| bajafreaks |
Oct 15 2026, 10:24 AM
Member ![]() ![]() Group: Members Posts: 177 Joined: 7-February 14 From: Gardnerville, Nevada Member No.: 16,969 Region Association: Northern California |
I'm in the middle of installing a new master cylinder, and yes its the job from hell.
My plastic reservoir lines are pretty brittle so I'm thinking I may replace them with rubber lines instead that are approved for brake fluid of course, it will probably make the overall MC install easier as well, at least I hope so. Anyone replaced their lines with all rubber? The size I believe is 9mm inside diameter, I'm finding 3/8" which 9.5mm. |
| emerygt350 |
Oct 15 2026, 11:11 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,780 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
is your difficulty getting the grommets back into the MC? I just did this job earlier in the spring. In my case they went in ok without too much swearing. I did it with the grommets on the lines and just pushed them in at together. Nice and lubed with brake fluid.
| bajafreaks |
Oct 15 2026, 01:12 PM
is your difficulty getting the grommets back into the MC? I just did this job earlier in the spring. In my case they went in ok without too much swearing. I did it with the grommets on the lines and just pushed them in at together. Nice and lubed with brake fluid. Trying to do the job without pulling the tank, I know, I know... Yes, the difficulty is getting the grommets popped in, tried several different ways and still cant get it. Thought if I changed the lines I could do it all on the work bench and not have to wrestle with also keeping the orientation of the metal lines since the rubber will be more flexible. |
bajafreaks master cylinder reservoir lines Oct 15 2026, 10:24 AM
bdstone914
I'm in the middle of installing a new master ... Oct 15 2026, 10:41 AM
Literati914 :popcorn: Oct 15 2026, 11:01 AM
fiacra
is your difficulty getting the grommets back int... Oct 15 2026, 01:38 PM
bajafreaks
[quote name='bajafreaks' post='3275255' date='Oct... Oct 15 2026, 02:04 PM
Shivers
I'm in the middle of installing a new master ... Oct 15 2026, 12:04 PM
bajafreaks
[quote name='bajafreaks' post='3275240' date='Oct... Oct 15 2026, 01:13 PM
Literati914
I'm pretty sure you had a thread about your M... Oct 15 2026, 03:45 PM![]() ![]() |
Lo-Fi Version | Time is now: 15th October 2026 - 05:41 PM |
