> Bowed coil springs, Is this normal? Any ideas?
Patrick_139
post Oct 13 2026, 04:34 PM
Today I installed new 85 lb coil springs onto new Koni Sport shocks. I placed the perches on the middle setting and I ensured the springs sat in the perch and in the upper mount correctly. After installing the hardware on top everything looked normal. As I loosened the spring compressing tools (One on each side) the springs started to bow out and stay that way after the tools were removed. I compared the new installation to what came off the car. The old ones were bowed, just not as much. Once the old ones were removed from the shocks they did not have a bow in them and they were about the same length as the new ones. Also, the distance between the perch and the top of the old shock was only about a 1/4 inch longer than the new set up.
The only research I did mentioned worn out springs or springs that are too long, but I don't see that being the case here. I sent an email to the seller, but I thought I would get a few opinions here before I proceed.
BillC
post Oct 13 2026, 04:56 PM
It's a little hard to tell from the pics, but are the spring perch plates straight? They look a little crooked in the first pic.
Also, make sure the end of the coil is seated all the way into the pocket of the cap.
- Lo-Fi Version Time is now: 14th October 2026 - 02:49 AM
