> Clutch pedal adjustment thing on the pedal set., What is the threaded rod for ?
nivekdodge
post Sep 24 2026, 07:12 PM
One of the first things I remember when i started working on the first one was looking at the clutch pedal and saying to myself, " I'll probably learn why that rod is threaded like that." So clue me in
Kevin
Shivers
post Sep 24 2026, 08:00 PM
QUOTE(nivekdodge @ Sep 24 2026, 06:12 PM) *
Kevin
This sounds reasonable:
"Kinematic Engineering & "Over-Center" Action: The 914 pedal cluster utilizes a heavy assist spring. The clutch needs to be precisely dialed in so that the spring passes an "over-center" point during the first third of its travel. This reduces the physical foot effort required to hold the pedal down. A fixed cast pedal wouldn't allow the precision needed to align the pedal perfectly with this mechanical sweet spot."
bdstone914
post Sep 24 2026, 09:04 PM
bdstone914
QUOTE(Shivers @ Sep 24 2026, 07:00 PM) *
Kevin
Sounds like bad Ai.
The clutch spring is very weak and provides almost no assist. The spring takes up the slack in the cable. It only takes 5-10 pounds of pressure to depress the pedal with a stock pressure plate. The threaded end of the clutch pedal allows for a small amount of height adjustment. The clutch does need to be properly adjusted to minimize the pressure to depress it.
7 User(s) are reading this topic (5 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 24th September 2026 - 09:56 PM
