> Bridgestone RE71 rz
jmargush
post Sep 16 2026, 02:31 PM
I upgraded to RE71rz for autoxv this year.
I am super impressed with these other than I am wearing the outside edge with almost no wear on the inside.
Tangerine camber boxes are installed camber maxed out and cater naxed or at around 4.75 degrees.
Anyone else experiencing this or more importantly have a solution.
jmargush
post Sep 18 2026, 03:14 PM
Camber is -2 degrees
Car is not pushing
stownsen914
post Sep 19 2026, 06:40 AM
2 degrees isn't too bad. The other possibility is too much toe in - that can cause wear like that at the outer edge.
Is it a dual use car? One of the challenges with a dual use car is figuring out whether uneven wear is from hard use like autocross/track vs. accelerated wear from street use. Especially with soft track tires, and also because autrocross/track alignment setups can increase tire wear for street driving.
A couple other thoughts:
How's your toe set? Toe in can cause increased wear at the outer edges of tires.
To optimize your camber, one option is to take tire temps after autocross runs (or track sessions) and look for even temps.
- Lo-Fi Version Time is now: 4th October 2026 - 11:38 PM
