pressure on the supply line. This isn't guesswork. Fuel pressure is at spec when it won't start or it isn't. If anything vapor lock will produce a lean condition -- and again starting fluid would quickly confirm this by making the car cough for a few seconds. "We are testing the CHT" The typical failure mode for the CHT is to go open circuit or way too high of a resistance when hot causing an excessive rich condition that won't start but often smells of raw, unburned fuel at the tailpipe. Any competent mechanic would be familiar with this smell. Super quick to check the CHT with a multimeter and zero guesswork is involved. Again, a visual plug check is one way of confirming whether the CHT is forcing a rich or lean condition that is resulting in the no start when hot. Starting fluid test is quick too but depends on which way the mixture is (rich vs. lean) "checking the fuel tank sock" There is almost zero reason to be checking the fuel tank sock unless it is 100% confirmed, beyond any doubt, that the fuel pump is being starved of fuel. This is a bunch of work to drain the tank, pull the sock, and then hope you haven't created leaks or pinched the undertank fuel hose resulting in more problems. Sure if you have zero fuel flow, this would be reasonable. But at this point your mechanic hasn't confirmed anything that would indicate that checking the sock is even relevant. The condition of the sock would have zero correlation to it stalling only when hot. " fuel lines" Again this is basically a binary. You either have fuel flow or you don't. "heater plumbing possibly deflecting air on the fuel pump." Not saying that this wouldn't contribute to vapor lock but until your mechanic actually confirms you have vapor lock and the inability to build fuel pressure after the car has heated and stalled, this is just a waste of time and would be billable hours for him. Correct me if I'm mistaken but at Mid-September the ambient temps in New Mexico are not even all that favorable for vapor lock to even be on the table. "Fuel pump will also be tested under actual driving conditions in case that is the culprit as well." I'm not sure what to say other than after two months of you struggling to solve the issues -- I cannot fathom why the fuel pump and fuel pressure is even a topic of conversation. It is one of the very first things that should have been measured and verified. Cold, Hot, running, and after the engine has stalled and won't restart. So basically, these proposed things to check are all over the map between no fuel, lean, and rich with no confirmation that spark is even present at the business end of the spark plug when the car is in a no-start condition. In order to help you move forward, and to potentially save you from being financially bled by this guy, we need to at least get information about whether you have spark present at the tip of the spark plug when the car won't start. Anything less than that with 100% certainty is just him jerking you around. I may be completely off my rocker and lacking relevant nformation about whether there is spark present during the no-start. If this is the case. Ignore my ranting. (IMG:style_emoticons/default/happy11.gif) i think he is on his third mechanic @Superhawk996 . the first one sounded hopeless. the guy on the car now sounds a lot more careful and methodical. has definitely made progress. some of the other suggestions have come from outside sources. ie the flat camshaft one. a complete furphy. i don't think any of the mechanics were involved in that suggestion. anyways - it can be frustrating and persistence and patience is required. they are beautifully sweet little engines the L jet 1.8s. but everything is getting old now - including the mechanics who have familiarity with them and of course the time and patience to persist. a lot of costs and pressures on anyone in any trade or business these days - dunno what its like in the USA at the moment but the economy has gone to hell down here which puts extra pressure on regular mechanics running their shops and businesses. but it definitely sounds like progress in being made with the guy he has the car with now. down here if you find a good mechanic you stick to them like glue. a disappearing species? |
nmkimosabe Starting Problems Jul 31 2026, 04:18 PM
rfinegan get a smoker from amazon, cheep and multi purpose.... Jul 31 2026, 04:23 PM
nmkimosabe
get a smoker from amazon, cheep and multi purpose... Aug 1 2026, 11:51 AM
fiacra I'm going to add a few more things I know abou... Aug 1 2026, 01:32 PM
fiacra :popcorn: Aug 6 2026, 10:29 AM
rfinegan It is running now with new ignition parts and base... Aug 6 2026, 11:10 AM
nmkimosabe
It is running now with new ignition parts and bas... Aug 10 2026, 12:03 PM
TRP Congratulations on getting it to start and idle. T... Aug 10 2026, 03:30 PM
nmkimosabe
Congratulations on getting it to start and idle. ... Aug 10 2026, 09:20 PM
TRP
Congratulations on getting it to start and idle.... Aug 10 2026, 11:36 PM
wonkipop
Congratulations on getting it to start and idle.... Aug 11 2026, 05:07 AM
nmkimosabe
[quote name='nmkimosabe' post='3268296' date='Aug... Aug 11 2026, 08:54 AM
wonkipop
[quote name='nmkimosabe' post='3268296' date='Au... Aug 11 2026, 06:01 PM
nmkimosabe
[quote name='nmkimosabe' post='3268355' date='Aug... Aug 24 2026, 02:23 PM
Artfrombama I too have a 74 1.8 with FI
I was having a similar... Aug 24 2026, 02:51 PM
wonkipop
Congratulations on getting it to start and idle. ... Aug 11 2026, 05:25 AM
nmkimosabe Thanks for the advice and I will double check that... Aug 26 2026, 09:32 AM
Superhawk996 Find a new mechanic that actually understands thes... Aug 26 2026, 12:56 PM
wonkipop
Find a new mechanic that actually understands the... Aug 26 2026, 03:19 PM
wonkipop as i recall @nmkimosabe - you sent me a PM telli... Aug 26 2026, 03:47 PM
nmkimosabe I will try to clarify the status and progress to d... Aug 27 2026, 06:13 PM
Superhawk996 Given you had a worn distributor is there a reason... Aug 27 2026, 07:08 PM
nmkimosabe
Given you had a worn distributor is there a reaso... Aug 28 2026, 04:26 PM
wonkipop
Given you had a worn distributor is there a reas... Aug 29 2026, 05:06 AM
nmkimosabe
[quote name='nmkimosabe' post='3269962' date='Aug... Aug 29 2026, 12:02 PM
wonkipop
[quote name='wonkipop' post='3270009... Aug 29 2026, 02:07 PM
fiacra I can't believe this saga took yet another tur... Aug 27 2026, 09:01 PM
nmkimosabe
I can't believe this saga took yet another tu... Aug 28 2026, 04:27 PM
fiacra It's funny how things always seem to circle ba... Aug 29 2026, 07:54 AM
nmkimosabe
It's funny how things always seem to circle b... Aug 29 2026, 12:06 PM
nmkimosabe It was suggested to me today by a person with seve... Sep 5 2026, 05:34 PM
wonkipop
It was suggested to me today by a person with sev... Sep 6 2026, 07:49 PM
nmkimosabe
[quote name='nmkimosabe' post='3270852' date='Sep... Sep 7 2026, 03:37 PM
wonkipop
[quote name='nmkimosabe' post='3270852' date='Se... Sep 7 2026, 05:09 PM
nmkimosabe
[quote name='nmkimosabe' post='3271003' date='Sep... Sep 8 2026, 12:35 PM
Superhawk996 Not likely.
Can be measured if you really wanted... Sep 5 2026, 08:41 PM
nmkimosabe
Not likely.
Can be measured if you really wante... Sep 6 2026, 05:19 PM
wonkipop @nmkimosabe
situation re servicing /parts etc fo... Sep 8 2026, 01:00 PM
nmkimosabe
@[url=http://www.914world.com/bbs2/index.php?show... Sep 9 2026, 11:03 AM
re 87 alfa romeo spider. thats a co... Sep 9 2026, 01:12 PM
nmkimosabe
@[url=http://www.914world.com/bbs2/index.php?show... Sep 9 2026, 04:16 PM
some other tips for you re your 1.8 ... Sep 9 2026, 01:28 PM
nmkimosabe
[b]@[url=http://www.914world.com/bbs2/index.php?s... Sep 15 2026, 04:37 PM
Superhawk996 Here is the curve for CHT sensor - you will have a... Sep 15 2026, 07:28 PM
nmkimosabe
Here is the curve for CHT sensor - you will have ... Sep 16 2026, 12:22 PM
wonkipop
[quote name='Superhawk996' post='3271990' date='S... Sep 16 2026, 03:00 PM
wonkipop i should add the symptoms are also fitting a fuel ... Sep 16 2026, 03:20 PM
wonkipop re vapor lock as an issue.
i live in a real hot p... Sep 16 2026, 03:38 PM
wonkipop ps
the fuel pressure figures you are looking for ... Sep 16 2026, 04:08 PM
Superhawk996 @wonkipop
The state of the repair industry is :... Sep 16 2026, 05:03 PM
nmkimosabe
@[url=http://www.914world.com/bbs2/index.php?show... Sep 17 2026, 06:53 PM
wonkipop yeah.
right on @Superhawk996 .
mike in here ju... Sep 17 2026, 02:49 AM
Superhawk996 I apologize if I’m coming off a bit harsh. My e... Sep 17 2026, 08:42 PM
nmkimosabe
I apologize if I’m coming off a bit harsh. My ... Sep 18 2026, 01:04 PM
fiacra Some great advice from @Superhawk996 and [b]@[u... Sep 20 2026, 12:37 PM
wonkipop
Some great advice from [b]@[url=http://www.914wo... Sep 20 2026, 02:18 PM
nmkimosabe
Some great advice from [b]@[url=http://www.914w... Sep 23 2026, 04:12 PM
Superhawk996 I don’t have a OEM 3 port pump on-site to measur... Sep 23 2026, 07:41 PM
nmkimosabe
I don’t have a OEM 3 port pump on-site to measu... Sep 24 2026, 11:11 AM
wonkipop
[quote name='wonkipop' post='3272527' date='Sep 2... Sep 24 2026, 05:04 AM
nmkimosabe
[quote name='wonkipop' post='3272527' date='Sep ... Sep 24 2026, 01:00 PM
nmkimosabe
[quote name='wonkipop' post='3272934' date='Sep 2... Sep 26 2026, 04:43 PM
Superhawk996 Give me a day or so and I’ll dig a 3 port fuel p... Sep 26 2026, 05:13 PM
nmkimosabe
Give me a day or so and I’ll dig a 3 port fuel ... Sep 26 2026, 07:09 PM
Superhawk996
Give me a day or so and I’ll dig a 3 port fuel... Sep 26 2026, 08:20 PM
nmkimosabe
[quote name='nmkimosabe' post='3273240' date='Sep... Sep 26 2026, 08:35 PM
wonkipop yeah that is interesting about the fuel pump in th... Sep 26 2026, 05:36 PM
nmkimosabe
yeah that is interesting about the fuel pump in t... Sep 26 2026, 07:06 PM
wonkipop
yeah that is interesting about the fuel pump in ... Sep 27 2026, 02:20 AM
nmkimosabe
[quote name='nmkimosabe' post='3273239' date='Sep... Sep 27 2026, 10:29 AM
wonkipop
[quote name='nmkimosabe' post='3273239' date='Se... Sep 27 2026, 01:20 PM
nmkimosabe
[quote name='nmkimosabe' post='3273326' date='Sep... Sep 27 2026, 01:46 PM
wonkipop
[quote name='nmkimosabe' post='3273326' date='Se... Sep 27 2026, 03:07 PM
nmkimosabe
[quote name='nmkimosabe' post='3273339' date='Sep... Sep 27 2026, 04:03 PM
wonkipop
[quote name='nmkimosabe' post='3273339' date='Se... Sep 27 2026, 04:30 PM
nmkimosabe
[quote name='nmkimosabe' post='3273356' date='Sep... Sep 27 2026, 04:57 PM
Superhawk996 Sorry for sloppy test setup.
Here are the curren... Sep 27 2026, 06:48 PM
nmkimosabe
Here are the curre... Sep 28 2026, 11:39 AM
Superhawk996
Impressive....as they say "a picture is wor... Sep 28 2026, 01:28 PM
wonkipop i pretty much agree with @Superhawk996 .
the co... Sep 28 2026, 02:35 PM
Superhawk996 Good point on the fuel lines - sometimes I assume ... Sep 28 2026, 06:47 PM
wonkipop
Good point on the fuel lines - sometimes I assume... Sep 28 2026, 07:15 PM
wonkipop double post for some reason, deleted, Sep 28 2026, 07:15 PM
nmkimosabe @[url=http://www.914world.com/bbs2/index.php?showu... Oct 4 2026, 07:48 PM
fiacra What a journey to get here. I'm glad you pers... Oct 4 2026, 08:31 PM
Superhawk996 :trophy: enjoy :driving: Oct 5 2026, 01:59 AM
nmkimosabe
Thanks again for you... Oct 5 2026, 08:39 AM
wonkipop top stuff
nothing like being in the hands of a me... Oct 5 2026, 05:25 AM
nmkimosabe
top stuff
nothing like being in the hands of a m... Oct 5 2026, 08:23 AM
Superhawk996
Of course, it was a rather expensive education.
... Oct 5 2026, 09:40 AM
nmkimosabe
... Oct 5 2026, 09:45 AM
wonkipop
top stuff
nothing like being in the hands of a ... Oct 5 2026, 04:30 PM
Superhawk996 Out of curiosity - did your mechanic keep the CHT ... Oct 5 2026, 11:39 AM
nmkimosabe
Out of curiosity - did your mechanic keep the CHT... Oct 5 2026, 02:46 PM
Superhawk996
Out of curiosity - did your mechanic keep the CH... Oct 5 2026, 03:10 PM
nmkimosabe
[quote name='nmkimosabe' post='3274235' date='Oct... Oct 5 2026, 03:30 PM
wonkipop
[quote name='nmkimosabe' post='3274235' date='Oct... Oct 6 2026, 01:29 AM
nmkimosabe
[quote name='nmkimosabe' post='3274235' date='Oc... Oct 6 2026, 10:50 AM![]() ![]() |
Lo-Fi Version | Time is now: 24th November 2026 - 09:17 PM |
