> If it weren't for bad luck, Under tank connection
NARP74
post Aug 6 2026, 05:52 PM
This is a continuation from a very long and frustrating fuel pump and fuel line project.
Everything is done BUT...
I have a small leak under the tank on the feed connection at the threaded nut. I did not anneal the copper washer, that seemed like a 50 50 issue and I took the lazy route to get it done. Now that I have several gallons of gas in the tank and have gone for short test drives, I have leakage at that connection.
I have good access to get a crow foot wrench on it and I have leaned into it quite a bit. I am seeing bad things happen if I really wrench on it. Don't want gallons of fuel pouring down on me again, don't ask!
Is there a torque spec for that nut other than the typical German phrase?
NARP74
post Aug 17 2026, 10:50 AM
Amazing what you learn when you get determined and decide to go all in. I drained the tank and took both tubes apart. As mentioned by someone before, I did have existing fiber washers already on each tube. They were so old and compressed it was hard to determine that they were not part of the brazed on fitting that the nut fits against. I was able to pry them off but they cannot be reused. They might be original to the car. The car was repainted so the tank was out at one point, but it had copper washers on top of the fiber ones. No way I was going to get that to seal.
Anyway, looks to me like the dimensions for the two fiber washers are;
Larger tube, feed side, ID 10mm, OD 16mm
Smaller tube, return side, ID 8mm, OD 16mm
Those are approximate. As mentioned the old washers were very fragile.
Someone please correct these if I am wrong. I asked AI a little while ago and it said no one had entered them into 914 World. So here they are for future use.
DennisV
post Oct 6 2026, 09:20 AM
QUOTE(NARP74 @ Aug 17 2026, 09:50 AM) *
Your dimensions are very close to what I pulled off our original tank.
* ID 10 mm, OD 16.25 mm
* ID 7.8 mm, OD 16.15 mm
Since I still haven't install our tank and have time for a parts order, I'm going to get the Red Vulcanized fiber from BelMetric. They have:
* ID 10 mm, OD 16 mm
* ID 8 mm, OD 14 mm
That's the closest I can find pre-made anywhere.
NARP74   If it weren't for bad luck   Aug 6 2026, 05:52 PM
Superhawk996   For what it’s worth it’s supposed to be a fibe...   Aug 6 2026, 06:06 PM
NARP74   Well copper is what came with the new sock I order...   Aug 6 2026, 08:23 PM
NARP74   Several online sources I checked send the screen w...   Aug 7 2026, 07:55 AM
bajafreaks   Several online sources I checked send the screen ...   Aug 7 2026, 08:28 AM
DennisV   I just installed my new tank, I wasn't able ...   Aug 7 2026, 10:13 AM
bajafreaks   I just installed my new tank, I wasn't able...   Aug 7 2026, 01:23 PM
Superhawk996   The fiber washers in this kit work but need a slig...   Aug 7 2026, 12:02 PM
Spoke   When I redid the tank I made the feed hoses so lon...   Aug 7 2026, 03:36 PM
Shivers   When I redid the tank I made the feed hoses so lo...   Aug 9 2026, 10:02 AM
Garland   I have reused original fiber washers before. If th...   Aug 7 2026, 04:04 PM
NARP74   Looking at the PET for a 74, the parts description...   Aug 9 2026, 07:47 AM
Superhawk996   So why is it that no company offers the correct ...   Aug 9 2026, 11:29 AM
DennisV   The generic HF kit has washers that are so close ...   Aug 9 2026, 12:58 PM
Superhawk996   Some very cursory poking around seems to suggest ...   Aug 9 2026, 04:59 PM
914Sixer   Check with aftermarket VW parts suppliers for fibe...   Aug 9 2026, 09:39 AM
Superhawk996   Check with aftermarket VW parts suppliers for fib...   Aug 9 2026, 11:35 AM
914Sixer   Check the hole size and just get a guitar hole plu...   Aug 9 2026, 11:23 AM
Shivers   Check the hole size and just get a guitar hole pl...   Aug 9 2026, 03:00 PM
MikeK   Try giving Painters Grinding in Denver a call. I ...   Aug 9 2026, 11:31 AM
NARP74   Try giving Painters Grinding in Denver a call. I...   Aug 9 2026, 11:36 AM
NARP74   As luck would have it, or lack thereof in my case,...   Aug 9 2026, 04:27 PM
NARP74   Amazing what you learn when you get determined and...   Aug 17 2026, 10:50 AM
DennisV   Anyway, looks to me like the dimensions for the t...   Oct 6 2026, 09:20 AM
NARP74   Still on the hunt for great substitutes. McMaster...   Aug 18 2026, 04:25 PM
Flyinlow   Still on the hunt for great substitutes. McMaste...   Aug 18 2026, 04:50 PM
NARP74   Still on the hunt for great substitutes. McMast...   Aug 18 2026, 05:11 PM
bdstone914   @[url=http://www.914world.com/bbs2/index.php?showu...   Aug 19 2026, 05:25 AM
DennisV   Have you given any consideration to a sealant on t...   Aug 19 2026, 06:21 AM
NARP74   I'll take a look at the sealing surface. Th...   Aug 19 2026, 07:27 AM
NARP74   Should I double up on the washers? On the same si...   Aug 19 2026, 07:45 PM
Steve   I converted to AN 6 and AN 8 fittings. You can th...   Oct 6 2026, 11:21 AM
NARP74   @DennisV the 8x16 is the hard one to find. I fou...   Oct 6 2026, 11:38 AM
East coaster   I used copper rings on mine, but annealed them fir...   Oct 6 2026, 04:16 PM
76-914   I couldn't find any sheet gasket material near...   Oct 6 2026, 07:58 PM
barefoot   Pretty sure I used O-rings, but I worked for Parke...   Oct 7 2026, 05:51 AM
- Lo-Fi Version Time is now: 22nd October 2026 - 11:54 PM
