| bajafreaks |
Sep 26 2026, 02:14 PM
Member ![]() ![]() Group: Members Posts: 166 Joined: 7-February 14 From: Gardnerville, Nevada Member No.: 16,969 Region Association: Northern California |
I'm in the process of installing new a arm bushings and curious about the angle degree requirement. Ian Karr says 21 degrees, I did mark my brackets before taking the old bushings out (a arm assembly out of the car) and the original angle of the brackets are greater than 21 degrees, closer to 40+/- which is a pretty big difference. So when installing new bushings etc. should I go with the 21 or the original number?
I'm also installing new torsion bars stock size, anything I need to know besides just sliding them in, keeping left and right as needed? Thanks |
| Superhawk996 |
Sep 26 2026, 03:55 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,090 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
Set at 21 degrees. Originals are worn and slipping.
The angle is established to be near curb height. If you set at original 40 or so you’ll have a ton of preload in the bushing at curb height. Not good for bushing durability and will cause a harsh ride. |
| bajafreaks |
Sep 26 2026, 05:15 PM
Set at 21 degrees. Originals are worn and slipping. The angle is established to be near curb height. If you set at original 40 or so you’ll have a ton of preload in the bushing at curb height. Not good for bushing durability and will cause a harsh ride. Thats what I assumed, the bushing were really bad. I'll go with the 21 degrees. Thanks, sounds like if I'm off a degree or two its okay, I'm using an app on my phone so... |
bajafreaks Indexing A arms Sep 26 2026, 02:14 PM
I'm in the process of installing new a arm bu... Sep 26 2026, 02:41 PM
Shivers
I'm in the process of installing new a arm bu... Sep 26 2026, 04:21 PM
Superhawk996 @shivers
Raising the spindle lowers the car but... Sep 26 2026, 05:18 PM![]() ![]() |
Lo-Fi Version | Time is now: 26th September 2026 - 06:22 PM |
