> Camshaft sealing plug R&R?, thought I had a rear main seal leak....
scott_in_nh
post Sep 21 2026, 08:18 AM
I've owned my 914 for 15 years and close to 40k miles now and never had the engine out! But I haven't used it much in the last 5 for several reasons.
The biggest is it shifts poorly, and it was dripping both motor oil and gear oil out of the bellhousing. I also had never done a deep dive for rust, but some holes that appeared where the floor and long meet under the driver's seat have convinced me now is the time (I'm 66 yo and afraid it will get "stuck" on the jack stands rather than being driven).
So far, the chassis is really very solid, but there will be more revelations and questions about that to come.
I dropped the entire drivetrain and separated the motor and trans thinking I had a rear main seal leak, but instead it turned out to be the camshaft sealing plug.
I found a lot of directions for pulling, tapping the rest of the oil gallery plugs (which I will not be doing), but no specific mentions of this larger plug.
Is it the same drill a hole, put a screw in and pull it out, followed by gluing a new one in?
Thanks in advance - more questions to follow
Scott
ejm
post Sep 21 2026, 08:23 AM
I can see the light at the end of the tunnel
You need to split the case to replace that.
Jamie
post Sep 21 2026, 08:28 AM
QUOTE(ejm @ Sep 21 2026, 06:23 AM) *
Looks like Hans didn't seat that one well, you might be able and lucky to hammer it in a bit further because its not square in the hole, but I'm no expert? (IMG:style_emoticons/default/confused24.gif)
Superhawk996
post Sep 21 2026, 09:13 AM
QUOTE(Jamie @ Sep 21 2026, 10:28 AM) *
No, no, and no (IMG:style_emoticons/default/sheeplove.gif)’in way.
Do not hammer that.
Previous post was correct - have to split the case to repair / replace properly.
44 User(s) are reading this topic (41 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 21st September 2026 - 11:34 AM
