| Shivers |
Sep 22 2026, 11:36 AM
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,600 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
This is the front suspension from my 72 that I am putting in Howard. This one is straight, I do not have another. The adjuster cap on one side fell off as soon as I removed the adjuster bolt. The other side is holding it position like it's from Texas.
And the arm I could get off the torsion bar is stuck fast. I need to get the bars out without harming the splines or heating it up so much it takes the spring out of the bars. I'm sure this is semi common so I'd sure appreciate hearing how you managed to get yours loose. So would Howard. (IMG:style_emoticons/default/biggrin.gif) Thanks ![]() ![]() ![]() |
| Shivers |
Sep 22 2026, 01:09 PM
Gaaads. Well I’m shaking it boss, but that plug is not wanting to play fair. I concaved it with a ball peen which gave me gaps then tried to rotate the cap with a punch. No love. What am I missing?
Attached thumbnail(s) |
| Patrick_139 |
Sep 22 2026, 01:28 PM
Newbie ![]() Group: Members Posts: 29 Joined: 2-March 24 From: Claremont Member No.: 27,975 Region Association: Southern California |
Since you won't be reusing that plug, I would suggest inserting a screw into it and using that for leverage to pull the cap off. Or drill a hole in the plug and then use a screwdriver to pry it out. It's a $5 part.
Shivers Suspension disassembly dilemma. Sep 22 2026, 11:36 AM
Cfletch The back side has a plug of sorts that can be remo... Sep 22 2026, 11:58 AM
Shivers I got the adjuster cap off. But the bars are still... Sep 22 2026, 12:12 PM
Shivers When you say back side, that would be this adjuste... Sep 22 2026, 12:18 PM
914werke The back (front) side has a (welch) plug of sorts... Sep 22 2026, 12:25 PM
Shivers
[quote name='Cfletch' post='3272736' date='Sep 22... Sep 22 2026, 12:36 PM
Shivers There is one nagging question that came up as I wa... Sep 22 2026, 01:13 PM
Patrick_139
There is one nagging question that came up as I w... Sep 22 2026, 01:32 PM
Shivers I got them Sep 22 2026, 02:42 PM
Shivers Well hahaha, I ended up grabbing my brass mallet a... Sep 22 2026, 02:45 PM
Superhawk996 :rockin: Sep 22 2026, 04:59 PM
SirAndy When in doubt, BFH ...
:smash: Sep 22 2026, 07:01 PM![]() ![]() |
Lo-Fi Version | Time is now: 22nd September 2026 - 07:06 PM |
