| nmkimosabe |
Jul 31 2026, 04:18 PM
Member ![]() ![]() Group: Members Posts: 99 Joined: 16-March 25 From: Santa Fe, NM Member No.: 28,660 Region Association: Rocky Mountains |
My 1974 1.8 with fuel injection will only start by manually opening the throttle but I can't get it idle and thus run properly. I recently had the AFM rebuilt and replaced the points, plugs, condenser and replaced the CHT sensor but the problem continues as it did before. I've looked for vacuum leaks to no avail with starter fluid. I now seek the expertise of the members of this forum for additional suggestions.
| wonkipop |
Sep 26 2026, 05:36 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,783 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille
yeah that is interesting about the fuel pump in the 1.8 having no fuse.
pretty sure that is the case and can remember thinking about this 5 pr 6 years ago when it came to my own car. back then i was getting my head around all the ways an L jet was different from a D jet and sifting through the factory manuals trying to nail down all the pages etc relevant to the L jet. did not ever resolve that thought back then and forgot about it. might return to that one myself and dig in again on the question of a fuse. nice bit of reminder to do info! sounds like your mechanic might have nailed it down. curious about the fuel pump. i know that if you tighten down the pump head plate too much (ie the plate the encases the roller cell part at the top of the pump - or bottom whichever way you want to orientate it) then the pump will stall or bind. i know that one from rebuilding mine. you got to tighten down those 4 screws carefully and slowly and test the pump to make sure she spins up nice and free but does not leak at the same time. i wonder if the inside of the roller cell portion got a bit of corrosion in it or foreign material and is binding enough to make the pump really labour and draw that excess current? very interesting diagnosis. top stuff. (IMG:style_emoticons/default/beerchug.gif) |
| nmkimosabe |
Sep 26 2026, 07:06 PM
yeah that is interesting about the fuel pump in the 1.8 having no fuse. pretty sure that is the case and can remember thinking about this 5 pr 6 years ago when it came to my own car. back then i was getting my head around all the ways an L jet was different from a D jet and sifting through the factory manuals trying to nail down all the pages etc relevant to the L jet. did not ever resolve that thought back then and forgot about it. might return to that one myself and dig in again on the question of a fuse. nice bit of reminder to do info! sounds like your mechanic might have nailed it down. curious about the fuel pump. i know that if you tighten down the pump head plate too much (ie the plate the encases the roller cell part at the top of the pump - or bottom whichever way you want to orientate it) then the pump will stall or bind. i know that one from rebuilding mine. you got to tighten down those 4 screws carefully and slowly and test the pump to make sure she spins up nice and free but does not leak at the same time. i wonder if the inside of the roller cell portion got a bit of corrosion in it or foreign material and is binding enough to make the pump really labour and draw that excess current? very interesting diagnosis. top stuff. (IMG:style_emoticons/default/beerchug.gif) Good info about the fuel pump and I will pass that on. Not sure about the fuse but in the video, you sent me I know the D-jet has a relay in the relay board unlike the L-jet. I ordered a fuel pump and a Porsche branded CHT sensor. Stay tuned and thanks again. |
| wonkipop |
Sep 27 2026, 02:20 AM
yeah that is interesting about the fuel pump in the 1.8 having no fuse. pretty sure that is the case and can remember thinking about this 5 pr 6 years ago when it came to my own car. back then i was getting my head around all the ways an L jet was different from a D jet and sifting through the factory manuals trying to nail down all the pages etc relevant to the L jet. did not ever resolve that thought back then and forgot about it. might return to that one myself and dig in again on the question of a fuse. nice bit of reminder to do info! sounds like your mechanic might have nailed it down. curious about the fuel pump. i know that if you tighten down the pump head plate too much (ie the plate the encases the roller cell part at the top of the pump - or bottom whichever way you want to orientate it) then the pump will stall or bind. i know that one from rebuilding mine. you got to tighten down those 4 screws carefully and slowly and test the pump to make sure she spins up nice and free but does not leak at the same time. i wonder if the inside of the roller cell portion got a bit of corrosion in it or foreign material and is binding enough to make the pump really labour and draw that excess current? very interesting diagnosis. top stuff. (IMG:style_emoticons/default/beerchug.gif) Good info about the fuel pump and I will pass that on. Not sure about the fuse but in the video, you sent me I know the D-jet has a relay in the relay board unlike the L-jet. I ordered a fuel pump and a Porsche branded CHT sensor. Stay tuned and thanks again. on the basis of your mechanic's report you ought to buy yourself some glue and adhere yourself to his services. (IMG:style_emoticons/default/beerchug.gif) i do believe he is methodical in the best way. (IMG:style_emoticons/default/beerchug.gif) i mean i am half way around the planet inhabiting "the a hole of the world" as ava gardner once described my city in the most poetic terms but even from this distance he sounds like the real deal. |
| nmkimosabe |
Sep 27 2026, 10:29 AM
yeah that is interesting about the fuel pump in the 1.8 having no fuse. pretty sure that is the case and can remember thinking about this 5 pr 6 years ago when it came to my own car. back then i was getting my head around all the ways an L jet was different from a D jet and sifting through the factory manuals trying to nail down all the pages etc relevant to the L jet. did not ever resolve that thought back then and forgot about it. might return to that one myself and dig in again on the question of a fuse. nice bit of reminder to do info! sounds like your mechanic might have nailed it down. curious about the fuel pump. i know that if you tighten down the pump head plate too much (ie the plate the encases the roller cell part at the top of the pump - or bottom whichever way you want to orientate it) then the pump will stall or bind. i know that one from rebuilding mine. you got to tighten down those 4 screws carefully and slowly and test the pump to make sure she spins up nice and free but does not leak at the same time. i wonder if the inside of the roller cell portion got a bit of corrosion in it or foreign material and is binding enough to make the pump really labour and draw that excess current? very interesting diagnosis. top stuff. (IMG:style_emoticons/default/beerchug.gif) Good info about the fuel pump and I will pass that on. Not sure about the fuse but in the video, you sent me I know the D-jet has a relay in the relay board unlike the L-jet. I ordered a fuel pump and a Porsche branded CHT sensor. Stay tuned and thanks again. on the basis of your mechanic's report you ought to buy yourself some glue and adhere yourself to his services. (IMG:style_emoticons/default/beerchug.gif) i do believe he is methodical in the best way. (IMG:style_emoticons/default/beerchug.gif) i mean i am half way around the planet inhabiting "the a hole of the world" as ava gardner once described my city in the most poetic terms but even from this distance he sounds like the real deal. That's pretty funny as his repair shop is called "Meticulous Motors". Sometimes I get a little frustrated because he's so analytical but it's a good thing. |
| wonkipop |
Sep 27 2026, 01:20 PM
yeah that is interesting about the fuel pump in the 1.8 having no fuse. pretty sure that is the case and can remember thinking about this 5 pr 6 years ago when it came to my own car. back then i was getting my head around all the ways an L jet was different from a D jet and sifting through the factory manuals trying to nail down all the pages etc relevant to the L jet. did not ever resolve that thought back then and forgot about it. might return to that one myself and dig in again on the question of a fuse. nice bit of reminder to do info! sounds like your mechanic might have nailed it down. curious about the fuel pump. i know that if you tighten down the pump head plate too much (ie the plate the encases the roller cell part at the top of the pump - or bottom whichever way you want to orientate it) then the pump will stall or bind. i know that one from rebuilding mine. you got to tighten down those 4 screws carefully and slowly and test the pump to make sure she spins up nice and free but does not leak at the same time. i wonder if the inside of the roller cell portion got a bit of corrosion in it or foreign material and is binding enough to make the pump really labour and draw that excess current? very interesting diagnosis. top stuff. (IMG:style_emoticons/default/beerchug.gif) Good info about the fuel pump and I will pass that on. Not sure about the fuse but in the video, you sent me I know the D-jet has a relay in the relay board unlike the L-jet. I ordered a fuel pump and a Porsche branded CHT sensor. Stay tuned and thanks again. on the basis of your mechanic's report you ought to buy yourself some glue and adhere yourself to his services. (IMG:style_emoticons/default/beerchug.gif) i do believe he is methodical in the best way. (IMG:style_emoticons/default/beerchug.gif) i mean i am half way around the planet inhabiting "the a hole of the world" as ava gardner once described my city in the most poetic terms but even from this distance he sounds like the real deal. That's pretty funny as his repair shop is called "Meticulous Motors". Sometimes I get a little frustrated because he's so analytical but it's a good thing. yes. anyway there are a few things that could be causing that fuel pump high amp draw. could be internal to the pump. don't think brushes or commutator - once they wear down its usually a simple no go. but possibly bearings on shaft finally worn out. might be some metal debris inside the pump and though its still spinning its getting harder to make itself spin up. those old 3 ports are built like tiger tanks internally but eventually i suppose there is end of life. and as i mentioned its possible that the roller cell head on the pump has become clogged in some way. more than likely that debris has made it past the filter. or the other possibility is a restriction. due either to clogged filter. internally collapsed fuel line somewhere on the line from tank to pump. or in the tank itself. at the pickup and sock. the flow delivery test on the pump can sometimes show this up. i think the flow test will certainly show up an internal problem to the pump if its there. might not show up a blockage issue as these often set in after a few minutes of running the car. |
| nmkimosabe |
Sep 27 2026, 01:46 PM
yeah that is interesting about the fuel pump in the 1.8 having no fuse. pretty sure that is the case and can remember thinking about this 5 pr 6 years ago when it came to my own car. back then i was getting my head around all the ways an L jet was different from a D jet and sifting through the factory manuals trying to nail down all the pages etc relevant to the L jet. did not ever resolve that thought back then and forgot about it. might return to that one myself and dig in again on the question of a fuse. nice bit of reminder to do info! sounds like your mechanic might have nailed it down. curious about the fuel pump. i know that if you tighten down the pump head plate too much (ie the plate the encases the roller cell part at the top of the pump - or bottom whichever way you want to orientate it) then the pump will stall or bind. i know that one from rebuilding mine. you got to tighten down those 4 screws carefully and slowly and test the pump to make sure she spins up nice and free but does not leak at the same time. i wonder if the inside of the roller cell portion got a bit of corrosion in it or foreign material and is binding enough to make the pump really labour and draw that excess current? very interesting diagnosis. top stuff. (IMG:style_emoticons/default/beerchug.gif) Good info about the fuel pump and I will pass that on. Not sure about the fuse but in the video, you sent me I know the D-jet has a relay in the relay board unlike the L-jet. I ordered a fuel pump and a Porsche branded CHT sensor. Stay tuned and thanks again. on the basis of your mechanic's report you ought to buy yourself some glue and adhere yourself to his services. (IMG:style_emoticons/default/beerchug.gif) i do believe he is methodical in the best way. (IMG:style_emoticons/default/beerchug.gif) i mean i am half way around the planet inhabiting "the a hole of the world" as ava gardner once described my city in the most poetic terms but even from this distance he sounds like the real deal. That's pretty funny as his repair shop is called "Meticulous Motors". Sometimes I get a little frustrated because he's so analytical but it's a good thing. yes. anyway there are a few things that could be causing that fuel pump high amp draw. could be internal to the pump. don't think brushes or commutator - once they wear down its usually a simple no go. but possibly bearings on shaft finally worn out. might be some metal debris inside the pump and though its still spinning its getting harder to make itself spin up. those old 3 ports are built like tiger tanks internally but eventually i suppose there is end of life. and as i mentioned its possible that the roller cell head on the pump has become clogged in some way. more than likely that debris has made it past the filter. or the other possibility is a restriction. due either to clogged filter. internally collapsed fuel line somewhere on the line from tank to pump. or in the tank itself. at the pickup and sock. the flow delivery test on the pump can sometimes show this up. i think the flow test will certainly show up an internal problem to the pump if its there. might not show up a blockage issue as these often set in after a few minutes of running the car. Good info and I will ask him. I know he replaced the filter and did say he saw small pieces of metal in the fuel line which would indicate internal failure. I did ask about the tank sock and collapsed fuel lines but will follow-up. I went ahead and ordered a fuel pump and CHT sensor based on his diagnosis so he can replace and I can get my car back. |
| wonkipop |
Sep 27 2026, 03:07 PM
yeah that is interesting about the fuel pump in the 1.8 having no fuse. pretty sure that is the case and can remember thinking about this 5 pr 6 years ago when it came to my own car. back then i was getting my head around all the ways an L jet was different from a D jet and sifting through the factory manuals trying to nail down all the pages etc relevant to the L jet. did not ever resolve that thought back then and forgot about it. might return to that one myself and dig in again on the question of a fuse. nice bit of reminder to do info! sounds like your mechanic might have nailed it down. curious about the fuel pump. i know that if you tighten down the pump head plate too much (ie the plate the encases the roller cell part at the top of the pump - or bottom whichever way you want to orientate it) then the pump will stall or bind. i know that one from rebuilding mine. you got to tighten down those 4 screws carefully and slowly and test the pump to make sure she spins up nice and free but does not leak at the same time. i wonder if the inside of the roller cell portion got a bit of corrosion in it or foreign material and is binding enough to make the pump really labour and draw that excess current? very interesting diagnosis. top stuff. (IMG:style_emoticons/default/beerchug.gif) Good info about the fuel pump and I will pass that on. Not sure about the fuse but in the video, you sent me I know the D-jet has a relay in the relay board unlike the L-jet. I ordered a fuel pump and a Porsche branded CHT sensor. Stay tuned and thanks again. on the basis of your mechanic's report you ought to buy yourself some glue and adhere yourself to his services. (IMG:style_emoticons/default/beerchug.gif) i do believe he is methodical in the best way. (IMG:style_emoticons/default/beerchug.gif) i mean i am half way around the planet inhabiting "the a hole of the world" as ava gardner once described my city in the most poetic terms but even from this distance he sounds like the real deal. That's pretty funny as his repair shop is called "Meticulous Motors". Sometimes I get a little frustrated because he's so analytical but it's a good thing. yes. anyway there are a few things that could be causing that fuel pump high amp draw. could be internal to the pump. don't think brushes or commutator - once they wear down its usually a simple no go. but possibly bearings on shaft finally worn out. might be some metal debris inside the pump and though its still spinning its getting harder to make itself spin up. those old 3 ports are built like tiger tanks internally but eventually i suppose there is end of life. and as i mentioned its possible that the roller cell head on the pump has become clogged in some way. more than likely that debris has made it past the filter. or the other possibility is a restriction. due either to clogged filter. internally collapsed fuel line somewhere on the line from tank to pump. or in the tank itself. at the pickup and sock. the flow delivery test on the pump can sometimes show this up. i think the flow test will certainly show up an internal problem to the pump if its there. might not show up a blockage issue as these often set in after a few minutes of running the car. Good info and I will ask him. I know he replaced the filter and did say he saw small pieces of metal in the fuel line which would indicate internal failure. I did ask about the tank sock and collapsed fuel lines but will follow-up. I went ahead and ordered a fuel pump and CHT sensor based on his diagnosis so he can replace and I can get my car back. i would suggest as part of all this work and end solution you fit a high pressure full flow fuel filter after the pump. you can position it in the engine bay itself between where the lines come up into engine bay and before the injector ring. this will protect the injectors from a future pump detonation. modern turbine style pumps are def not built like tiger tanks internally. this will protect your injectors for the future. i installed one on my 1.8 back when i recommissioned as injector insurance. (IMG:style_emoticons/default/beerchug.gif) i am sure superhawk would agree with me. you can leave the filter in before the pump, but install additionally the full flow high pressure filter after it. yeah if he found metal in the lines something has let go inside the old pump. probably a bearing. the whole pump is flooded with fuel when it runs. the fuel is the lubricant for the pump internals - its completely immersed in fuel internally. |
| nmkimosabe |
Sep 27 2026, 04:03 PM
yeah that is interesting about the fuel pump in the 1.8 having no fuse. pretty sure that is the case and can remember thinking about this 5 pr 6 years ago when it came to my own car. back then i was getting my head around all the ways an L jet was different from a D jet and sifting through the factory manuals trying to nail down all the pages etc relevant to the L jet. did not ever resolve that thought back then and forgot about it. might return to that one myself and dig in again on the question of a fuse. nice bit of reminder to do info! sounds like your mechanic might have nailed it down. curious about the fuel pump. i know that if you tighten down the pump head plate too much (ie the plate the encases the roller cell part at the top of the pump - or bottom whichever way you want to orientate it) then the pump will stall or bind. i know that one from rebuilding mine. you got to tighten down those 4 screws carefully and slowly and test the pump to make sure she spins up nice and free but does not leak at the same time. i wonder if the inside of the roller cell portion got a bit of corrosion in it or foreign material and is binding enough to make the pump really labour and draw that excess current? very interesting diagnosis. top stuff. (IMG:style_emoticons/default/beerchug.gif) Good info about the fuel pump and I will pass that on. Not sure about the fuse but in the video, you sent me I know the D-jet has a relay in the relay board unlike the L-jet. I ordered a fuel pump and a Porsche branded CHT sensor. Stay tuned and thanks again. on the basis of your mechanic's report you ought to buy yourself some glue and adhere yourself to his services. (IMG:style_emoticons/default/beerchug.gif) i do believe he is methodical in the best way. (IMG:style_emoticons/default/beerchug.gif) i mean i am half way around the planet inhabiting "the a hole of the world" as ava gardner once described my city in the most poetic terms but even from this distance he sounds like the real deal. That's pretty funny as his repair shop is called "Meticulous Motors". Sometimes I get a little frustrated because he's so analytical but it's a good thing. yes. anyway there are a few things that could be causing that fuel pump high amp draw. could be internal to the pump. don't think brushes or commutator - once they wear down its usually a simple no go. but possibly bearings on shaft finally worn out. might be some metal debris inside the pump and though its still spinning its getting harder to make itself spin up. those old 3 ports are built like tiger tanks internally but eventually i suppose there is end of life. and as i mentioned its possible that the roller cell head on the pump has become clogged in some way. more than likely that debris has made it past the filter. or the other possibility is a restriction. due either to clogged filter. internally collapsed fuel line somewhere on the line from tank to pump. or in the tank itself. at the pickup and sock. the flow delivery test on the pump can sometimes show this up. i think the flow test will certainly show up an internal problem to the pump if its there. might not show up a blockage issue as these often set in after a few minutes of running the car. Good info and I will ask him. I know he replaced the filter and did say he saw small pieces of metal in the fuel line which would indicate internal failure. I did ask about the tank sock and collapsed fuel lines but will follow-up. I went ahead and ordered a fuel pump and CHT sensor based on his diagnosis so he can replace and I can get my car back. i would suggest as part of all this work and end solution you fit a high pressure full flow fuel filter after the pump. you can position it in the engine bay itself between where the lines come up into engine bay and before the injector ring. this will protect the injectors from a future pump detonation. modern turbine style pumps are def not built like tiger tanks internally. this will protect your injectors for the future. i installed one on my 1.8 back when i recommissioned as injector insurance. (IMG:style_emoticons/default/beerchug.gif) i am sure superhawk would agree with me. you can leave the filter in before the pump, but install additionally the full flow high pressure filter after it. yeah if he found metal in the lines something has let go inside the old pump. probably a bearing. the whole pump is flooded with fuel when it runs. the fuel is the lubricant for the pump internals - its completely immersed in fuel internally. That's a good idea. Is there a specific brand you might recommend? |
nmkimosabe Starting Problems Jul 31 2026, 04:18 PM
rfinegan get a smoker from amazon, cheep and multi purpose.... Jul 31 2026, 04:23 PM
nmkimosabe
get a smoker from amazon, cheep and multi purpose... Aug 1 2026, 11:51 AM
fiacra I'm going to add a few more things I know abou... Aug 1 2026, 01:32 PM
fiacra :popcorn: Aug 6 2026, 10:29 AM
rfinegan It is running now with new ignition parts and base... Aug 6 2026, 11:10 AM
nmkimosabe
It is running now with new ignition parts and bas... Aug 10 2026, 12:03 PM
TRP Congratulations on getting it to start and idle. T... Aug 10 2026, 03:30 PM
nmkimosabe
Congratulations on getting it to start and idle. ... Aug 10 2026, 09:20 PM
TRP
Congratulations on getting it to start and idle.... Aug 10 2026, 11:36 PM
wonkipop
Congratulations on getting it to start and idle.... Aug 11 2026, 05:07 AM
nmkimosabe
[quote name='nmkimosabe' post='3268296' date='Aug... Aug 11 2026, 08:54 AM
wonkipop
[quote name='nmkimosabe' post='3268296' date='Au... Aug 11 2026, 06:01 PM
nmkimosabe
[quote name='nmkimosabe' post='3268355' date='Aug... Aug 24 2026, 02:23 PM
Artfrombama I too have a 74 1.8 with FI
I was having a similar... Aug 24 2026, 02:51 PM
wonkipop
Congratulations on getting it to start and idle. ... Aug 11 2026, 05:25 AM
nmkimosabe Thanks for the advice and I will double check that... Aug 26 2026, 09:32 AM
Superhawk996 Find a new mechanic that actually understands thes... Aug 26 2026, 12:56 PM
wonkipop
Find a new mechanic that actually understands the... Aug 26 2026, 03:19 PM
wonkipop as i recall @nmkimosabe - you sent me a PM telli... Aug 26 2026, 03:47 PM
nmkimosabe I will try to clarify the status and progress to d... Aug 27 2026, 06:13 PM
Superhawk996 Given you had a worn distributor is there a reason... Aug 27 2026, 07:08 PM
nmkimosabe
Given you had a worn distributor is there a reaso... Aug 28 2026, 04:26 PM
wonkipop
Given you had a worn distributor is there a reas... Aug 29 2026, 05:06 AM
nmkimosabe
[quote name='nmkimosabe' post='3269962' date='Aug... Aug 29 2026, 12:02 PM
wonkipop
[quote name='wonkipop' post='3270009... Aug 29 2026, 02:07 PM
fiacra I can't believe this saga took yet another tur... Aug 27 2026, 09:01 PM
nmkimosabe
I can't believe this saga took yet another tu... Aug 28 2026, 04:27 PM
fiacra It's funny how things always seem to circle ba... Aug 29 2026, 07:54 AM
nmkimosabe
It's funny how things always seem to circle b... Aug 29 2026, 12:06 PM
nmkimosabe It was suggested to me today by a person with seve... Sep 5 2026, 05:34 PM
wonkipop
It was suggested to me today by a person with sev... Sep 6 2026, 07:49 PM
nmkimosabe
[quote name='nmkimosabe' post='3270852' date='Sep... Sep 7 2026, 03:37 PM
wonkipop
[quote name='nmkimosabe' post='3270852' date='Se... Sep 7 2026, 05:09 PM
nmkimosabe
[quote name='nmkimosabe' post='3271003' date='Sep... Sep 8 2026, 12:35 PM
Superhawk996 Not likely.
Can be measured if you really wanted... Sep 5 2026, 08:41 PM
nmkimosabe
Not likely.
Can be measured if you really wante... Sep 6 2026, 05:19 PM
wonkipop @nmkimosabe
situation re servicing /parts etc fo... Sep 8 2026, 01:00 PM
nmkimosabe
@[url=http://www.914world.com/bbs2/index.php?show... Sep 9 2026, 11:03 AM
re 87 alfa romeo spider. thats a co... Sep 9 2026, 01:12 PM
nmkimosabe
@[url=http://www.914world.com/bbs2/index.php?show... Sep 9 2026, 04:16 PM
some other tips for you re your 1.8 ... Sep 9 2026, 01:28 PM
nmkimosabe
[b]@[url=http://www.914world.com/bbs2/index.php?s... Sep 15 2026, 04:37 PM
Superhawk996 Here is the curve for CHT sensor - you will have a... Sep 15 2026, 07:28 PM
nmkimosabe
Here is the curve for CHT sensor - you will have ... Sep 16 2026, 12:22 PM
wonkipop
[quote name='Superhawk996' post='3271990' date='S... Sep 16 2026, 03:00 PM
Superhawk996 Lets be clear here. You have no obligation to kee... Sep 16 2026, 02:57 PM
wonkipop
Lets be clear here. You have no obligation to ke... Sep 16 2026, 04:20 PM
wonkipop i should add the symptoms are also fitting a fuel ... Sep 16 2026, 03:20 PM
wonkipop re vapor lock as an issue.
i live in a real hot p... Sep 16 2026, 03:38 PM
wonkipop ps
the fuel pressure figures you are looking for ... Sep 16 2026, 04:08 PM
Superhawk996 @wonkipop
The state of the repair industry is :... Sep 16 2026, 05:03 PM
nmkimosabe
@[url=http://www.914world.com/bbs2/index.php?show... Sep 17 2026, 06:53 PM
wonkipop yeah.
right on @Superhawk996 .
mike in here ju... Sep 17 2026, 02:49 AM
Superhawk996 I apologize if I’m coming off a bit harsh. My e... Sep 17 2026, 08:42 PM
nmkimosabe
I apologize if I’m coming off a bit harsh. My ... Sep 18 2026, 01:04 PM
fiacra Some great advice from @Superhawk996 and [b]@[u... Sep 20 2026, 12:37 PM
wonkipop
Some great advice from [b]@[url=http://www.914wo... Sep 20 2026, 02:18 PM
nmkimosabe
Some great advice from [b]@[url=http://www.914w... Sep 23 2026, 04:12 PM
Superhawk996 I don’t have a OEM 3 port pump on-site to measur... Sep 23 2026, 07:41 PM
nmkimosabe
I don’t have a OEM 3 port pump on-site to measu... Sep 24 2026, 11:11 AM
wonkipop
[quote name='wonkipop' post='3272527' date='Sep 2... Sep 24 2026, 05:04 AM
nmkimosabe
[quote name='wonkipop' post='3272527' date='Sep ... Sep 24 2026, 01:00 PM
nmkimosabe
[quote name='wonkipop' post='3272934' date='Sep 2... Sep 26 2026, 04:43 PM
Superhawk996 Give me a day or so and I’ll dig a 3 port fuel p... Sep 26 2026, 05:13 PM
nmkimosabe
Give me a day or so and I’ll dig a 3 port fuel ... Sep 26 2026, 07:09 PM
Superhawk996
Give me a day or so and I’ll dig a 3 port fuel... Sep 26 2026, 08:20 PM
nmkimosabe
[quote name='nmkimosabe' post='3273240' date='Sep... Sep 26 2026, 08:35 PM
wonkipop
[quote name='nmkimosabe' post='3273339' date='Se... Sep 27 2026, 04:30 PM
nmkimosabe
[quote name='nmkimosabe' post='3273356' date='Sep... Sep 27 2026, 04:57 PM
Superhawk996 Sorry for sloppy test setup.
Here are the curren... Sep 27 2026, 06:48 PM
nmkimosabe
Here are the curre... Sep 28 2026, 11:39 AM
Superhawk996
Impressive....as they say "a picture is wor... Sep 28 2026, 01:28 PM
wonkipop i pretty much agree with @Superhawk996 .
the co... Sep 28 2026, 02:35 PM
Superhawk996 Good point on the fuel lines - sometimes I assume ... Sep 28 2026, 06:47 PM
wonkipop
Good point on the fuel lines - sometimes I assume... Sep 28 2026, 07:15 PM
wonkipop double post for some reason, deleted, Sep 28 2026, 07:15 PM
nmkimosabe @[url=http://www.914world.com/bbs2/index.php?showu... Oct 4 2026, 07:48 PM
fiacra What a journey to get here. I'm glad you pers... Oct 4 2026, 08:31 PM
Superhawk996 :trophy: enjoy :driving: Oct 5 2026, 01:59 AM
nmkimosabe
Thanks again for you... Oct 5 2026, 08:39 AM
wonkipop top stuff
nothing like being in the hands of a me... Oct 5 2026, 05:25 AM
nmkimosabe
top stuff
nothing like being in the hands of a m... Oct 5 2026, 08:23 AM
Superhawk996
Of course, it was a rather expensive education.
... Oct 5 2026, 09:40 AM
nmkimosabe
... Oct 5 2026, 09:45 AM
wonkipop
top stuff
nothing like being in the hands of a ... Oct 5 2026, 04:30 PM
Superhawk996 Out of curiosity - did your mechanic keep the CHT ... Oct 5 2026, 11:39 AM
nmkimosabe
Out of curiosity - did your mechanic keep the CHT... Oct 5 2026, 02:46 PM
Superhawk996
Out of curiosity - did your mechanic keep the CH... Oct 5 2026, 03:10 PM
nmkimosabe
[quote name='nmkimosabe' post='3274235' date='Oct... Oct 5 2026, 03:30 PM
wonkipop
[quote name='nmkimosabe' post='3274235' date='Oct... Oct 6 2026, 01:29 AM
nmkimosabe
[quote name='nmkimosabe' post='3274235' date='Oc... Oct 6 2026, 10:50 AM![]() ![]() |
Lo-Fi Version | Time is now: 24th November 2026 - 09:17 PM |
