> 2.0 plenum issue, Can it be removed while in the car?
robkammer
post Oct 6 2026, 09:05 AM
Robbo
Hello brain trust! The engine saga continues on our BB. What started in February as an engine reseal, head refresh, and engine compartment repair is still ongoing. The heads needed a full refresh, and close inspection found cracks, that the head expert 'fixed' with Timeserts. Lifter wear pointed to a cam lobe that was half gone. So off the short block went to a very well know Type I and IV engine builder. Wife and I went to Florida and wandered around for a month while this was all taking place. Back to Ohio in March and I started gathering the parts needed for the re-install.
The heads came back looking great, and the short block looked even better, now with fresh bearings, a stock cam and bearings, and a new oil pump.Oh, and we dicovered that I had a 2056, Cool, right?
Got the heads on, all of the tin, wiring and hoses. Put the beast in the car and started the break in process. First 30 miles, then oil change and valve adjust, then 100 more, rinse and repeat. Noticed a pretty significant oil leak coming from the front of the engine. it was the new oil pump, totally unacceptable. The builder came to my shop in hope that the oil cover gasket was the problem. Uh, no.
So out came the motor, back to the builder who is 100 miles away. At the 130 mile mark I also pulled the plugs to see how they were firing. All good, except that three of the Timeserts came out with the plugs, crap.
So while the engine was at the builder I ordered a new set of AMC heads, shipped directly to the builder. Why not, eh?
Get the engine back in with the new heads, start the process again. Got through about 65 miles and the engine is running like crap.
All of the FI bits are working as they should, and all with engine wires are Jeff b's harnesses. The only non functioning bit is the thermo sensor on the side of the plenum.
Plugs looked ok but maybe a bit on the lean side.
Time for a Smoke test! Cool tool for sure, brings back memories of my Lionel trains.
At first glance it looked like the throttle body shaft was leaking, although I had Rocky in Walla Walla rebuild it while the engine was out the second time. Nope, turns out that one of the two unused tubes through the plenum had somehow come loose and is allowing atmosphere into the plenum. I've attached a video.
So after that long intro about my sorrows, the question is: Can I remove the plenum while the engine is in the car? I struggled getting the intake runners onto the plenum the second time while the engine was on the cart, I used the 100 mile old rubber tubes and they may have shrunk. I'll buy new rubbers again, and of course the intake gaskets. But am I delusional that I may be able to get the plenum off in order to repair or replace it without dropping the engine, Again!!??
Any helpful advice will truly be appreciated.
Robbo
robkammer
post Oct 6 2026, 07:16 PM
Robbo
Thanks Emory: Yes, stock ignition. Not going anywhere until I fix the vacuum issue. Ran fine before the last engine pull. Everything I've read says not to mess with the MPS. The test I used for the MPS is out of Georges book. It holds vacuum quite well. Really the only things that have changed are fresh heads, better compression, and better valves. And again, it ran well after the first install, other than a bad oil leak at the oil pump. The new pump is a Type I pump.No leaks now.
Going to pull the plenum tomorrow, fix the leak, then back at it in few days. Also need to find that 'plain jane' pressure gauge.
emerygt350
post Oct 7 2026, 05:53 AM
QUOTE(robkammer @ Oct 6 2026, 07:16 PM) *
A 2056 uses surprisingly more fuel than stock and with the higher compression and unknown quench you will likely need to tune it, or maybe cheat it with some extra resistance in the CHT circuit. Once you get an afr installed you could put 100-200 ohms in that cht line if you notice it is dangerously lean and see how it goes. I wouldn't drive it much without checking the afr and having a CHT gauge installed. Most important is that cht. Hate to trash those new heads.
robkammer   2.0 plenum issue   Oct 6 2026, 09:05 AM
emerygt350   Hello brain trust! The engine saga continues ...   Oct 6 2026, 09:24 AM
robkammer   I need to fix that leak before going much further...   Oct 6 2026, 10:13 AM
JamesM   Sounds like a bit of an ordeal for sure Noticed...   Oct 6 2026, 10:47 AM
dax1969   Noticed a pretty significant oil leak coming from...   Oct 7 2026, 03:26 AM
Superhawk996   Noticed a pretty significant oil leak coming fro...   Oct 7 2026, 06:05 AM
JamesM   So while the engine was at the builder I ordered...   Oct 6 2026, 10:54 AM
robkammer   Hey Teeners, thanks for all of the replies. A coup...   Oct 6 2026, 04:08 PM
emerygt350   Just put a plain Jane fuel pressure gauge inline w...   Oct 6 2026, 06:15 PM
robkammer   Thanks Emory: Yes, stock ignition. Not going anywh...   Oct 6 2026, 07:16 PM
emerygt350   Thanks Emory: Yes, stock ignition. Not going anyw...   Oct 7 2026, 05:53 AM
robkammer   Hey fellas, here’s an update. I have the plenum ...   Oct 14 2026, 04:38 PM
emerygt350   Don't worry too much about the TPS. Just make...   Oct 14 2026, 06:50 PM
robkammer   Sounds simple, I guess my question is: How can I t...   Oct 15 2026, 04:28 AM
emerygt350   The wire closest to the passenger side is the idle...   Oct 15 2026, 05:49 AM
robkammer   Perfect! Thanks for the explanation. Plenum an...   Oct 16 2026, 08:09 AM
robkammer   Hey teeners, here’s the latest update; It runs...   Oct 19 2026, 06:12 PM
Jack Standz   [quote name='dax1969' post='3274415' date='Oct 7 ...   Oct 19 2026, 08:37 PM
Superhawk996   Thanks for sharing that supplier. Hadn’t seen t...   Oct 19 2026, 09:56 PM
Jack Standz   Hey teeners, here’s the latest update; It runs...   Oct 19 2026, 08:50 PM
robkammer   Hi Fellas: I do not have a CHT gauge, nor an AFR g...   Oct 20 2026, 07:43 AM
emerygt350   Hi Fellas: I do not have a CHT gauge, nor an AFR ...   Oct 20 2026, 11:51 AM
Jack Standz   Hi Fellas: I do not have a CHT gauge, nor an AFR ...   Oct 20 2026, 12:49 PM
robkammer   Thanks. I typically pull the plugs at each oil int...   Oct 20 2026, 01:12 PM
emerygt350   Thanks. I typically pull the plugs at each oil in...   Oct 20 2026, 02:10 PM
robkammer   Thanks. I typically pull the plugs at each oil i...   Oct 20 2026, 04:29 PM
robkammer   Thanks. I typically pull the plugs at each oil i...   Oct 20 2026, 04:31 PM
rjames   Thanks. I typically pull the plugs at each oil in...   Oct 20 2026, 04:55 PM
Jack Standz   [quote name='emerygt350' post='3275762' date='Oct...   Oct 20 2026, 04:57 PM
emerygt350   I am about 6 hours from you, otherwise I would lov...   Oct 20 2026, 07:15 PM
- Lo-Fi Version Time is now: 23rd October 2026 - 04:25 AM
