| nmkimosabe |
Jul 31 2026, 04:18 PM
Member ![]() ![]() Group: Members Posts: 99 Joined: 16-March 25 From: Santa Fe, NM Member No.: 28,660 Region Association: Rocky Mountains |
My 1974 1.8 with fuel injection will only start by manually opening the throttle but I can't get it idle and thus run properly. I recently had the AFM rebuilt and replaced the points, plugs, condenser and replaced the CHT sensor but the problem continues as it did before. I've looked for vacuum leaks to no avail with starter fluid. I now seek the expertise of the members of this forum for additional suggestions.
| wonkipop |
Oct 5 2026, 05:25 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,783 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille
top stuff
nothing like being in the hands of a mechanic who knows what he is doing. well done to you and your spanner man. and you probably now know more about your wonderful and technically advanced L jet (for 1974 - space age tech then) than i do. L jets for ever. (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/beerchug.gif) |
nmkimosabe Starting Problems Jul 31 2026, 04:18 PM
rfinegan get a smoker from amazon, cheep and multi purpose.... Jul 31 2026, 04:23 PM
nmkimosabe
get a smoker from amazon, cheep and multi purpose... Aug 1 2026, 11:51 AM
fiacra I'm going to add a few more things I know abou... Aug 1 2026, 01:32 PM
fiacra :popcorn: Aug 6 2026, 10:29 AM
rfinegan It is running now with new ignition parts and base... Aug 6 2026, 11:10 AM
nmkimosabe
It is running now with new ignition parts and bas... Aug 10 2026, 12:03 PM
TRP Congratulations on getting it to start and idle. T... Aug 10 2026, 03:30 PM
nmkimosabe
Congratulations on getting it to start and idle. ... Aug 10 2026, 09:20 PM
TRP
Congratulations on getting it to start and idle.... Aug 10 2026, 11:36 PM
wonkipop
Congratulations on getting it to start and idle.... Aug 11 2026, 05:07 AM
nmkimosabe
[quote name='nmkimosabe' post='3268296' date='Aug... Aug 11 2026, 08:54 AM
wonkipop
[quote name='nmkimosabe' post='3268296' date='Au... Aug 11 2026, 06:01 PM
nmkimosabe
[quote name='nmkimosabe' post='3268355' date='Aug... Aug 24 2026, 02:23 PM
Artfrombama I too have a 74 1.8 with FI
I was having a similar... Aug 24 2026, 02:51 PM
wonkipop
Congratulations on getting it to start and idle. ... Aug 11 2026, 05:25 AM
nmkimosabe Thanks for the advice and I will double check that... Aug 26 2026, 09:32 AM
Superhawk996 Find a new mechanic that actually understands thes... Aug 26 2026, 12:56 PM
wonkipop
Find a new mechanic that actually understands the... Aug 26 2026, 03:19 PM
wonkipop as i recall @nmkimosabe - you sent me a PM telli... Aug 26 2026, 03:47 PM
nmkimosabe I will try to clarify the status and progress to d... Aug 27 2026, 06:13 PM
Superhawk996 Given you had a worn distributor is there a reason... Aug 27 2026, 07:08 PM
nmkimosabe
Given you had a worn distributor is there a reaso... Aug 28 2026, 04:26 PM
wonkipop
Given you had a worn distributor is there a reas... Aug 29 2026, 05:06 AM
nmkimosabe
[quote name='nmkimosabe' post='3269962' date='Aug... Aug 29 2026, 12:02 PM
wonkipop
[quote name='wonkipop' post='3270009... Aug 29 2026, 02:07 PM
fiacra I can't believe this saga took yet another tur... Aug 27 2026, 09:01 PM
nmkimosabe
I can't believe this saga took yet another tu... Aug 28 2026, 04:27 PM
fiacra It's funny how things always seem to circle ba... Aug 29 2026, 07:54 AM
nmkimosabe
It's funny how things always seem to circle b... Aug 29 2026, 12:06 PM
nmkimosabe It was suggested to me today by a person with seve... Sep 5 2026, 05:34 PM
wonkipop
It was suggested to me today by a person with sev... Sep 6 2026, 07:49 PM
nmkimosabe
[quote name='nmkimosabe' post='3270852' date='Sep... Sep 7 2026, 03:37 PM
wonkipop
[quote name='nmkimosabe' post='3270852' date='Se... Sep 7 2026, 05:09 PM
nmkimosabe
[quote name='nmkimosabe' post='3271003' date='Sep... Sep 8 2026, 12:35 PM
Superhawk996 Not likely.
Can be measured if you really wanted... Sep 5 2026, 08:41 PM
nmkimosabe
Not likely.
Can be measured if you really wante... Sep 6 2026, 05:19 PM
wonkipop @nmkimosabe
situation re servicing /parts etc fo... Sep 8 2026, 01:00 PM
nmkimosabe
@[url=http://www.914world.com/bbs2/index.php?show... Sep 9 2026, 11:03 AM
re 87 alfa romeo spider. thats a co... Sep 9 2026, 01:12 PM
nmkimosabe
@[url=http://www.914world.com/bbs2/index.php?show... Sep 9 2026, 04:16 PM
some other tips for you re your 1.8 ... Sep 9 2026, 01:28 PM
nmkimosabe
[b]@[url=http://www.914world.com/bbs2/index.php?s... Sep 15 2026, 04:37 PM
Superhawk996 Here is the curve for CHT sensor - you will have a... Sep 15 2026, 07:28 PM
nmkimosabe
Here is the curve for CHT sensor - you will have ... Sep 16 2026, 12:22 PM
wonkipop
[quote name='Superhawk996' post='3271990' date='S... Sep 16 2026, 03:00 PM
Superhawk996 Lets be clear here. You have no obligation to kee... Sep 16 2026, 02:57 PM
wonkipop
Lets be clear here. You have no obligation to ke... Sep 16 2026, 04:20 PM
wonkipop i should add the symptoms are also fitting a fuel ... Sep 16 2026, 03:20 PM
wonkipop re vapor lock as an issue.
i live in a real hot p... Sep 16 2026, 03:38 PM
wonkipop ps
the fuel pressure figures you are looking for ... Sep 16 2026, 04:08 PM
Superhawk996 @wonkipop
The state of the repair industry is :... Sep 16 2026, 05:03 PM
nmkimosabe
@[url=http://www.914world.com/bbs2/index.php?show... Sep 17 2026, 06:53 PM
wonkipop yeah.
right on @Superhawk996 .
mike in here ju... Sep 17 2026, 02:49 AM
Superhawk996 I apologize if I’m coming off a bit harsh. My e... Sep 17 2026, 08:42 PM
nmkimosabe
I apologize if I’m coming off a bit harsh. My ... Sep 18 2026, 01:04 PM
fiacra Some great advice from @Superhawk996 and [b]@[u... Sep 20 2026, 12:37 PM
wonkipop
Some great advice from [b]@[url=http://www.914wo... Sep 20 2026, 02:18 PM
nmkimosabe
Some great advice from [b]@[url=http://www.914w... Sep 23 2026, 04:12 PM
Superhawk996 I don’t have a OEM 3 port pump on-site to measur... Sep 23 2026, 07:41 PM
nmkimosabe
I don’t have a OEM 3 port pump on-site to measu... Sep 24 2026, 11:11 AM
wonkipop
[quote name='wonkipop' post='3272527' date='Sep 2... Sep 24 2026, 05:04 AM
nmkimosabe
[quote name='wonkipop' post='3272527' date='Sep ... Sep 24 2026, 01:00 PM
nmkimosabe
[quote name='wonkipop' post='3272934' date='Sep 2... Sep 26 2026, 04:43 PM
Superhawk996 Give me a day or so and I’ll dig a 3 port fuel p... Sep 26 2026, 05:13 PM
nmkimosabe
Give me a day or so and I’ll dig a 3 port fuel ... Sep 26 2026, 07:09 PM
Superhawk996
Give me a day or so and I’ll dig a 3 port fuel... Sep 26 2026, 08:20 PM
nmkimosabe
[quote name='nmkimosabe' post='3273240' date='Sep... Sep 26 2026, 08:35 PM
wonkipop yeah that is interesting about the fuel pump in th... Sep 26 2026, 05:36 PM
nmkimosabe
yeah that is interesting about the fuel pump in t... Sep 26 2026, 07:06 PM
wonkipop
yeah that is interesting about the fuel pump in ... Sep 27 2026, 02:20 AM
nmkimosabe
[quote name='nmkimosabe' post='3273239' date='Sep... Sep 27 2026, 10:29 AM
wonkipop
[quote name='nmkimosabe' post='3273239' date='Se... Sep 27 2026, 01:20 PM
nmkimosabe
[quote name='nmkimosabe' post='3273326' date='Sep... Sep 27 2026, 01:46 PM
wonkipop
[quote name='nmkimosabe' post='3273326' date='Se... Sep 27 2026, 03:07 PM
nmkimosabe
[quote name='nmkimosabe' post='3273339' date='Sep... Sep 27 2026, 04:03 PM
wonkipop
[quote name='nmkimosabe' post='3273339' date='Se... Sep 27 2026, 04:30 PM
nmkimosabe
[quote name='nmkimosabe' post='3273356' date='Sep... Sep 27 2026, 04:57 PM
Superhawk996 Sorry for sloppy test setup.
Here are the curren... Sep 27 2026, 06:48 PM
nmkimosabe
Here are the curre... Sep 28 2026, 11:39 AM
Superhawk996
Impressive....as they say "a picture is wor... Sep 28 2026, 01:28 PM
wonkipop i pretty much agree with @Superhawk996 .
the co... Sep 28 2026, 02:35 PM
Superhawk996 Good point on the fuel lines - sometimes I assume ... Sep 28 2026, 06:47 PM
wonkipop
Good point on the fuel lines - sometimes I assume... Sep 28 2026, 07:15 PM
wonkipop double post for some reason, deleted, Sep 28 2026, 07:15 PM
nmkimosabe @[url=http://www.914world.com/bbs2/index.php?showu... Oct 4 2026, 07:48 PM
fiacra What a journey to get here. I'm glad you pers... Oct 4 2026, 08:31 PM
Superhawk996 :trophy: enjoy :driving: Oct 5 2026, 01:59 AM
nmkimosabe
Thanks again for you... Oct 5 2026, 08:39 AM
nmkimosabe
top stuff
nothing like being in the hands of a m... Oct 5 2026, 08:23 AM
Superhawk996
Of course, it was a rather expensive education.
... Oct 5 2026, 09:40 AM
nmkimosabe
... Oct 5 2026, 09:45 AM
wonkipop
top stuff
nothing like being in the hands of a ... Oct 5 2026, 04:30 PM
Superhawk996 Out of curiosity - did your mechanic keep the CHT ... Oct 5 2026, 11:39 AM
nmkimosabe
Out of curiosity - did your mechanic keep the CHT... Oct 5 2026, 02:46 PM
Superhawk996
Out of curiosity - did your mechanic keep the CH... Oct 5 2026, 03:10 PM
nmkimosabe
[quote name='nmkimosabe' post='3274235' date='Oct... Oct 5 2026, 03:30 PM
wonkipop
[quote name='nmkimosabe' post='3274235' date='Oct... Oct 6 2026, 01:29 AM
nmkimosabe
[quote name='nmkimosabe' post='3274235' date='Oc... Oct 6 2026, 10:50 AM![]() ![]() |
Lo-Fi Version | Time is now: 24th November 2026 - 09:17 PM |
