| gulf908 |
Sep 21 2026, 08:13 PM
Member ![]() ![]() Group: Members Posts: 132 Joined: 25-December 13 From: Sydney Member No.: 16,795 Region Association: Australia and New Zealand |
wtb - an oil pipe connector/fitting in alloy for my '70 914-6 as pictured
I believe the similar 911 parts are not alloy marks on connector are - OL NW16 3/70 - gepr 60 26 mm TIA Dennis Attached thumbnail(s) |
| Luke M |
Sep 21 2026, 08:26 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,602 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States
There's a guy over on n pelican that made me some fittings for my 6 oil system.
I purchased a few 26 mm fitting just like you posted. Must be the return to tank line one that you need. I'll pm you some info in the morning. |
| gulf908 |
Sep 21 2026, 09:53 PM
thx Luke
any contacts appreciated I believe its the centre oil line cheers Dennis There's a guy over on n pelican that made me some fittings for my 6 oil system. I purchased a few 26 mm fitting just like you posted. Must be the return to tank line one that you need. I'll pm you some info in the morning. Attached thumbnail(s) |
| Luke M |
Sep 22 2026, 05:52 AM
thx Luke any contacts appreciated I believe its the centre oil line cheers Dennis There's a guy over on n pelican that made me some fittings for my 6 oil system. I purchased a few 26 mm fitting just like you posted. Must be the return to tank line one that you need. I'll pm you some info in the morning. Hi Dennis, The center line is the line that comes off the oil tank feed to the engine. It attaches to the lower hose in the pic then onto the oil cooler. By the looks of it you need the return line that mounts on the steel return line then to tank return port. The only 26 mm fittings used on the 914-6 is for the oil return line. I sent you a pm with the contact info for the fittings. |
Lo-Fi Version | Time is now: 22nd September 2026 - 12:08 PM |
