| Superhawk996 |
Sep 24 2026, 10:10 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,084 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
Food for thought.
Split ring lock washers were abandoned by the auto industry as well as aviation long ago and for good reason. They are worse than useless. (IMG:style_emoticons/default/stirthepot.gif) It is well documented that they don’t provide any locking function. I say worse than useless because one of their failure modes is cracking. When this happens the joint loosens, the remnants of the cracked lock washer fall out, and now you have a loose joint. Here’s a few I found recently that had been cracked and were on the verge of falling out. You will also notice that even the ones that aren’t cracked are flattened and have lost any spring effect. ![]() The inability of a split ring lock washer to provide any locking is documented in NASA literature. ![]() https://ntrs.nasa.gov/citations/19900009424 As well as Naval Ships Technical Manual Chpt. 75 that recommends other solutions. ![]() https://maritime.org/doc/nstm/ch075.pdf |
| Root_Werks |
Sep 24 2026, 05:35 PM
Village Idiot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,061 Joined: 25-May 04 From: About 15NM from Canada Member No.: 2,105 Region Association: Pacific Northwest
I've used star washers before and like them. Mostly using the wavy washers. Those junk as well?
Superhawk996 Are you still using “lock washers”? Sep 24 2026, 10:10 AM
Retroracer Interesting data - thx for sharing
- Tony Sep 24 2026, 11:30 AM
NARP74 I can say those are not my go to for anything anym... Sep 24 2026, 12:00 PM
flxzcat I hate washers that damage the base metal. Sep 24 2026, 12:08 PM
Root_Werks That's really good info, thanks! Sep 24 2026, 12:32 PM
bdstone914 @Superhawk996
I use star washers. Sep 24 2026, 01:00 PM
Superhawk996
[b]@[url=http://www.914world.com/bbs2/index.php?s... Sep 24 2026, 02:18 PM
Superhawk996 Tried to find a good description of the Junker Tes... Sep 24 2026, 02:41 PM
914Sixer My work around is WIZ (serrated)nuts and bolts. N... Sep 24 2026, 04:24 PM
930cabman Thank you Phil, very cool having an automotive eng... Sep 24 2026, 04:45 PM![]() ![]() |
Lo-Fi Version | Time is now: 24th September 2026 - 06:05 PM |
