> Six convertion gearbox
DavidSweden
post Sep 19 2026, 01:16 PM
Hello,
I’ve just rebuilt a 1971 2.2T engine, with the intention of installing it in my 914.
As I understand it, it should be possible to mate the existing side-shift gearbox to the 2.2T engine by using an early flywheel, while retaining the existing 914 clutch.
Is this correct?
Thanks in advance
Retroracer
post Sep 19 2026, 04:42 PM
Yes, that is the exact combination I have in my car. I recall that I used the 914 pressure plate and clutch, but I'd have to check.
BTW - Don't neglect the main shaft support bearing and washer that sits in the flywheel / crank area - suggest renew that and the clutch throwout bearing at the same time. Also the (nylon?) pivot bushing, as these crumble over time.
- Tony
porschetub
post Sep 19 2026, 05:21 PM
QUOTE(Retroracer @ Sep 20 2026, 10:42 AM) *
- Tony
(IMG:style_emoticons/default/agree.gif) any wear parts as Tony mentioned above ,I would add input shaft seal also ,mine was dry but leaked not long after I had been driving it for a while .
I think its worth so you don't have my issue and learn from it (IMG:style_emoticons/default/chair.gif) .
Cheers.
- Lo-Fi Version Time is now: 19th September 2026 - 06:42 PM
