| Cvrguy |
Oct 1 2026, 01:15 PM
Newbie ![]() Group: Members Posts: 43 Joined: 18-September 25 From: Los Angeles Member No.: 28,995 Region Association: None |
I had all of the instrument lights go out on me recently. Is there a single ground point for them? If so, where is it? I checked the defrost light wire aft of the shifter. That's not the problem.
| JeffBowlsby |
Oct 1 2026, 01:42 PM
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,364 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None
Probably the ground behind the fuse panel, drivers side. You might also have a dash light subharness that could be disconnected, its not very long, is behind the dash gauges, look for any of the black/blue striped wires to find the common single connector to the main chassis harness.
Cvrguy Instrument lights ground point Oct 1 2026, 01:15 PM
FlacaProductions the common black/blue striped line was the one i w... Oct 1 2026, 01:52 PM![]() ![]() |
Lo-Fi Version | Time is now: 1st October 2026 - 04:38 PM |
