> Starting Problems, Starting with Throttle but Won't Idle
nmkimosabe
post Jul 31 2026, 04:18 PM
My 1974 1.8 with fuel injection will only start by manually opening the throttle but I can't get it idle and thus run properly. I recently had the AFM rebuilt and replaced the points, plugs, condenser and replaced the CHT sensor but the problem continues as it did before. I've looked for vacuum leaks to no avail with starter fluid. I now seek the expertise of the members of this forum for additional suggestions.
wonkipop
post Oct 5 2026, 05:25 AM
top stuff
nothing like being in the hands of a mechanic who knows what he is doing.
well done to you and your spanner man.
and you probably now know more about your wonderful and technically advanced L jet (for 1974 - space age tech then) than i do.
L jets for ever.
(IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/beerchug.gif)
nmkimosabe
post Oct 5 2026, 08:23 AM
QUOTE(wonkipop @ Oct 5 2026, 05:25 AM) *
top stuff
L jets for ever.
Well, I have learned a lot about these cars and the L-jet from reading tons of material and spending time with the mechanic. Of course, it was a rather expensive education.
nmkimosabe   Starting Problems   Jul 31 2026, 04:18 PM
rfinegan   get a smoker from amazon, cheep and multi purpose....   Jul 31 2026, 04:23 PM
nmkimosabe   get a smoker from amazon, cheep and multi purpose...   Aug 1 2026, 11:51 AM
fiacra   I'm going to add a few more things I know abou...   Aug 1 2026, 01:32 PM
fiacra   :popcorn:   Aug 6 2026, 10:29 AM
rfinegan   It is running now with new ignition parts and base...   Aug 6 2026, 11:10 AM
nmkimosabe   It is running now with new ignition parts and bas...   Aug 10 2026, 12:03 PM
TRP   Congratulations on getting it to start and idle. T...   Aug 10 2026, 03:30 PM
nmkimosabe   Congratulations on getting it to start and idle. ...   Aug 10 2026, 09:20 PM
TRP   Congratulations on getting it to start and idle....   Aug 10 2026, 11:36 PM
wonkipop   Congratulations on getting it to start and idle....   Aug 11 2026, 05:07 AM
nmkimosabe   [quote name='nmkimosabe' post='3268296' date='Aug...   Aug 11 2026, 08:54 AM
wonkipop   [quote name='nmkimosabe' post='3268296' date='Au...   Aug 11 2026, 06:01 PM
nmkimosabe   [quote name='nmkimosabe' post='3268355' date='Aug...   Aug 24 2026, 02:23 PM
Artfrombama   I too have a 74 1.8 with FI I was having a similar...   Aug 24 2026, 02:51 PM
wonkipop   Congratulations on getting it to start and idle. ...   Aug 11 2026, 05:25 AM
nmkimosabe   Thanks for the advice and I will double check that...   Aug 26 2026, 09:32 AM
Superhawk996   Find a new mechanic that actually understands thes...   Aug 26 2026, 12:56 PM
wonkipop   Find a new mechanic that actually understands the...   Aug 26 2026, 03:19 PM
wonkipop   as i recall @nmkimosabe - you sent me a PM telli...   Aug 26 2026, 03:47 PM
nmkimosabe   I will try to clarify the status and progress to d...   Aug 27 2026, 06:13 PM
Superhawk996   Given you had a worn distributor is there a reason...   Aug 27 2026, 07:08 PM
nmkimosabe   Given you had a worn distributor is there a reaso...   Aug 28 2026, 04:26 PM
wonkipop   Given you had a worn distributor is there a reas...   Aug 29 2026, 05:06 AM
nmkimosabe   [quote name='nmkimosabe' post='3269962' date='Aug...   Aug 29 2026, 12:02 PM
wonkipop   [quote name='wonkipop' post='3270009...   Aug 29 2026, 02:07 PM
fiacra   I can't believe this saga took yet another tur...   Aug 27 2026, 09:01 PM
nmkimosabe   I can't believe this saga took yet another tu...   Aug 28 2026, 04:27 PM
fiacra   It's funny how things always seem to circle ba...   Aug 29 2026, 07:54 AM
nmkimosabe   It's funny how things always seem to circle b...   Aug 29 2026, 12:06 PM
nmkimosabe   It was suggested to me today by a person with seve...   Sep 5 2026, 05:34 PM
wonkipop   It was suggested to me today by a person with sev...   Sep 6 2026, 07:49 PM
nmkimosabe   [quote name='nmkimosabe' post='3270852' date='Sep...   Sep 7 2026, 03:37 PM
wonkipop   [quote name='nmkimosabe' post='3270852' date='Se...   Sep 7 2026, 05:09 PM
nmkimosabe   [quote name='nmkimosabe' post='3271003' date='Sep...   Sep 8 2026, 12:35 PM
Superhawk996   Not likely. Can be measured if you really wanted...   Sep 5 2026, 08:41 PM
nmkimosabe   Not likely. Can be measured if you really wante...   Sep 6 2026, 05:19 PM
wonkipop   @nmkimosabe situation re servicing /parts etc fo...   Sep 8 2026, 01:00 PM
nmkimosabe   @[url=http://www.914world.com/bbs2/index.php?show...   Sep 9 2026, 11:03 AM
wonkipop   @nmkimosabe re 87 alfa romeo spider. thats a co...   Sep 9 2026, 01:12 PM
nmkimosabe   @[url=http://www.914world.com/bbs2/index.php?show...   Sep 9 2026, 04:16 PM
wonkipop   @nmkimosabe some other tips for you re your 1.8 ...   Sep 9 2026, 01:28 PM
nmkimosabe   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Sep 15 2026, 04:37 PM
Superhawk996   Here is the curve for CHT sensor - you will have a...   Sep 15 2026, 07:28 PM
nmkimosabe   Here is the curve for CHT sensor - you will have ...   Sep 16 2026, 12:22 PM
wonkipop   [quote name='Superhawk996' post='3271990' date='S...   Sep 16 2026, 03:00 PM
Superhawk996   Lets be clear here. You have no obligation to kee...   Sep 16 2026, 02:57 PM
wonkipop   Lets be clear here. You have no obligation to ke...   Sep 16 2026, 04:20 PM
wonkipop   i should add the symptoms are also fitting a fuel ...   Sep 16 2026, 03:20 PM
wonkipop   re vapor lock as an issue. i live in a real hot p...   Sep 16 2026, 03:38 PM
wonkipop   ps the fuel pressure figures you are looking for ...   Sep 16 2026, 04:08 PM
Superhawk996   @wonkipop The state of the repair industry is :...   Sep 16 2026, 05:03 PM
nmkimosabe   @[url=http://www.914world.com/bbs2/index.php?show...   Sep 17 2026, 06:53 PM
wonkipop   yeah. right on @Superhawk996 . mike in here ju...   Sep 17 2026, 02:49 AM
Superhawk996   I apologize if I’m coming off a bit harsh. My e...   Sep 17 2026, 08:42 PM
nmkimosabe   I apologize if I’m coming off a bit harsh. My ...   Sep 18 2026, 01:04 PM
fiacra   Some great advice from @Superhawk996 and [b]@[u...   Sep 20 2026, 12:37 PM
wonkipop   Some great advice from [b]@[url=http://www.914wo...   Sep 20 2026, 02:18 PM
nmkimosabe   Some great advice from [b]@[url=http://www.914w...   Sep 23 2026, 04:12 PM
Superhawk996   I don’t have a OEM 3 port pump on-site to measur...   Sep 23 2026, 07:41 PM
nmkimosabe   I don’t have a OEM 3 port pump on-site to measu...   Sep 24 2026, 11:11 AM
wonkipop   [quote name='wonkipop' post='3272527' date='Sep 2...   Sep 24 2026, 05:04 AM
nmkimosabe   [quote name='wonkipop' post='3272527' date='Sep ...   Sep 24 2026, 01:00 PM
nmkimosabe   [quote name='wonkipop' post='3272934' date='Sep 2...   Sep 26 2026, 04:43 PM
Superhawk996   Give me a day or so and I’ll dig a 3 port fuel p...   Sep 26 2026, 05:13 PM
nmkimosabe   Give me a day or so and I’ll dig a 3 port fuel ...   Sep 26 2026, 07:09 PM
Superhawk996   Give me a day or so and I’ll dig a 3 port fuel...   Sep 26 2026, 08:20 PM
nmkimosabe   [quote name='nmkimosabe' post='3273240' date='Sep...   Sep 26 2026, 08:35 PM
wonkipop   yeah that is interesting about the fuel pump in th...   Sep 26 2026, 05:36 PM
nmkimosabe   yeah that is interesting about the fuel pump in t...   Sep 26 2026, 07:06 PM
wonkipop   yeah that is interesting about the fuel pump in ...   Sep 27 2026, 02:20 AM
nmkimosabe   [quote name='nmkimosabe' post='3273239' date='Sep...   Sep 27 2026, 10:29 AM
wonkipop   [quote name='nmkimosabe' post='3273239' date='Se...   Sep 27 2026, 01:20 PM
nmkimosabe   [quote name='nmkimosabe' post='3273326' date='Sep...   Sep 27 2026, 01:46 PM
wonkipop   [quote name='nmkimosabe' post='3273326' date='Se...   Sep 27 2026, 03:07 PM
nmkimosabe   [quote name='nmkimosabe' post='3273339' date='Sep...   Sep 27 2026, 04:03 PM
wonkipop   [quote name='nmkimosabe' post='3273339' date='Se...   Sep 27 2026, 04:30 PM
nmkimosabe   [quote name='nmkimosabe' post='3273356' date='Sep...   Sep 27 2026, 04:57 PM
Superhawk996   Sorry for sloppy test setup. Here are the curren...   Sep 27 2026, 06:48 PM
nmkimosabe   Sorry for sloppy test setup. Here are the curre...   Sep 28 2026, 11:39 AM
Superhawk996   Impressive....as they say "a picture is wor...   Sep 28 2026, 01:28 PM
wonkipop   i pretty much agree with @Superhawk996 . the co...   Sep 28 2026, 02:35 PM
Superhawk996   Good point on the fuel lines - sometimes I assume ...   Sep 28 2026, 06:47 PM
wonkipop   Good point on the fuel lines - sometimes I assume...   Sep 28 2026, 07:15 PM
wonkipop   double post for some reason, deleted,   Sep 28 2026, 07:15 PM
nmkimosabe   @[url=http://www.914world.com/bbs2/index.php?showu...   Oct 4 2026, 07:48 PM
fiacra   What a journey to get here. I'm glad you pers...   Oct 4 2026, 08:31 PM
Superhawk996   :trophy: enjoy :driving:   Oct 5 2026, 01:59 AM
nmkimosabe   :trophy: enjoy :driving: Thanks again for you...   Oct 5 2026, 08:39 AM
wonkipop   top stuff nothing like being in the hands of a me...   Oct 5 2026, 05:25 AM
nmkimosabe   top stuff nothing like being in the hands of a m...   Oct 5 2026, 08:23 AM
Superhawk996   Of course, it was a rather expensive education. ...   Oct 5 2026, 09:40 AM
nmkimosabe   Of course, it was a rather expensive education. ...   Oct 5 2026, 09:45 AM
wonkipop   top stuff nothing like being in the hands of a ...   Oct 5 2026, 04:30 PM
Superhawk996   Out of curiosity - did your mechanic keep the CHT ...   Oct 5 2026, 11:39 AM
nmkimosabe   Out of curiosity - did your mechanic keep the CHT...   Oct 5 2026, 02:46 PM
Superhawk996   Out of curiosity - did your mechanic keep the CH...   Oct 5 2026, 03:10 PM
nmkimosabe   [quote name='nmkimosabe' post='3274235' date='Oct...   Oct 5 2026, 03:30 PM
wonkipop   [quote name='nmkimosabe' post='3274235' date='Oct...   Oct 6 2026, 01:29 AM
nmkimosabe   [quote name='nmkimosabe' post='3274235' date='Oc...   Oct 6 2026, 10:50 AM
- Lo-Fi Version Time is now: 24th November 2026 - 09:17 PM
