23mm master cylinder, out of what??? |
stock93 |
Feb 14 2005, 01:55 PM
Member Group: Members Posts: 333 Joined: 12-May 03 From: Huntsville, AL Member No.: 684 Region Association: South East States |
What car did the 23mm master cylinder that will bolt into our cars come out of?
John |
ArtechnikA |
Feb 15 2005, 06:00 PM
rich herzog Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None |
here is the trick on that that i learned only after having struggled with it - once. put the reservoir lines in the MC while it's still sitting on your bench and you have good leverage from the top. some brake assembly grease helps, but mostly it's just a matter of being on top of the problem rather than it being on top of you. then snake the lines up to the reservoir as you install the MC onto the studs ... |
Lo-Fi Version | Time is now: 8th June 2024 - 02:17 AM |
